Question about Hotpoint Washing Machines
My hotpoint aquarius wdl520 tripped the electrics while half way through and keeps doing it now everytime i switch it on. why is this?
Now as i try to plug back in it just trips out everytime and has still got water inside.
  • 209 Answers
SOURCE: Hotpoint Aquarius WD64 - Tripping the electric?!
something is going down to earth, start by unplugging the motor and retesting, if it doesn't trip them check the motor carbons etc, if it trips then check the heater element for contact down to earth, replace if needed etc, then check the outlet pump the same way if i have helped rate me please ps when working on machine remove from power supply
Posted on Oct 03, 2007
barkencoa
  • 3463 Answers
SOURCE: my aquairius hotpoint washer dryer wd62 keeps tripping electric why
Remove top cover, and unplug motor, try it, and if it does not trip, then motor is causing prob.
If it still trips, then heater is probably causing problem.
Please rate my advice.
Thanks.
Posted on Jun 01, 2009
  • 166 Answers
SOURCE: hotpoint washing machine keeps tripping electric
First unplug your washer. Check the ground on the washer and make sure it isn't loose; this would be a good time to inspect the wiring harness for any problems. Next check the outlet (turn off the electric to that breaker first) make sure all the wires are tight and are making good contact; pay special attention to the neutral (white) wire. If that seems fine, and you are comfortable with going into you breaker panel, turn off that breaker and check the hot (the wire on the breaker) to make sure it isn't loose and then check the neutral wire. If either of these wires seem loose tighten them down....a loose wire will move when a load is put on it and cause the breaker to trip. If all seems normal and washer is still tripping the breaker you might want to replace the breaker.....they can go bad. Good luck!
Posted on Aug 26, 2009
guythegrilla
  • 21 Answers
SOURCE: hotpoint tcl 770 aquarius tripping electrics
REMOVE TOP OF WASHER AND CHECK WIRING ON FRONT RIGHT SIDE AS IT IS PRONE TO CHAFFING CAUSING AN INSTANT TRIP.
Posted on Aug 04, 2010
  • 1525 Answers
SOURCE: my hotpoint aquarius wdl540 keeps
hello, the reason for this because theres a dead short inside washer or the socket may have a loose wire check all the earth wires inside the washer and the sockets get back to me if you still have trouble
regards
shaun
Posted on Jan 03, 2011
Hotpoint wdl520 aquarius not switching on!
hi if you are getting no power at all and fuse in plug good i would check interlock that is were door locks in next is control panel usually interlock is cause
Jan 01, 2014 | Hotpoint Aquarius WD63 Front Load...
I need to a manual for hotpoint aquarius WDL520 washer dryer
you can download the instruction manual from here.
Hope this helps, thanks for using fixya.
Nov 08, 2011 | Hotpoint Aquarius WD640 Front Load...
I NEED A MANUAL FOR HOTPOINT AQUARIUS WDL520G
You should be able to download the user manual from the following site: hotpointservice.co.uk/pages/manual
Or directly download from this link: Hotpoint/Laundry/WDL520 (pdf)
Hope helps.
Sep 25, 2011 | Hotpoint -Ariston Aquarius WD645 Front...
Hotpoint tcl 770 aquarius tripping electrics
Jul 27, 2010 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint Aquarius FDW60 tripping electrics
I had the same problem. found out that the RCD was faulty & needed replaced. now o.k.
Sep 14, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint aquarius WDL520 all lights flashing not spinning water still in bowl cant find instructions only bought it at xmas
There should be a small door at the front bottom of the machine, open it and unscrew the plunger. try that first as there could be a blockage.
The machine will not spin until the water is drained out.
Jun 17, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WM51 Washing Machine keeps tripping the electric
I had this problem; it was the motor arthing out on the body. It took a repair man half an hour to sort and it cost me £35. Hope this helps. Domo.
Jan 24, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Oct 03, 2007 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
112 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
