Question about Hasbro Playskool Kota and Pals Monty T-rex In Box Dinosaur
The head in kota the dinosaur stopped working. It just hangs and makins a clicking noise. All other parts work.
The head just hangs and makes a clicking noise. It doesn't lift up. Everything else still works. Is their a repair or replacement part?
3 Suggested Answers
  • 8 Answers
SOURCE: Hasbro S'mores tail broken off, makes clicking
Not sure about the clicking but her is how to repair the tail. Had the same problem and the fix is easy. Hopefully, the tail snapped off at the base of the plastic plate on the tail. If so, go to a hardware store and buy 1 ft. of CLEAR plastic tubing with 3/16" inner diameter and 5/16" outer. Cut off a piece about 1 1/2". Now, look at the base of the tail and you should see a small screw that holds in what remains of the stub that broke. Unscrew the screw and remove what is left of the stub. KEEP THE SCREW. Now drill a small hole thru the plastic tube about 1/8" from the end. This will later be inserted into the tail and the screw will go through the holes. Next, take a hair dryer and heat the undrilled end of the tube to soften it and push it on to what is left of the broken stub inside the pony. It will be a tight fit which is what you want. You will probably need to twist the tube gently while applying firm pressure on it to make it slide over the stub. The end of the tube with the holes should be about even with the outside top of the white plastic hole and the tube holes should be level, looking at it from side to side. This makes the alignment of the screw hole to the tail correct. Now slide the tail over the end of the tube and insert the screw. I just did it today and it works good as new! If the tail is too far away from the body of the pony, carefully twist and remove the tube and shorten it. Since you bought a 1 ft. tube, you can have several trys to get it right if you cut it too short! Total cost for the tube was 21 cents. Good luck! Kip V. Tryon, NC
Posted on Jul 23, 2010
lisaf
  • 47 Answers
SOURCE: its not working right the head only moves a little and only half the face works
Did you buy it with the head off new or did you buy it used and the seller removed the head?
Posted on Dec 12, 2011
How to fix my kota triceratops neck?
New you tube video 2:50 min video called Kota dinosaur
broken/hanging neck repair
Jan 16, 2016 | Hasbro Playskool Kota and Pals Stompers -...
How can I get an instruction manual for Playskool Kota dinosaur
Hasbro has the instructions and replacement parts for many of the Playskool toys on their support site, http://www.hasbro.com/site-map.cfm . The instructions for the Kota the Triceratops are available here: http://www.hasbro.com/common/documents/dad2af771c4311ddbd0b0800200c9a66/61EED7975056900B10DED12F214D6B3E.pdf . The instructions for the Kota and Pals Ankylosaurus are here: http://www.hasbro.com/common/documents/dad2af771c4311ddbd0b0800200c9a66/F235292B5056900B10B29E652C4640C1.pdf . However, they do not have any parts for the Kota and Pals set. You may find the leaf available in an internet auction.
I hope this helps.
May 01, 2014 | Hasbro Playskool Kota and Pals Monty T-rex...
Kota manual
According to Amazon, the only thing that comes in Monty's box is Monty, 4 C cell batteries and a "discovery sheet". There are several pages about the Kota dinosaurs with a lot of information including Amazon. I'd suggest contacting Hasbro for the "Discovery Sheet" if you can't get the info from the Amazon page http://www.amazon.com/Playskool-Kota-Pals-Monty-T-Rex/dp/product-description/B001WSCU34/ref=dp_proddesc_0?ie=UTF8&n=165793011&s=toys-and-games or this specialized site about the Kota series. The hasbro contact page is here
Dec 10, 2011 | Hasbro Playskool Kota and Pals Monty T-rex...
My minn kota endura 55 is three years old is making a grinding noise when in operation..
I had this problem with my MinnKota Endura 35. The gear teeth that turn the prop are off center and need to be realigned. You need to take it to a service depot as trying to open the casing yourself may do more damage. Plus when it it put back together you need to ensure that it is water tight again.
Cost me around $85 at the local marine mechanic...
May 22, 2011 | Minn Kota Endura 55 42 In Trolling Motor...
My minn kota 70lb thrust motor is 2 years old. Brand new batteries and it will turn left & right, but the prop will not work.????
Minn kota 74 lbs. prop runs when head turns when rotating motor from centre to right, but stops when you turn motor from centre to left. The light on top stays on.
Aug 30, 2010 | Minn Kota Maxxum 70 Freshwater Bow Mount...
I have to manually turn the prop. to get the Minn Kota electric motor to work. Once it gets going it works fine. What is the cause?
I have an all terrain 70 that would not work intermittently. I disassembled the motor and discovered that the brushes wer hung in the brush housing. The housing is clean and the brushes are in great shape. It appeared that the geometry of the brush spring is just right to make it hang at that prticular position. I freed the spring and could not recreate the problem. Reassembled with new gaskets and seals and all is good.
Jul 05, 2010 | Minn Kota Maxxum Pro 80 Freshwater Transom...
The Simpsons Game on DS.
Climb up the ladder.Make homer stand on the dinosaurs head then swop to bart.Make bart go to the tail and jump of and glide .
Feb 17, 2009 | EA - Electronic Arts The Simpsons Game for...
Speed related whine
Just a possible check is first check your power steering fluid. When it runs low it can make the front end do many weird things. Also check if the front rotors are very warm. If I am correct to understand you have a 96 not a 2002. If so, they have dual piston calipers, which sometimes will hang one piston and apply the brake pad at an angle which will make them drag and wobble the calipers and rotors and give you a rough feel through the wheel. Hope this helps.
Jan 16, 2009 | 2002 Subaru Legacy
Hasbro Playskool Kota and Pals Monty T-rex In Box Dinosaur Logo
137 people viewed this question
Top Hasbro Toys Experts
thegtw
William McDowell
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
