Question about Brother CE5000 Computerized Sewing Machine
Thread stuck in gears of brother sewing machine ce5500prw
  • 27 Answers
SOURCE: Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Posted on Feb 23, 2008
SOURCE: SEWING MACHINE BROTHER LS 1217
if you put in search online .......brother ls 1217 threading diagram it will give you completeresults to print out
Posted on May 13, 2008
  • 323 Answers
SOURCE: Brother 2001 sewing and embroidery machine.
The fact that your machine is turning hard says you still have some thread inside the machine that is binding up and activating the safety device. It must turn easily before it will work properly again.
Sometimes the machine must be disassembled to remove these threads.
sewman7
Posted on Jun 18, 2008
  • 10 Answers
SOURCE: HOW DO i THREAD A BROTHER BM2600 SEWING MACHINE
They have several brother diagrams and threading instructions @ http://www.sewusa.com. I hope this helps you.
Posted on Jul 24, 2008
SOURCE: brother vx-950 sewing machine
Place thread spool on the spool pin at back right top of machine. From there, thread through 1) rear thread guide (little hook), 2) front thread guide (front hook), 3) down and up through the thread tension dial from right to left so that thread picks up the thread spring check (the little spring on the left of the tension dial). 4) Through the thread take-up-lever, from right to left (the little lever that goes up and down). 5) Through the thread guard and guides (one on the front, one on the needle arm). 6) Through the needle, front to back. Good luck johntrev800 (at) yahoo.com
Posted on Jan 19, 2009
I have a Brother CE5500PRW and lost the spool holder. How can I put it back on?
You can use a nail that has a small head at the top. You will have to wrap electrical tape around the bottom of the nail until you get it the right size to fit the hole.
Jul 29, 2016 | Brother Sewing Machines
There is thread stuck in the upper threading compartment.
try using a pair of tweezers or wire pliers to get the thread
Jun 04, 2015 | Brother CS-6000i Electric Sewing Machine...
Unlock brothers LS2125i sewing machine
Is the thread caught in gear in top of machine causing it to bind. If you refilled bobbin did the gear switch back completely or you have lost an o ring in bobbin rewind.
Oct 16, 2014 | Brother LS-2125 Mechanical Sewing Machine
I have a "Brother CE5500PRW" machine. I have
1 - Make 100% sure you are threading the top thread correctly.
2 - Make sure your top tension is set at 5.
3 - Look in your book and make sure you have the black plastic bobbin case inserted 100% correctly.
4 - Remove the black plastic bobbin case and inspect it for burrs or needle damage, if so it needs to be replaced.
Oct 02, 2014 | Sewing Machines
I have the brother CE5500PRW sewing machine. I
Are you 100% sure you are using the right size bobbin?
Sep 11, 2017 | Sewing Machines
Difficult to use auto needle threading
you thread the machine the normal way, using every thread guide, and if the automatic theader works it will thread the needle,
if the auto threader doesn't work, then it needs to be checked.
also make sure the needle is turned the correct way and inserted correctly into the needle holder.
Mar 06, 2014 | Brother 50-Stitch Limited Edition Project...
LS-1520 Brother sewing machine hook pick thread up takes it around half way and gets stuck...any ideas. the timing seems to be right??!!
try changing needles
clean under the needle plate & in the bobbin area for loose thread or lint
make sure the bobbin is inserted into the bobbin case correctly--if the
machine won't pick the thread up from the bobbin correctly take the bobbin
out of the case & turn it around & try it that way.
Apr 13, 2012 | Brother LS-1520 Mechanical Sewing Machine
Thread tangles under throat plate while embroidering
Could the little hook that is stuck over the bobbin area be the thread cutter? My thread cutter gets stuck there and I have to turn my machine off and then try to use the cutter to reset it to its "resting" position.
Nov 23, 2008 | Brother SE-270D Computerized Sewing...
Brother CE5000 Computerized Sewing Machine Logo
79 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
