Question about Samsung 300E5A-A03 laptop
I droped my labtop and has shaddered aperance and will not boot up
Labtop powers up but will not turn off. scream appears broken but screan not cracked
  • Samsung Master
  • 27,725 Answers
Examine the case (your laptop's exterior casing, not the carrying case.) Damages to the case might only be cosmetic and are often not even worth fixing unless you plan to sell the computer. However, severe damages to the case are often good indicators that the hardware has been damaged, too. Check to see if the case if broken, bent, or cracked. Take a look at your laptop's screen and check if it is cracked or damaged. This kind of damage will require a professional computer technician to repair. You might need to have the entire screen replaced depending on the extent of the damage. Plug in your laptop and try to boot up the system. Do this in a quiet room so you can listen for signs of damage. If the laptop is not significantly damaged, you should hear the fans starting up, the hard drive spinning, and other normal sounds your computer makes during start-up. Check with your laptop's manufacturer if you hear unfamiliar beeping. Most manufacturers have specific meanings for the different beep sequences a damaged computer will make. Listen for weird clicking, buzzing or other unusual noises coming from you computer's hard drive. This might be an indication that your hard drive is damaged and will need to be replaced. If your computer does not turn on at all, check if the battery and plug are connected securely. Verify that there is no damage in these areas and try to boot up again. Contact a professional if your computer appears to be completely dead Hope this helps.
Posted on Dec 08, 2012
    Problem Solver:
  • 17 Answers
Take out battery, then remove the hard drives and get a new laptop
Labtop won't turn on
Turn on, hold F8 button down until boot menu appears. Download Norton Boot Recovry to disc from another computer. Install in ur CD/DVD drive. Boot ur computer. Or install ur operating system disc in cCD rom drive. Reboot computer, hold F2 button down, modify BIOS boot sequence so CD Rom in 1st boot device. Boot computer, repair or reinstall operating system.
Sep 08, 2012 | Toshiba Satellite L355D-S7813 Notebook
The laptop is booting but not coming on the screen. what can i do to solve the problem?
Sometimes when your laptop edures a traumatic drop, slamming of scream, even bumping it into the hall/wall corner you dislodge the connections to your laptop monitor. Pretty simple to fix but getting to that area or your comp can be a pain. Remember you take a chance of voiding warantee if 1 exists. In my experiences this has always fixed my no screan problems and I am no comp pro. Hope it works. Let me know man
Jan 04, 2012 | Acer EXTENSA 4630Z COMPATIBLE LAPTOP LCD...
Broken laptop screan nead video to show me how to replace screan thank you ,.
www.youtube.com/watch?v=BjgMUksNhVc
www.youtube.com/watch?v=hoc_ZuU7G-I
Either of these should do the trick
Dec 15, 2011 | Dell Inspiron Computers & Internet
I need a boot disk to reboot my labtop but i dont have one because it did not come with the labtop
in that case there must be a recovery partition on the disk - the first screen that appears when you turn the laptop on will tell you what key to press to access it - then just select to recover your laptop and follow the procedure.
Jan 15, 2011 | Toshiba Satellite C655-S5085 Notebook
Wen i torn on my 6300 chia phone a white screan an
it means that you have so much files on the phone such that the quota allocated to the phones ram is not getting enough as it should. i will recommend formating it if it is a genuine phone ( i can help so do let me know)
On the other hand you can have it flashed by a phone technician
good luck and do let me know if you want to formate so i can give you the steps involved
Jul 05, 2010 | Nokia 6300 Cellular Phone
Unable to boot dell inspiron 1525 labtop
get a new battery and try that but check your power supply before you plug it in. Most laptops will work directly off power supply even with no battery present. If these solutions don't work for you then you need professional technicians help or a decent bin.
Aug 02, 2009 | Dell Inspiron 1525 Notebook
Unable to turn on my labtop (gateway 7326GZ) computer.
The real button is under the button you see. You might be able to get the keyboard cover off. If it's not broken broken you could try to reseat it. The part unless you find a cheaper source is 149.00 (which frankly is ridiculous)
Dec 31, 2008 | Gateway 7320GZ Notebook
Problems with phone
it seems like that.but it can be solved.go to the samsung care & ask to restore the phone and update its software.
Dec 24, 2008 | Samsung SGH-J600 Cellular Phone
Labtop not booting
Try pressing F12 when you see the toshiba logo appear,this will access the bios
Oct 17, 2008 | Toshiba Satellite A100-S8111TD Notebook
Broken lcd screen
**** sake my screan wont turn on at first it started to be gay with me and not let me go on my playlist then i slided my phone up and the screan wont show basicly my screan is broke can you help me
Aug 20, 2008 | Sony Ericsson Cell Phones
Samsung 300E5A-A03 laptop Logo
53 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
