Question about Kenmore 98702 Stacked Washer/Dryer
Washer stop washing and dryer stop heating
Washer stop while washing a load of clothes and dryer stop heating also
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
Check the breakers first.
Posted on Dec 08, 2012
jsrock516
  • 5911 Answers
SOURCE: Unbalanced loads
There has been a noted problem with the Kenmore Oasis and the "Out of Balance" or "Ob" error. If this is what you are experiencing, the problem has been attributed to a couple of things. Not having sufficient amount of clothes in the wash tub during a wash cycle. That is...smaller loads cause a problem when the washer tries to distribute he weight evenly in the spin cycle. Not enough clothes, no balanced weight, you get an Out of Balance indication. The other problem (which tends to be the more common issue) is the control board under the operator console. The manufacturers developed a new software to run on the new and improved control boards that is supposed to correct this problem. Double check your load distribution first (which it seems you already have), then check with the manufacturer to see if there may be a recall on your washer that corrects this problem at no cost to the consumer. I hope this helps you some.
Posted on Nov 11, 2007
  • 131 Answers
SOURCE: Dryer takes forever
You have a clog somewhere in the venting. Anywhere between the lint screen and the outside of the house. Use a vaccum with a crevice tool to reach behind the lint screen. Also check the flaps on the outside of the house. You can also access the machine end of the vent pipe by removing the two Phillips screws on the angled panel just below the dryer door. If you feel you need to take apart the machine further to clean behind the lint screen, write back. It's very tricky, and will take some time, but I can walk you through it.
Posted on Mar 12, 2008
SOURCE: Rust stains and bleach spots.
I'm sorry but the white spots will be due to bleach. It may be that there was undissolved bleach in the washer after the first load. Maybe some of it came out with the whites and lay in wait in the basket.
I doubt the makers would guarantee anything for 7 years, so no free basket or installation is likely. Seems there is a chip in the enamel and dampness / water from the previous wash days before sits there collecting iron as rust particles.
For the time being you could try rinsing the machine out before the first load. That might prevent the rust marks or reduce them.
Posted on May 04, 2008
aborcass
  • 2651 Answers
SOURCE: washer won't drain or spin
top loader ??? or front loader??? if top loader you have broken your lid switch, will fill, agitate, but when it comes to drain/spin for safety reasons if the unit doent recognize the lid closed it will not advance...if yo have a front loader then i would suspect that something has gotten into the pump assy and preventing drainiing of water therefore will not spin
Posted on Mar 02, 2009
SOURCE: top load Kenmore 800 washer will not fill with water
OK - I have a solution to my problem with this washing machine. Nothing would work except for one of the spin cycles. I thought it was the main switch - the cycle selection and start switch - but I was wrong. The service tech replaced the switch behind the fabric softener. It's the switch that controls the water levels. Part # W10292584. Our government is forcing the manufacturers to put controls on the washing machine to save water. It's a bad idea and is causing lots of problems. Tech says he's replacing them on a regular basis. Less than $100 if you do it yourself. Hope this helps.
Posted on Feb 20, 2010
Washing machine not washing clothes properly, clothes coming out cold. dryer also not heating up, repairman said to get new heating element for dryer but said nothing was wrong with washing part of machine...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jun 11, 2010 | Hotpoint Aquarius WD640 Front Load...
Inglis dryer-spinning,not heating,Inglis washer not spinning well
Your heating element is going out. Mine did this a few months ago. It is an easy fix. Look up the part online.
Apr 13, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Tumble dryer isn't woking
You may need to replace the thermostat or the heating element.
Apr 13, 2009 | Hotpoint -Ariston Aquarius WD645 Front...
Error E20 showing ........stops during wash cycle and clothes not dry on drying cycle
not familar with the code but usually wash has a built in thermo stop to wait for water to heat to correct temp,if it works normally in a rince cycle and spins out and finishes properly i would look at heat element or stat,hope this helps
Apr 06, 2009 | Zanussi ZJD1219 Front Load Washer / Dryer
Clothes dryer
washer dryer and dryer ony machines differ in a huge way. the big diff. is the drums on each are completly different sizes. the conventional dryer has the bigger, giving better air flow and tumble to clothes. the w/d has a smaller drum thus less air flow and less tumble between clothes. the best way to see this effect is remove half the clothes after a wash and then select a drying cycle. u will see that by giving the clothes more room to tumble free of each other rather than tumbling in a large ball will dry them. washer dryers are really only a marketing tool.
(ex main brand engineer)
Nov 12, 2007 | Candy DQW150 Front Load Washer / Dryer
Washer - yes, dryer - NO!
may be as simple as a broken wire to the dryer heat element, take the top off & check if you have 240 volt supply to the dryer heat element
Oct 16, 2007 | Hotpoint Aquarius WD63 Front Load...
Kenmore 98702 Stacked Washer/Dryer Logo
Sal De
fordexpert
Whirlpool
Whirlpool
