Question about IBM ThinkPad 600X Notebook
Safe mode boots okay but not in normal boot - no error either
After a complete hang in the ThinkPad T30, the system booted to a "blank scree" like hang or stop. I can get it to boot with safe mode, replaced the video driver to the latest and even "system restore " to a good point. However, as I exited safe mode and reboot to "normal booting", It will get through the Win xP initial screen and go to a blank screen (not like power off as I can tell the backlight is on, it is just "no-data type of blank/dark screen).
In device driver setup, there is no error on the configuration.
Sometime, I got a blue screen saying I have some ATI AGP/VGA error and then the system will restart... no sure if my ATI chip has problem but it runs find in safemode and iwth PC doctor. I can even change the resolution on safe mode to 1024x768 too...
  • Victor William Jan 16, 2009
    The IBM TP recovery CD has no repair feature. I ended up reload a fresh copy of Win XP with all pre-IBM tested driver, I still have the same probelm soo he has to be HW related.
    Upon more searching, this ATI3DVGA is a infinte loop things and others have success with using a generic driver. I end up using a simple ATI Radeon basic driver instead of the "golden" ATI Radeon 7500.... driver. And it works the 1st time. No noticable video performance degradtion on normal web serving.
    I know what I am going into for a "fresh" reload. Now, I need to adding SP3 and other things back on.... Should have done the driver change first. I believe the "golden" driver is running the ATI graphic chip at a "peak" level" and cause HW problem after a few years. Downgraded the driver with an old generation/compatible driver likely slow the ATI chip/memory speed for more margin. Using any version of ATI Radeon 7500 driver would probably cause the same problem. I have not border to try to put the 7500 driver back to see what happen...
    Wintel platform Goden rules #1 - don't change it unless it is broken !
  • 31 Answers
Do you have the original recovery disk? I recommend inserting the recover disk, restart the computer while continually pressing F12. Select boot from CD, press any key when asked, and you would want to do a "repair". That should fix your problem.
Posted on Jan 12, 2009
Display only in safe mode
It is possible that your computer is not able to start up (normally), e.g. problem with your Windows XP, Windows 7, etc. ... e.g. you see a blinking cursor at the top left corner of your (blank) blue screen.
If this is the case, you can try to repair your disk first ... in save mode, get to a DOS prompt, i.e. >
You may see options/commands (at the DOS > prompt) by typing HELP. One of the programs that attempts to repair the disk is CHKDSK. Type at the > prompt: CHKDSK /? to see the options
Then, run the CHKDSK command to repair the boot disk.
After completing the chkdsk, type EXIT (to go back to Windows). If necessary, shut down and power up again and see if the boot disk has been repaired.
In the worst case, you may have to restore your disk from backup, or boot from a back-up (boot disk / CD) to fix the boot disk problem. But first try to save/store all your (personal) files (while in SAFE mode) before you reformat the disk and re-install the operating system (from an installation / boot CD disk)
Mar 04, 2014 | HP Pavilion F1703 17" LCD Monitor
Dell 1558-2182 boots about 1-3 hours. It hangs on screen "Welcome" for 1-3 hours. Safe mode runs ok When I try to log on guest account laptop reboots When I run PSA (Pres-boot System...
before changing disk, you can try reformat and re install.
The disk may be okay and you are having windows problem especially
because safe mode works okay.
Aug 03, 2011 | Computers & Internet
After windows screen it goes blank, i know the lcd works because i can choose F2 or F12 and read and choose anything there however when i command it it just goes blank, no cursor, just blue / black ..blank
If the system will not complete boot, try the F8 boot menu and select safe mode and see if the system will boot to windows.
If the system boots to windows, you could have software issues or a startup item causing the system to hang at boot, try turning off the startup group items in MSCONFIG (Start, run, MSCONFIG) and see if the system will boot in normal mode.
If that is not help, hold the Fn Key while pressing the power buttong this should start PSA diagnostics on the system, see if any hardware fails
Jun 30, 2011 | Dell Inspiron 5100 Notebook
I am getting a blue scree error on my IBM Thinkpad R51 that says unmountable_Boot_Volume. It will not let me run on save brings me back to the blue scree error message. I have windows xp
Unmountable boot volume = The file system is damaged and cannot be mounted.
To fix that do the following:
1.Put the CD first in the boot order and boot from the XP install disk.
2.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3.Select your partition - it should be C
4.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5.At the command prompt, type chkdsk /r , and then press ENTER.
6.At the command prompt, type exit , and then press ENTER to restart your computer.
This takes a bit longer, but the system should boot back into Windows.
Jun 14, 2010 | IBM ThinkPad R51 Notebook
Screen goes blank after afew second on ac inly
Try booting to the Safe Mode (F8 at boot) see if you get any further. Also, does the system complete boot (DO you hear windows sounds?) or is the system just hanging after the Splash screen (You can also try an external monitor and press Fn+F8 to enable the external display) If you can get video externally, then is it likely a LCD or video card failure. If you can't boot to the safe mode and you do not hear the Windows Welcome sound that normally plays at the desktop, then the system is not booting and you have either a hard drive failure and/or an operating system failure.
See if you can boot to the BIOS (F2 at boot), then reload the default settings and reboot.
If you suspect the OS is a problem, boot to the XP CD, then run CHKDSK /R and see if that helps
You can also run system Diagnostics by pressing Fn+the Power button
Dec 21, 2009 | Dell Latitude D800 Notebook
Continuous windows xp startup failure
That's usually caused by a bad system driver. Next time it boots to the "start windows normally" page, select 'safe mode'. If the system boots well in safe mode, you can start from there by replacing the drivers from the system board on up until you've solved the problem.
May 07, 2009 | IBM ThinkPad T30 2366 Notebook
T30 Intermittent Booting Problems - Depending on screen angle
It is issue with the screen cable connection. Replace it. or it is getting chaffed and causing issue in proper signal and power to the screen. It is hardware issue.
Apr 24, 2009 | IBM ThinkPad T30 2366 Notebook
Windows XP won't boot and safe mode doesn't work
Well hate to give you the bad news but it sounds like your hard drive as died. The error code you mentioned (0X000000ED) designates file system damage. (Referenced here Your best solution would be to replace the hard drive in a repair shop.
Sep 07, 2008 | Microsoft Windows XP Professional With...
IBM ThinkPad T30 2367
I bet your hard drive crashed on you. You might have to buy yourself a new hard drive and replace your old one with it. Then format it and install a fresh copy of your Operating System on it. Your error condes here indicate to me that you either got a blue screen or similar. Blue Screens and/or the code that you stated here are usually caused by a software issue, and are rarely hardware issues. But in this case, you may have gotten something bad on your computer, such as a virus or serious spyware, that wiped out your Operating System And caused your hard drive to crash/become corrupt. As I mentioned, try replacing your hard drive. Hope this helps.
Sep 07, 2008 | IBM ThinkPad T30 2366 Notebook
IBM ThinkPad 600X Notebook Logo
257 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
