Question about HP Mini 1000 Netbook
Problem with my HP Mini 110 PC Notebook
Few days ago my HP Mini started to run slow, after I restarted it, a screen saying " Reboot and Select proper Boot device or insert Boot media in selected Boot device and press a key". I pressed F10 and went to "Boot Device Priority" But nothing appears. I also opened the computer and reconnected the hard drive, but nothing happens. Please Help!!!
  • HP Master
  • 27,725 Answers
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your operating system and computer Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter Change the first boot device to your hard drive.
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. Check the memory module and memory slot contacts. They are either copper tin or gold. The colour will tell you which they are. Mixing tin and gold can result in corrosion that prevents proper contact. Look for any sign of physical damage to the memory module, memory slots or the motherboard. Reseat the memory modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible. Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ There is a connection problem such as a bad cable
Test all power and data leads that attach to your hard drive SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty. Although it would be very rare for the sata lead to be faulty. Make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty Computers need power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Hope this helps.
Posted on Dec 08, 2012
    Problem Solver:
  • 17 Answers
Your best bet is to just take it back to the store and get a new laptop
4 Suggested Answers
SOURCE: Can not start HP mini
the hard disk must have gone bad, so when you go to bios go to diagnostics and run a test on hard drive, most probably if it fails , u need to replace the hard disk so call hp and u can replace the same
Posted on Oct 22, 2009
sfender713
  • 397 Answers
SOURCE: hp mini 110 started with a hp symble and f9=change
The hard drive is not being recognized as a bootable device- you will need to reinstall windows or replace the hard drive in order to resolve this issue
Posted on Oct 02, 2010
bronk50
  • 27725 Answers
SOURCE: Reboot and select proper boot
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to ......,press escape then press f10 to save to cmos to restart
?????????????????? hope this helps
Posted on Dec 27, 2010
HP Netbook mini 110, Bought new battery but it will not reboot properly after installed
sounds like it is powered up if it is continually restarting. Does it work with the AC power adapter plugged in? At any rate the constant restart is indicative of a failing power supply (not meaning the battery but the power converter that is inside notebook). After the BIOS the PC goes to the hard drive for the boot cycle at which point there is an increase in power demand which can cause a weak power supply (not the battery) to shutdown and restart, hence the restarting cycle. How do you tell him to fix the problem?? well that depends but I don't believe that there is a conversational repair at this point.
Nov 11, 2013 | Dell Inspiron Mini 10 Netbook Computer
We found an inconsistency in your data and are fixing it. Please wait while we restart your computer
To enter safe mode, At boot start tapping F-8. Or, Unplug, while running, remove battery, plug in, reboot, a list should come up select safe mode with networking. OR, while running open MSCONFIG, by opening RUN and typing MSCONFIG and OK, select Boot Tab, Safe boot, restart. Try Running Command Prompt, as Administrator, type sfc /scannow.
Feb 02, 2013 | HP Mini 1000 Netbook
Hp mini "unmountable boot volume"
I ran across the same problem. I used chk disc utility on a hiren's bootable usb. It found and fixed the errors on the main volume and it rebooted up without a problem after that.
Jan 27, 2012 | HEWLETT-PACKARD HP Mini-Notebook...
MY NOTEBOOK IS STARTING UP VERY SLOW PLUS ITS RUNNING VERY SLOW
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f this should schedule to happen on reboot which will scan for and attempt to recover bad sectors and automatically fix any corrupt files on your hard drive or
control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
defragment your hard drive will speed up your computer
scroll to the bottom toolbar (bottom of screen) right click you can select task manager applications also processes you will see whats running on your computer you might have virus slowing your computer also select users you will see who is using your computer
hope this helps
Jan 13, 2011 | HP Pavilion ze5170 Notebook
Hp mini 110 started with a hp symble and f9=change boot device order f10 bios setup options. after a few minites screan said reboot and select proper boot device or insert boot mediain selected boot...
Oct 02, 2010 | HP Mini 110-1037NR Netbook
HP Mini 110 no Wifi and intermittent sound
Press the wireless button.
This shoud solve the problem.
Apr 16, 2010 | HP Mini 110-1037NR Netbook
Black screen says reboot on my minihp
Hi there please try these mentioned below.
1. Restart the PC and repeatedly hit F8 until you have a menu in front of you.
2. You will find few option there. Just select these mention option " Last know good Configuration ...." use by your up/down arrow on your keyboard.
3. Press enter there.
4. your will see the system asking you for which OS you want to use. If you have only one OS then just press ENTER there or select the OS and Enter.
After these if you face the same problem then format the OS & install it again.Thanks & waiting for your feedback.
Feb 15, 2010 | HP Compaq Presario V6000T Notebook
Have HP mini notebook. everytime im on the
Sounds like spyware / malware i would use an online scanner like Eset or a program like Malwarebytes.
also to stop the computer from restarting open the command prompt window (start menu, click run, type cmd, click ok...) type "shutdown.exe /a" without the "" and there is a space between exe and /a this will abort the shutdown.
Jan 22, 2010 | HP Pavilion 110-1030NR Notebook
I brought a hp 110 mini from a flea market and dont have the pass code want to do to reboot it
must ask on flea market tech support, for change passw or give the right passw
Jan 02, 2010 | HP Pavilion 110-1030NR Notebook
How to Reset HP Mini 1000 Laptop BIOS?
http://laptoppassword.blogspot.com/2011/06/hp-mini-password-service-compaq-mini.html
Clear Bios Password for HP Mini - Compaq Mini:
HP Mini 1000, HP Mini 110, Compaq Mini 110C, Compaq Mini 110, HP 2230S, HP Mini 1120LA, HP Mini 1151NR, Compaq 700....If you see this screen on boot:Enter CURRENT Password: [_______________]
We can help you Remove Password, right now !!!
You just enter 3 random passwords one by one and see if you get a similar [System Halted] message with 10 chars Error Code. (e.g CNUXXXXXXX, 2MCXXXXXXX....)
Jul 16, 2009 | HP Mini 1000 Netbook
HP Mini 1000 Netbook Logo
62 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
