Question about Vehicle Parts & Accessories
Have a rs90 car starter and t-harness for2001 subaru forester cannot finde diagram showing were in harness it plugs into
    Problem Solver:
  • 12 Answers
If its a remote start harness, then it has to plug into the ignition harness. try the back of the key cylinder ( thats where your ignition harness is)
Posted on Jan 15, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Can i hardwire an aftermarket stereo in my 2001 vw passat without any issues and is there a diagram on how to do it? Ive installed many stereos but from what ive read it sounds a little tricky.
use an adapter,do not cut factory wiring harness!!!!!!!!!!!! plug right into the factory plug,get your adapter here or find one online,dont forget your antenna adapter too,walmart also carries the adapters, Car Stereo Installation Parts for2001 VOLKSWAGEN PASSAT4DR 5DR SDN WGN GLX
May 15, 2015 | Cars & Trucks
Need wiring diagram for 2009 subaru forester drivers window harness
go to product tools.com and they will give it to you.
Jan 27, 2013 | 2009 Subaru Forester
Changed the alternator and starter and the timing belt on a 1998 subaru forester and it still wont start ...
If the engine cranks but won't start, the starter and alternator would not be the problem.
Was the engine running before you changed the timing belt ?
Do you have spark to the plugs and fuel to the injectors ?
Do you have normal compression on all cylinders ?
Jan 23, 2013 | 1998 Subaru Forester
Fuse box layout for subaru forester
On this website you find fuse box diagram and description for Subaru Forester
http://www.autogenius.info/category/subaru/forester
Mar 29, 2012 | Cars & Trucks
2000 subaru forester/wiring for a trailer
The easiest way is to go to any RV dealer, or most Autoparts stores and buy an adapter. They plug in to your existing wiring harness under rear of vehicle and then you simply plug your connector in to it from there. Saves trying to figure it all out and cutting or splicing into your existing wiring and possibly causing problems later.
Nov 12, 2011 | 2000 Subaru Forester
1999 Subaru Forester Where is fuse for electric
you may find the fuse diagram on the inside of the fuse box cover, try looking under the dash there might be another fuse box there.......hope this helps....cheers
Sep 13, 2010 | 1999 Subaru Forester
2000 subaru forester ignition coil wiring
Are there any other possible problems, or you are just not receiving spark at all now?
The coilpack could be dead and just need replaced. If you have a voltmeter or a test light, check the wiring on both sides of the coilpack harness to make sure it is receiving power.
I don't believe Subaru used ignitors past '99, but if they did, your should be located on the firewall behind the throttle body. Make sure it's plugged in and receiving power.
Coil packs do go bad from time to time. I had to replace mine in my
'98 Impreza a while back.
Mar 15, 2010 | 2000 Subaru Forester
Tow bar trailer socket wiring connection point to car wiring?
The connectors for towing wire harnesses on foresters are generally on the passenger side, below the rear taillight inside the cargo space. some require pulling up the foam block that is between the spare tire compartment and the taillight. Check where you replace the tailights from inside the car, if there isn't a matching connector hanging out there, check around the spare tire compartment, see if you can remove the carpeted foam block next to the compartment and find the plug under there.
Jun 03, 2009 | 2006 Subaru Forester
Adding fog lights to a 2003 forester X
If they are factory lights or even aftermarket they shoudl give you diagram. Oh and you will have to get a relay that subaru sells. most cars already have the accesory spot for it you just have to add the parts. subaru should tell you this. I was a subaru tech.
Apr 24, 2009 | 1998 Subaru Forester
Radio connection Pioneer vs Subaru Forester
I would like to refer you to a reputable car audio dealer.
If you have NOT yet CUT THE FACTORY HARNESS, DON'T!!!!!!!
Airbags are nothing to take lightly...
I HIGHLY RECOMMEND a wiring harness adapter from a reputable source such as METRA, Scoche, or Pozitive Connections. Every wiring harness adapter changes the colors at the "pioneer side" of the harness to color match the PIONEER RADIO. All you have to do is color match, plug and play.
HOPE I HAVE HELPED.
Scott
Sep 27, 2008 | Pioneer DEH-2800MP CD Player
Vehicle Parts & Accessories Logo
94 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
