Question about Measuring Tools & Sensors
How do I set the control box and what are typical settings for a Culligan Medallist water softener?
Culligan Medallist Water Softener has an error message E1.
2 Suggested Answers
  • 8 Answers
SOURCE: water softener is inoperative and is displaying E1
Usually, an E1 error code means the circuit board is bad. Try unplugging the unit for 5 minutes. Upon plugging it back in, if it does not reset itself, that means you need a new board. It is really easy to replace ( just a few wires) and will cost around $160.
Posted on Jul 21, 2010
Water softener 1016182
We are going to need more information to assist you. Such as Model type: Gold series, Medallist, Silver, HE etc. and approximate age of unit. This information will either be on the back cover of the control panel or on the inside cover where you found the 1016182#.
RJ
Jul 07, 2014 | Water Dispensing & Filtration
WHERE IS OUR SOFT WATER!? A few years back we had the Culligan man out to check our water because it was not soft (at the time, we had the Culligan Mark 100 model). After testing our water, the suggested...
The most frequent causes for intermittent hard water would be the gallon settings set too low causing the softener to run out of capacity or a meter that is not measuring the gallons. I would set the "hardness" setting on your culligan softener 30% higher than actual hardness. The softening resins they use are low in crosslink and very inefficient. Also make sure there are no toilets leaking causing hard water to "bleed" through softener. Iron filters require regular maintenance to clear oxidized iron from nozzles and the valve. Generally it is better to have the iron filter regenerate at least every 3 days to keep the bed refreshed.
RJ
Mar 01, 2012 | Culligan Sediment Water Filter
Culligan medallist softener will not regenerate unless done manually, not sure how to set different locations. 1 set to present time, 2-2:00 am, 3-10, 4-10, 5-10, 6 is set to 71 degrees, 9 is set to U, 10...
How do you know it is not regenerating? When hard water occurs through system it may still be regenerating but not drawing brine or refilling the salt tank properly. First check to see if it is metering the gallons. Run water and check for the flashing icon. If it is not metering the gallons, the meter is bad, dirty (iron buildup) or the board is bad. Clean the eductor assembly on top of valve (under chrome plate) this may be plugged.
Here is a link to the manual for your medallist softener.
http://www.culligan.com/uploadedFiles/Service_and_Maintenance/Customer_Support/Owners_Guides/Water_Softener_Owner_Guides/Culligan%20Medallist%20Series%20Water%20Softeners%20fr%202007%20%28Rev%20B%29%2001020482.pdf
RJ
Aug 14, 2011 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Need to reset auto timer for back flushing for culligan model # FA-1054 would like online manual
That model # does not work. 10x54 denotes the size of the tank. Is this a Gold Series, Medallist?
Softener, Filter?
RJ
May 30, 2011 | Culligan 34" Whole House Water Filter...
Have a water filter by culligan ..a 01014042 ser # 0703k0196 need a user manual
This is a Medallist series water softener. Her is the link to Culligan for your owners manual.
http://www.culliganwater.com/residential/resources/timers_manuals.php
For future reference it is more helpful to provide the Model and the year it was installed.
RJ
Sep 09, 2010 | Culligan Sediment Water Filter
My Medallist culligan water softener had run for approx. 3 hours without shutting off. The display shows the telephone symbol. I have unplugged the unit but it is still re-generating. What should I do?
You should have a bypas valve or valves at the back of the unit where the water pipes go in and out of the unit...
Shut off and bypass the unit till you can get it fixed...
heatman101
Apr 22, 2010 | Culligan Sediment Water Filter
Water softener is inoperative and is displaying E1
Jan 05, 2010 | Culligan Sediment Water Filter
Measuring Tools & Sensors Logo
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
