Question about Nikon D700 Digital Camera
When I plug nikkor 70-300mm 1:4-5.6 D lens to D700, show aputure error.
But, I plug 18-105 ED lens to my camera the error is not show. How I can do?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Turn the aperture ring to its smallest setting (largest f/number). You control the aperture from the camera body, the same was as on a lens without an aperture ring.
Posted on Dec 08, 2012
SOURCE: Nikon D80 Autofocus problem
Try re-setting the camera? On the D40 it is 'Menu' scroll down one to Custom Setting Menu (a pencil) and click reset 'ok' yes 'ok' this worked for me.
Posted on Sep 09, 2008
  • 138 Answers
SOURCE: Nikon D40 will not focus when shutter pressed 1/2 down
has the lens stuck up? put it temporarily on 'M" and try to turn the focus ring. this should be freely turning;
otherwise you may want to check the camera body to lens electrical contacts (silver).. a small dab of alcohol to a q-tip.. make sure its not that wet..then try to clean the contacts.
Posted on Feb 09, 2009
  • 155 Answers
SOURCE: Nikon D700 viewfinder dark
It sounds as if there is a problem with aperture blades not fully opening.
A quick test...
With a known good lens on the camera, set it to shutter priority mode. Point the camera at a plain wall or ceiling, half press the shutter button and note the aperture reading suggested by the camera. (Play around with the shutter speed settings until you get something around about f11.)
If possible, switch to another good lens and do the same. (You will need to point the camera at the same wall or ceiling!) You should find that without altering any settings, you will get the same, or very similar, aperture reading as before.
Now try the suspect lens. If there is a a fault with the aperture, the camera will almost certainly suggest that a significantly different aperture setting is required.
Hope this helps!
Posted on Jun 20, 2009
  • 62 Answers
SOURCE: Using a Nikon D40 digital slr with a AF-S DX
Please check if the Autofocus-switch on your lens is set to M/A. Also check if the Autofocus on your camera is switched on. For detailed information about your cameras autofocus, please check this site: http://www.kenrockwell.com/nikon/d40/af-settings.htm
Posted on Jul 18, 2010
  • 420 Answers
SOURCE: nikon d700 error message
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
Posted on Sep 11, 2010
Nikkor
Could be as simple as dirty electrical contacts on the lens, camera or both. Try cleaning them with a pencil eraser. Also, there is a focusing motor in the lens and circuitry in the camera. Do other auto focus lenses work on your camera? If yes, it is your lens. If no, you have a camera problem. In either case, I would take it to the Nikon repair center in your error or to a qualified camera repair man. You should not try to disassemble the lens or camera yourself under any circumstances. Reassembly is not a matter of simply reversing the disassembly process.
Mar 04, 2014 | Nikon Nikkor AF-S 28-70mm f/2.8D IF-ED...
Nikon 24-120mm G ED VR
Could you confirm that this is a G lens (without an aperture ring)? If so, try cleaning the electrical contacts on the back of the lens and in the lens mount on the camera.
Dec 01, 2012 | Nikon AF-S Nikkor 24-120mm F4 G ED VR -...
Is the 1988 Nikkor 28-85mm F3.5-5.6 lens a good alternative mid rang lens for Nikon D700?
Absolutely. Here's what one reviewer has to say about it:
http://www.kenrockwell.com/nikon/2885af.htm
Aug 24, 2011 | Nikon 28-85 F3.5-4.5 AF ZOOM-NIKKOR Lens
Is D700 or D3 compatable for this lens AF 70-210mm f/4.5-6 D
Yes. The lens is fully compatible and functional on both the D700 and the D3.
Oct 21, 2010 | Nikon AF 70-210mm f/4-5.6D Zoom-Nikkor...
Nikon 18-55 f:3.5/5.6Camera error: no lens fitted or non-CPU lens
Remove lens, clean contacts, reattach lens, wiggle it some to seat contacts.
Dec 18, 2009 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Nikon d700 error message
Have you tried cleaning the contacts on the lens with alchoho and a cotton swab? The DX lens will have to tell the camera that it's not a full frame lens, and that happens through those contacts.
Post a comment if that won't work and we can go into more troubleshooting.
Oct 03, 2009 | Nikon D700 Digital Camera
Camera will not take picture with nikkor 105mm lens
Check if the lens is properly mounted. If still you get the error message, clean the electrical contacts between the lens and the camera using an eraser. Take care not to let any dust fall into the body. Attach the lens and try.
Feb 10, 2009 | Nikon 105mm f/2.8G ED-IF AF-S VR...
Nikon D700 Digital Camera Logo
48 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
