Question about Russound A-h484 4 Zone/4 Source Hub
The power light on the Russound A-H484 doesn't turn on.
The A-PS light turns on.
Russound x75 stopped working wont power on
Check the fuse! Is it plugged in? Is it turned on. Have you read the manual?
Jun 27, 2014 | Russound X75 Amplifier
Computer doesn't reboot after turning off.
You could have a power supply problem. Start up is ******* a ps until it is fully up an running. You may have bulged caps in the power so that takes awhile to full charge up. I would start there. No other reason for it to do that because it runs fine after it gets started.
Jul 21, 2017 | Computers & Internet
If i press the ps button on dualshock 3 controller all four lights on it are supposed to flash but it doesn't therefore the ps3 system cannot be turned on using it
Have you charged it? If you have plugged it in and no lights blink you may have a defective controller. If so check with Sony support/
Oct 05, 2012 | Sony Ps3 Sixaxis Wireless Dual Shock...
Russound CA6.4i zones failing
They should be. I would replace the electrolytics for each of the failed zones. If you do not have a tester, just replace the electrolytics out of hand. The intermittent sound suggests one is likely shorted but not completely or has opened up internally- but not completely.
Sep 21, 2012 | Russound Audio Players & Recorders
Camcorder wont turn on at all
Are the batteries fully charged ?
Jun 17, 2017 | Mitsuba DV777 Camcorder
My Ps3 Wont Turn On It indicates on stand by mode(solid red light).i pressed the power button; it wont turn on and it doesnt work or even beeps. i also tried using the ps button on the contoller.same...
Hi Shiman,
Are you seeing any flashingred/yellow lights?
If so this is the red lighterror and you will find that is why the system will not turn on.
Why Does It Happen?
The GPU and the CPU are the 2 main chips in the system and they deal with allof the number crunching however they can get very hot and if they loseconnection the system will either freeze up or turn off and give you the redflashing light.
How To Fix?
The key is stopping the heat build up and you can either send it in and theywill fix it for you.
Bear in mind that for the PS3red flashing light error you will be waiting for about 4 weeks and itwill also cost you $150 for the repair bill!
Other Ways To Fix?
You can also use a good PS3Repair Guide to fix it and this will show you how to stop the heatbuild up with a few household items.
Just make sure that you get a good guide there are some good ones out there!
Click Here For A CompleteReview Of All Available PS3 Repair Guides.
Hope this helps and any questions let me know?
Aug 13, 2011 | Sony Playstation 3 (PS3) Console
I updated my PS3 because it told me it would not run without and update and now it doesn't recognize the controller... CECHP01 used the latest update 3.66 (it asked for 2.76 or later.)
PS3's will sometimes loose their connection to the controllers. I have always fixed this problem with these steps:
1. Make sure the system is off (red light)
2. plug the control in with the usb cable
3. press the PS button in the middle of the controller (this will let the console relearn the controller)
4. once the lights on the front of the controller are not blinking red anymore, and have a single green light indicating which player the controller has taken, hold the PS button and turn off the system
5. once the system is off, unplug the usb cable
6. the controller should work without the cable now. (check by pressing the PS button to turn the system back on
Controllers will lose their connection to the PS3 when they die completely, during updates, power outages, etc. I don't know what exactly causes it, but I have had to do this process several times since I got my PS3.
Thanks,
John Vickers
Aug 12, 2011 | Sony Playstation 3 (PS3) Console
I have no output on my Russound ca6.4. All lights on console and room controllers appear to function. Input double checked. Could amp be fried?
CA6.4 that has no sound, but all other funtcions are fine, has a problem with protection IC 10 (uPC12370). Check the Cap C28 (2.2uF/50V). If you read any AC
Volatge on that Cap, it means Cap is dry. Replace it with 4.7uF/50V and go back to
your regular duties.
P.S. Since the unit is discontinued, I would love to see basic diagram, available from the manufacturer for download, for easy troubleshooting. I had to spend feew precious minutes to fix that.
May 17, 2011 | Russound CA64IL Amplifier
Tv has been turning off right after you turn it on then after a few attempts it would stay on now the power button on front turns green, it tries to come on but then turns off.
Sounds like high voltage power supply has gone bad. You can try purchasing new PS online and replacing yourself if handy or you will need to bring in for service.
Mar 04, 2011 | RCA HD52W59 HDTV Projection Television
Russound A-h484 4 Zone/4 Source Hub Logo
228 people viewed this question
Top Russound Audio Players & Recorders Experts
Robert Graf
 Grubhead
Grubhead
Gil Shultz
Are you a Russound Audio Player and Recorder Expert? Answer questions, earn points and help others
