Question about Bodycraft Rowing Machine VR100 Rower
Display is dead
Rowing machine was not used for awhile, I am guessing there is a dead battery that would otherwise have recharged with use. I have a lot of equipment and some become more favored than others. It seems the same thing happened to the bike. My repair guy charges $125 just to come out and tell me the problem, then I get dinged for another visit but he is the only game in town. Is there a way I can remedy this on my own?
  • 81 Answers
From what I have seen and read, it does run on batteries but they do not recharge. Look for a door on the bottom. If not then it needs to come apart. Still cheaper than a $125 repair guy. Let me know if you need more help.
Posted on Jan 12, 2009
  • 10,515 Answers
The normal preocedur wld have been :)
If this is the case, there are 3 alternatives:
  1. Recharge the battery pack by attaching via USB to a plugged in PC
  2. Use a USB-mains adapter (ensure the correct USB connector)
  3. And possibly the simplest solution:
  4. Use two alkaline D-Cell (LR20) batteries..
 Now we have to check the first and foremost option :) Isnt it....so Lets move...
 Do not wait for so many replies....let me send u a link that wld help u to determine whether its battery or something else...
http://www.concept2.com/us/service/monitors/pm4/pm4troubleshooting.asp
It will also help u to recognize any future troubleshooting ....
Take Care.
    Genius:
  • 2,920 Answers
Watch what he does then next you can do it instead of calling the guy out,just watch closely to what he does to fix it and then youll know how to do it on your own
  • 2,071 Answers
Just open the display console and replaced the battery .The LCD display is powered up by a button cell battery maybe run out already.
Hope it may help you;
Regards;
VOTIT
Display not working
Most likely the batteries in your display have been depleted. Check your console for the battery compartment and change them.
For customer service, Concept 2 can be reached at (800) 245-5676
Dec 02, 2013 | Concept2 2 Rowing Machine
Concept 2 rower screen says batteries are low even after I install new batteries.
Have you checked to make sure there is no corrosion or dirt on the battery terminals/contacts resulting in reduced voltage flow? If dirty try using a dollar bill(the fibrous paper used to make money is slightly course) to clean them as even a fine grit sand paper is too course for these contact points( you just want clean them, not scratch the finish off)
Feb 25, 2013 | Concept2 2 Rowing Machine
Computer replaced batteries - screen lights up but does not function when rowing - not registering meters
Check the mtion sensing magnetic switch thats under the seat rail. It determines if you are rowing and sends a signal to the computer. Make sure all connections are fully seated. You may have loosened a wire when you swapped the batteries.
Feb 24, 2011 | Concept2 2 Rowing Machine
Display screen doesn
I had the same problem here,,,
This was my friend rowing that we received as a "gift" (he wasn't using it anymore) and the LCD display stop working.
Without the user manual, I decided to remove the side panel and by doing so the LCD panel pop out showing the source of the problem...
The AA battery simply felt off inside the case.
So my guess is that either your battery felt off or is dead.
So here're the steps...
1. remove the LCD panel (use a flat screwdriver if needed)
2. if there's no battery, it is probably inside the assembly. You can try to retreive it by removing the 7 screws on one side or simply leave the battery if it's not interfering with the rowing mechanics.
3. if there's a battery, it's probably dead. Change it!
Apr 02, 2010 | RTO Lifespan RW1000 Rowing Machine
Correct distance rowing
Is it 50 meters in a minute? That comes out to about 32 minutes per mile.
Feb 22, 2010 | Exercise & Fitness
Rowing machine foot plate sensor
thankyou but i managed to phone a sports shop and order my part...many thanks.....****
Sep 15, 2009 | Exercise & Fitness
Slack in line on rowing machine
extend the line to its max required length while you are sitting on the machine { as using } then get someone else to adjust the slack on the line and make it taught , the adjustment should be a bolt and nut type located on the main wheel . do not adjust the line from the seat as this may dislodge the seat . happy rowing
May 06, 2009 | Kettler Coach Rowing Machine
Maintenance
Rowing Machine Kadett Rowing Machine CTGID0 maintenance
Dec 01, 2008 | Kettler Rowing Machine Kadett Rowing...
What are the benefits of a Rowing Machine?
One of the major benefits of the rowing machine is that it assists in strengthening the torso, the upper body where most of our main muscles are located. In addition to, legs is constantly work out although in the lifestyle of today, the area around the upper body is used more than the legs. The use of resistance to workout the area around the upper body significantly contributes to improving the core strength of the chest, shoulders and forearms. With improved strength, it gives rise to an upper body strength that is more stable and solid to carry out our day-to-day tasks easily. The legs are firmly workout as well although not as much as the upper body but you will be able to notice the difference when you work out consistently. One of the better benefits of a rowing machine is that of calories burning but few use it mainly for that purpose as other fitness equipments such as the Nordic Track, stationery bike and treadmills can do so effectively. In addition to, the rowing machine can help to improve lean muscle mass and given that lean muscle mass burn off more calories for a given size, the body will utilize more calories to nourish the muscle. As a result, rowing machine effectively increases metabolism so as to feed the lean muscle with the requisite calories. Very few people know that rowing machine help to reduce the stress level and anxiety through the frequent use of it. Exercising makes a person less depress and edgy and it is one of the most beneficial and least appreciated of all the rowing machine benefits. Keeping our mental faculties alert and well is as important if not more than physical aspect of our health. To derive all the benefits mentioned, we need to effectively make the most out of the rowing machine. The information that we gather here will be very relevant to utilize the most from the rowing machine. Fully understanding the machine itself and its functions can contribute to us getting a complete and beneficial workout. Rowing machine mimic the actual rowing experience of a boat for the sole function of aerobic and strength training workout as well as for those training for rowing. The machine has been in existence for more than a century but only in recent years that it gains in popularity. The market for rowing consists of a few types of resistance and they are the air resistance, piston resistance, water resistance and magnetic resistance. All are equally effective and none can claim to be better than the others. Each has their own admirer and the types of resistance you choose will hinge on the relevance of your exercise as well as the state of your fitness level. To derive the most out of the rowing machine, you need to know the different types of resistance levels and the air resistance will increase in resistance as you increase your pace. The piston resistance is the most popular as it is so small and compact that allows the machine to be foldable and move around as well as easy storage. Water resistance comes close to the actual rowing experience and the workout is as intense and the magnetic resistance makes use of electromagnets which make it very smooth and quiet in operation. With lesser noise, similar to air resistance, it provides a great workout without disturbing other. Besides understanding resistance levels to fully utilize the rowing machine, the other extras are as important. The computerized digital display that provide all the functions of the rowing machine such as calories burned, distance covered, time and speed to better gauge our training. All these may come at an additional price but all is worth it. Rowing machine remains one of the best fitness equipments out there and with regular workout, the results are there to see.
Bodycraft Rowing Machine  VR100 Rower Logo
133 people viewed this question
Top Bodycraft Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Bodycraft Exercise and Fitnes Expert? Answer questions, earn points and help others
