Question about Brother MFC-7820N Printer
LCD Panel All of the words have "gone away" on the front LCD panel. Is there a replacement part available or do I work strictly from the Owner's Manual for instructions, settings, etc.?
  • 14 Answers
I have the LCD only for the Brother MFC 7820N. $29.00 with free shipping. Email me at repairguyz2004@gmail.com for detail. Thanks
Posted on Jan 23, 2010
    Champion:
  • 320 Answers
Have tried going in to the menu? there is aplace in the menue that controls the brightness on the lcd pannel. if that will not work you might have to replace the lcd pannel
Posted on Jan 24, 2009
I REGZA 32 lcd tv, will not work for me function.when channel and press the button on the tv, it says panel lock.what problem?
read the owner manual, the book that came with the set--it is telling you the panel or front controls for the set (maybe the remote also) are locked to prevent them being used, there will be a method to unlock them in the owner manual
Nov 04, 2012 | Toshiba Regza 32LV67U 32 in. LCD HDTV
How to replace LCD screen
To replace the the LCD screen of your laptop, You need to be very careful in replacing this screen. Please kindly follow the steps below to be able to guide You in replacing the screen.
  1. Shut down the Acer laptop, unplug the AC power adapter and all extensive devices.
  2. Remove the battery pack from the battery tray that is at the bottom of the screen.
  3. Open the display panel as far as You can open it.
  4. Pry the rubber screw covers from the display panel's front cover with a small, flat-head screwdriver.
  5. The front panel is the front plastic piece covering the LCD screen.
  6. Remove the Phillips-head screws fastening the front cover to the display panel.
  7. Remove the front cover from the laptop with your fingers.
  8. Remove the Phillips-head screws from each side of the LCD screen that fasten the screen to its metal frame inside the display panel.
  9. Tilt the screen forward, then disconnect the large ribbon cable from the connector on the back side of the screen.
  10. Peel away any tape securing the cable in place. Lift the screen out of the display panel.
  11. Place the new screen inside the display panel.
  12. Reconnect the LCD ribbon cable to the back of the new screen.
  13. Align the screw holes on each side of the screen with the screw holes on the metal framing inside the display panel.
  14. Replace the LCD screen's retaining screws.
  15. Replace the display panel's front cover, and its retaining Phillips-head screws.
  16. Then replace the rubber screw covers.
  17. Replace the battery pack, then reconnect all cables and devices to the laptop.
That is how to replace the screen of your phone.
Hope this was helpful. Thank You for using FixYa!!
Jan 12, 2011 | Acer Extensa 5620 Notebook PC
Model No LC-32SB24U. I cant get software update for my television. Please help .
Hello; Contact Sharp for any available upgrades. Most are installed using a USB stick or SD card. A word to the wise: If your set seems to be working OK. STAY AWAY from doing upgrades! Most problems are not due to having upgrades! John
Dec 15, 2010 | Sharp LC-32SB24U 32 in. LCD TV
Get "double vision" after about 20 minutes of operation. Sometimes this goes away and it works fine again, but most times it doesn't. Repairman says its the panel and needs to be replaces, but that part...
Your service repairman is correct. The TCON (Timing Contol) board on the LCD panel is malfunctioning. This TCON board is not available by itself, only with the panel. Unfortunately, you don't have many options here. Best wishes.
Apr 24, 2010 | Sony BRAVIA KDL-52W3000 52 in. LCD...
VERTICAL LINES IN SCREEN
Your LCD panel (the screen you view) has electrical connections all along it's top edge. The lines appear when these electrical connections are broken. You can try carefully squeezing the top of edge were the lines are located. Sometimes this will cause them to momentarily disappear. Regardless, this defect is generally not repairable by any means other than panel replacement. Often the LCD panel will cost nearly as much as the TV. This defect can be caused by impact, but generally it is due to a poor electrical connection and not the fault of the owner.
Mar 14, 2010 | Protron PLTV3250 32 in. LCD Television
I need an owner's manual for samsung 37" 1080p lcd hdtv.
Have you gone to the http://www.samsung.com site and hover on SUPPORT and select DOWNLOADS. Then enter your model and see what manuals are available.
Mar 07, 2010 | Samsung 37 in. Flat-Panel LCD HDTV
Benq FP71G words fuzzy with purple
Hi..there,
Don't bother...you've got a busted panel. If it still under warranty send it back for replacement of panel. If not, then just buy a new one... it's will saved you $$$...
Dec 06, 2008 | BenQ FP71G 17" LCD Monitor
Toshiba rezga 32 " broken
$300-500 replacement cost, installed by a pro, if you find one that doesn't tell you that you can replace the toshiba 720p 32" at a cost of $750(online) or with a toshiba 42" for $999(online). Your call.
Sep 13, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Inverter Problem
I agree with the ASC. Many LCDs have the inverters as an integrated part of the display panel. SOME have the separate, but not many.
Jul 01, 2008 | Televison & Video
Brother MFC-7820N Printer Logo
156 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
