Question about Lexmark JetPrinter Z55 InkJet
Lexmark z23 I can't get any printing done because when I turn the power on the "paper light" keeps flashing (like when paper's jamed) even when there's no paper there. Can any1 tell me what the problem is???
    Genius:
  • 2,985 Answers
Carefully check the paper feed track to ensure there is no debris stuck- only needs a crumb to do it. Take a stack of paper- knock it up- that is with it in your hand knock the ends together so the that all feed straight. Then try. - no Go? Get a piece thicker paper/card- and try a paper feed with this single sheet. Sill no go? Try to find out how to 'reset' your printer This may mean if you have several buttons on the machine- with the machine off- hold the buttons down then switch the machine on and keep the button down until it has stopped initializing. Still in trouble? Take a look at www.fixyourownprinter.com
Posted on Jun 11, 2007
My lexmark z23 printer keeps leaving blots of ink or marks all over the pages that it prints
You may need to clean the nozzles on your cartridges. Please follow the instructions in this article in the Lexmark website on How to Unblock (Clean) the Cartridge Nozzles in the Lexmark Z13/Z23/Z33 Color Jetprinter.If problem continues, try to insert a different known working cartridge to determine if your other cartridge is faulty. Thanks.
Feb 23, 2011 | Lexmark Color JetPrinter Z23 InkJet
Paper won't feed. need button press for each sheet; z23 lexmark printer.
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 21, 2010 | Lexmark Color JetPrinter Z23 InkJet
Printer sounds as if it is printing, paper runs through,
Have you tried to clean the nozzles?
Did you print a test page after installing the new cartriddge?
Go there http://www.lexmark.com/publications/pdfs/z33/enuserlx.pdf
Sep 26, 2009 | Lexmark Color JetPrinter Z23 InkJet
LexMark Z23 printer error message
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 03, 2009 | Polaroid Lexmark Z23 USB 1200x1200dpi...
Lexmark z23 won't print and when i do the wizard hardward installation it said that it cannot find software location. Can you please help me?
you need the Lexmark z23 driver installed on your computer first. Here is the lexmark website. just download the driver and install it. Once that is done you should be able to chose it when printing.
the following link is for your printer.
http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=229:1:0:285:0:0
Oct 23, 2008 | Lexmark Color JetPrinter Z23 InkJet
Lexmark z23 will not print
go to the printer properties---there select printing preferences ---there select lexmaxr solution center-----in that option select printer cartridge replacement option----in that follow the replacement instructions.and select the cartridges.as it is new.and its proper appropriate number.then only it will print properly. selecting the cartridge is very much necessary.
Sep 12, 2008 | Lexmark Color JetPrinter Z23 InkJet
Lexmark z23
its a mechanical issue , if your handy you have to open and check the rollers where its connected with some plastic wheels , I fix one before with this issue , what I found is one of the plastic wheels was broken (pulleys with teeth) , hope this helps AJ
May 01, 2008 | Lexmark Color JetPrinter Z23 InkJet
Lexmark z23
DONT GET THIS Z23 PRINTER ,its a mechanical problem, the problem its the rollers , where you see some wheels inertchanging with each other , check for some broken teeth on these pulleys , printer suffers this problem ,
Apr 07, 2008 | Lexmark Color JetPrinter Z23 InkJet
Paper sensor, I think
check the cable first..and do a test page, if you can without the printer connected to anything.
then, if that all works, we can look elsewhere, no?
Mar 06, 2008 | Lexmark Color JetPrinter Z23 InkJet
Lexmark P4350
Solution:
I have a Lexmark and it says that there is "No Loaded Paper" some times and when you click ok it keeps saying it. If the power light is flashing on the printer - try this suggestion.
Suggestion:
  1. Press the power button (Which will turn off printer.)
  2. Wait till flashing stops and printer is completely off.
  3. Press the same button which will turn on the printer.
  4. The Printer should automatically go back to printing.
  5. If it does not - Manually try printing by your self.
Dec 04, 2007 | Lexmark P4350 All-In-One InkJet Printer
Lexmark JetPrinter Z55 InkJet Logo
206 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
