Im using ibm think pad but when i turn on blue tooth a note appear that (no local device was detected) what can i do please??
    New Friend:
  • 46 Answers
No need to worry thats just bluetooth looking to pair with other devices but its turned off unless you want to use it leave it as it is you can turn it on by clicking on the notification or via the control panel
Posted on Dec 14, 2012
bijoybakal
  • 57 Answers
SOURCE: blue tooth device is not working
hi,
check if your device is enabled, you can do this by ---
right click my computer..-> properties--> hardware tab--> device manager --> right click on the blue tooth icon and clcik properties. --> check if enabled..
if it is enabled check if bluetooth is enabled at startup { type msconfig in RUN in start menu, click startup tab..check if it is enbaled in startup}... or else you have to manually switch on bluetooth each time u intend to use... hope it helps.
hope to get rated as helpful...
regards
bzoy
Posted on Jan 01, 2008
SOURCE: Conecting Blue tooth phone to acer laptop
Visit this link to download the bluetooth driver http://support.acer-euro.com/drivers/notebook/as_5630.html
Posted on Jan 06, 2008
  • 7 Answers
SOURCE: How do I use blue tooth on my laptop IBM T41?
It depends upon what you mean by "USE".
0. Do you HAVE bluetooth?
- there is a bluetooth light over the keyboard (of course probably not lit)
- there is a bluetooth identifier on the bottom of the laptop
- the FN+5 key brings up a menu of (possibly, wireless) and Bluetooth.
0.1 if NOT then you need to ADD a bluetooth USB adapter
Usage:
1. Use to synchronize a PIM or cell phone or other DATA connection
- This should be fine; you need to solve (0) first (that you HAVE the hardware) then the driver, then have it running
2. Use a bluetooth headset to listen to audio.
- this you can *NOT* do with the default IBM bluetooth stack - I tried, an "audio adapter" for the bluetooth was simply not supplied by IBM. It would require changing to some non-IBM bluetooth stack, and I chose not to do that so never got a bluetooth headset working with my T41.
Posted on Jul 17, 2009
SOURCE: My IBM Think Pad will not boot up when I turn it on.
That's the BIOS password it's asking for. The symbol with the hand in a circle with the line through it is telling you that you've entered an incorrect BIOS password. The system will not boot until you enter the correct one, or manage to reset it through other means (will void any warranties, if applicable).
Posted on Sep 20, 2009
  • 615 Answers
SOURCE: toshiba serial no l300/l300d bluetooth not
Start by going to device manager and system and delete the old driver then download another one for it and shutdown the computer then start again and the computer will read the new driver and hope it will read it, remember you must be in admin mode when you doing this,, let me know if that work if not we go to the next step. Please see that grant me your approvals by rating my service and I hope that I can serve you again the future. I will work with you in this issue to conclusion
Posted on Sep 26, 2009
Bluetooth user manual
If you are using Windows 8.1 .please follow the following instructions.
1.go to the PC settings
2. In Accounts goto PC and Devices
3. In pc and Devices click on Blue tooth
4. In blue tooth Switch on the blue tooth button and wait till your device will appear in the list. Click on the device and click on the pair . A code will appear on both device just click yes on the code windows. you will be able to connect the Devices and now it is ready to share the data.
Sep 13, 2013 | HP Pavilion Computers & Internet
It is not being detected by my new nokia C7
you must make sure you have your blue tooth device turn on to discovery mode most blue tooth devices you just hold the power button for 6 to 10 second when turning on the device,once it is in discovery mode your phone should find it,then you will need a 4 digit pn or pairng code,most blue tooth manufactures use a 4 digit code they are as follows 0000,1234,1111 or 9999 i hope this helps
Feb 21, 2011 | Jabra Radio Communications
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
When i tryto use bluetooth this messages appear "no local bluetooth devise was detect"
If your laptop blue-tooth switch is enabled, then you need a second device with blue-tooth like a phone or laptop in range. Make sure the devices' blue-tooth adapter is switched on.
Dec 13, 2010 | Lenovo 3000 Y410 Notebook
I WOULD LIKE TO SET UP A BLUE TOOTH CONNECTION
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Aug 20, 2010 | LG Shine CU720 Cellular Phone
I go to the bluetooth menu and turn it on. it says "Bluetooth turned on" But the icon fails to appear and file transfer fails.
HOW TOCONNECT BLUETOOTH
Take care.
Aug 16, 2010 | Sony Ericsson K550i Cellular Phone
How to connect a blue tooth with cell phone
Take care.
Aug 08, 2010 | Cell Phones
How to connect sony ericsion w395 via blue tooth
Take care.
Jul 07, 2010 | Sony Ericsson W395i GSM Quadband Phone ...
Bluetooth is not found in the control panel of my laptop
goto start and type bluetooth in search...if bluetooth drivers are installed ull get some icons like bluetooth, bluetooth devices etc.....try clickin bluetooth devices.....n u can try to connect with ur mobile.....if it doesnt show anythin u may have to install bluetooth drivers....hope this helps...
Mar 07, 2010 | Lenovo ThinkPad R61i 14 inch widescreen...
Computers & Internet Logo
David Payne
David Payne
