Question about GE Ovens
I have a GE Profile built in oven Model PT916SOM1SS. How do I remove the control panel in order to replace the electronics which have gone hay wire?
I un screwed the screws at the bottom of the control panel. I cannot get the control panel off. Is something else holding it on?
Powerman
  • 68 Answers
SOURCE: ge double wall oven repair
You need to tell us the model number. I can then give you specific information.
Posted on Nov 18, 2007
  • 1314 Answers
SOURCE: Jenn-Air JDS9860AAP Control Panel Problem
Control Panel
1. Remove power from unit.
2. Remove burner switch control knobs.
3. Open oven door and remove screws securing control
panel.
4. Remove screws located on the right and left sides of
the control panel.
5. Grasp control panel on the far left and right sides and
gently pull the control panel out and down.
NOTE: Gently pull control panel out and down.
6. Remove infinite switch control knobs, infinite
switches, indicator lights, rocker switches, and
electronic control/clock (as necessary) and transfer to
the new control panel.
7. Reverse procedure to reinstall control panel.
Electronic Control
1. Remove control panel, see “Control Panel”
procedure, steps 1 through 5.
2. Remove screws securing electronic control bracket to
control panel.
3. Label and disconnect terminal wiring from electronic
control.
4. Reverse procedure to reinstall electronic control.try that
Posted on Jan 16, 2008
  • 3 Answers
SOURCE: ge profile oven loc
hey - I figured it out! hold down the 9 and 0 at the same time for 3 seconds! or it might be another combination depending on your oven - it is probably the 2 keys that the messge is under
Yay!
Island2
Posted on Oct 03, 2008
SOURCE: Built in GE wall oven
I have a GE wall oven and the light bulb has burned out. I can't get the cover off to see what size bulb I need. The model number appears to be JkP20BOF1BB.
Posted on Jan 22, 2009
barkencoa
  • 3463 Answers
SOURCE: element needs replacing
You need to remove the outer rear panel of oven to gain access to heater on this model.
The element is attached to a panel at the rear of oven , which when removed gives you access to the element..
It cann ot be done from inside the oven.
Plz rate my solution.
Thanks.
Posted on Jan 24, 2009
Heating element burned out and console dark and
your electronic fuse for the control panel probably opened,to save the electronics it should be on or near the board replace it with the right size/amperage fuse its critical, before doing so do a check of all wires and anything else that looks suspect
Aug 28, 2009 | GE Profile JTP95 Electric Single Oven
Is it easy to replace the keypanel of the GE
Hello, The simple answer is yes it's not too hard...Normally you have a couple of screw located underneath the control panel. In most mordern ovens today they just consist of 2 components, the EOC (Electronic oven control) and the touch pad which basically cosists of everything you see(the whole panel). If you are replacing the touchpad..remove screws holding old panel in...pull wire harness from control board (dont worry where they go because the will only fit in one place) remove tape from EOC and relocate the control board to the new touchpad panel...reattach wire harness and tape in the new touchpad panel and hook back on oven ..screws in and your good to go. if replacing the control board (EOC) drop touch pad panel from oven and pull wires install new control then reassemble..easy!. One thing i would check though before purchasing the part, check to see it is the touchpad and not the control board...Here is how to do it...shut breaker off...pull out control panel...remove ribbon for key pad from EOC the re install panel..go switch breaker back on. leave for 24 hours..if within the 24 hours the error messages come back it's the EOC that is bad, if the error messages do not come back then you can be sure it's the touchpad. I would check this before buying the part since they are expencive and offten non returnable. Good Luck!! If you have any other questions or concerns please feel free to comment again. Thanks for using Fixya!! Mike
Jul 24, 2009 | GE Profile JKP56 Electric Double Oven
I have a GE Profile built in oven and the F7 display with the beeping sound. Clear or cancel will not work What do I do
Well, F7 error code occures due to
A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Replace the ERC there are ten screws 3 on each side and 4 on the control leave the hex screws alone all you need is a phillip screwdriver.
REMEMBER TO SHUT OFF THE POWER FIRST lift and fold out the control panel remove the ribbon cable and remove the four screws that hold the control board . replace control panel in reverse order.
Good Luck!!
Jun 28, 2009 | GE JGRP17 Gas Single Oven
Ge Profile built-in 27 inch wall oven -- When I
f9 means your control panel needs to be replaced..chances are part is not covered and if it is the only way you can obtain it is through having service
Jun 18, 2009 | GE Profile JT912 Electric Single Oven
The F7 code appears with a beeping noise. How do I turn off the beep for good.... selecting clear/off only works for a few seconds
Thanks
May 27, 2009 | GE Built-In 24" Double Electric Wall Oven
F7 error
Good Luck!!
Have a nice Day!!
May 03, 2009 | GE Profile JTP18 Electric Single Oven
Need to find Electronic range control part for my GE Range
http://www.myapstore.com/Omega/Dispatcher?REQUEST=ACCESSORY
After you go to this site it is going to ask you to pick your model number it is JTP56XXXX you can located the rest of the model number and from there you can order the part. Or you can just contact them via phone or internet. But you can order the part right offline
Feb 13, 2009 | GE Profile JTP56 Electric Double Oven
My GE profile oven is giving me a code f7 and I can't clear it.  What does this mean?
Best of luck!!
Thanks
Dec 02, 2008 | GE Profile JTP56 Electric Double Oven
GE wall oven display say F7, Bake and alarm sounds
Good Luck!!
Thanks
Aug 06, 2008 | GE JKP30WMWW 27" Built-in Single Electric...
Ovens Logo
81 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
