Question about Dryers
How do i reset a remote control model no YCT-100 which switchs on my legend electric fire
  • 54 Answers
Reset the remote: undo the Philips screw on the back and prize ip the circuit board, then turn it over, keeping the battery in place. There is a slide switch on the back; move it all the way to the left, pause, then all the way to the right, pause again (10 seconds) then move it about a third of the way to the left until it drops into a dent. Carefully reassemble, keeping the battery in place. If this doesn't work, you probably need a new circuit board (receiver) in the fire.
Posted on Aug 11, 2017
Yct-100
What is the Brand name and model number to your TV?
Dec 31, 2012 | Televison & Video
Bulb blew in my dimplex michigan fire, model MCN20. I now can't get the bulbs to switch off with either the remote control or the on/off switch.
Stewart, turn the Master ON/OFF Switch to OFF. Unplug the unit from the wall outlet and wait 12 - 15 minutes. Then plug the unit back in and turn the Master ON/OFF Switch to ON and set the function controls manually (not with the remote) one at a time. If everything works as it should, the fire reset itself during the 12 - 15 minute timeout. If it didn't or that problem continues to reoccur, contact Dimplex North America, Technical Service at 888-346-7539.
Hope this helped you solve the problem.
Apr 27, 2011 | Heating & Cooling
The amplifier was put to mute on using the remote control then the remote control was broken and cannot use anymore. How can I return back the amplifier to normal without using the remote control?
Two suggestions.
1) You may be able to reset the memory and get back to factory default settings by either unplugging from the power point and leaving it unpowered for at least 5 minutes - some products could require a few hours for memory to be reset. Alternatively your amplifier may have a reset funtion (usually a button or switch on the rear panel - see owners manual for specific instructions of your model)
2) Since your remote is broken, the cheapest option is generally to buy a universal remote control (available from may discount and electrical retailers) for around $10.00 enter the code for your particular amplifier and then use the amp as you did previously - you might like to double check that your brand/model is supported by that particular brand remote manufacturer - the better ones (read dearer) even allow you to down load the remote codes from the web (this would be overkill for your problem, but you might like to combine all your remotes into the new tricky one you will buy).
Feb 15, 2010 | Yamaha DSP-A3090 7-Channel Amplifier
No flow of gas to fire after pilot light is lit and turned on.
i have had a legend vantage slide control gas fire for about 5 years.this problem is i believe a blocked oxy get which is a failsafe device to prevent a gas leak.can be remedied easily by a gas safe engineer.
Jan 07, 2010 | Vantage Televison & Video
MY REMOTE ALWAYS SHOWS ME REM506....
The Audio System does not respond to the remote control.
1. To reset their connection, turn on the remote control and switch the Audio System to Standby mode.
2. In Standby mode, press and hold both INFO and SOURCE on the front panel of the Audio System. It is reset to default when"RF ID clear" displays.
3. Press and hold both PROGRAM and SELECT on the remote control. When “ID claer” displays on the LCD of the remote control, the connection is reset.
4. By now the remote control and the Audio System should be connected to each other. Press and hold PROGRAM and SELECT on the remote control again. When
“ID Locked” displays on the LCD of the remote control, the connection between the remote control and the Audio System is locked.
May 07, 2009 | RCA RS2100 Shelf System
Hampton Bay remote for ceiling fan caused an electrical fire
We just installed this fan and within 1 day the electrical wires in the receiver burned and would have caught fire had it not been caught!!!
Jan 07, 2009 | Universal Remote Control Hampton Bay...
Need code for a legend tv
Hey there,
This brand uses the same code as sylvania/emerson. Try using the emerson codes, and that should give you the basic functions with remote. Here are some of the emerson codes. Just drop first 0 if your remote only takes three #s. Try each until one works. Good Luck!
0463, 0236, 0019, 0180, 0280, 0179, 0154, 0177, 0178, 0038, 0185, 0282
Nov 30, 2008 | Radio Shack 15-2142 Remote Control
Dryers Logo
607 people viewed this question
Top Dryers Experts
