Model Number? Sea Breeze
Looks like 321.231578
Thank you for your post, friend!
To turn your freezer off you should be able to disable power from the control panel or you can disconnect power from your freezer to clean it out.
The compressor on your freezer will continue to run until the temperature has dropped to its setting. The thermostat inside of your freezer should tell the compressor to stop running. If you feel your freezer is running too long you may want to check to make sure the rear is cleaned out buildup of dirt or debris can cause your freezer to overwork. I hope this information is helpful to some degree. -Matt
253.9260210 Kenmore
I need you to turn the defrost timer clockwise untill compressor either starts or stops . If nothing happens that way I want you to feel topof the compressor to see if running or too hot to keep hand there. Then tell me your finding, TKS JT Click=> http://www.repairclinic.com/PartDetail/D...
I did. It's working
