Question about Kenmore Elite Side By Side Refrigerator - White
My kenmore elite side by side refrigerator isn't cooling properly
The food seemed warm last night so I put a thermometer in and it said 50, i turned it down a notch and this morning it still says 50. I found ice blocking the drain in the freezer and defrosted that, still isn't cooling. Last night I could feel some air coming through the vent at the top of the fridge, this morning I don't feel any.
  • Kenmore Master
  • 4,655 Answers
I need your model number I cannot pull up views without the model number. The number most times looks like 321.654987 Thank You, Sea Breeze
my kenmore elite side by side refrigerator isn' - 12_9_2012_3_01_59_pm.jpgKenmore
Posted on Dec 09, 2012
  • 86 Answers
SOURCE: I have a 7 year old Kenmore Upright
After you taken the back panel off and see a lot of ice forming on the coil before you use your hairdryer you should locate the timer and turn the center of the timer manually into defrost cycle. If you can see or hear the ice melting then your problem is the timer defective. Change the timer and that is all. But if it doesn't do anything then you will need a little bit more on electrical knowledge to deal with the rest on defrost temperature control and the element itself. Hope this help, God Bless.
Posted on Jul 14, 2009
SOURCE: Kenmore Freezer Model 23041
I have an upright freezer which temp was unstable. The coils were frosted up, and the circulating fan was unable to pull air across the cooling fins.I defrosted the unit, cleaned it up, and turned it back on. Worked fine until it frosted up again. The unit was a no frost model. I had to have it serviced, and one of the defrost sensors was bad. No problems since this was fixed.
Posted on Aug 13, 2007
mikedurland
  • 481 Answers
SOURCE: kenmore freezer peeing on my floor
  • if the door was not closed correctly for a while then a lot of condensation will be accumulated on the freezer coils.
  • then when going into defrost it melts this ice/frost and overflows the pan or container under the machine which relies on evaporation to dispel  of the water.
  • empty the pan under the refrigerator if you can, then give it another day, it will get back to normal.
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Posted on Jul 12, 2008
Instant Help
  • 73 Answers
SOURCE: freezer problem
Dear it depends upon the temperature settled, but i think that the problem is with the gas leakage in your freezer, thats why it cooling is geting week, so , it is better to call a mechanic to check it properly.
Best regards
Posted on May 25, 2009
  • 949 Answers
SOURCE: my kenmore 9 upright freezer feels warm on the
This is normal. The condenser coils on freezers are typically located in the walls.
The refrigerator in your kitchen has condenser coils that are hot either under the frig or on the back. Freezers do not need as much heat transfer on the coils with the air so they put them in the walls, it is called a warm wall condenser. It may even feel hot to the touch if you happen to feel it near the end of a cooling cycle. It will be the warmest close to the compressor and cool off at it makes it around the cabinet down to the other side.
Posted on Apr 25, 2010
My kenmore is not pressure sealing
the problem is that the compressor is not working
call a technician for a proper diagnosis
and it is not a pressure sound but a vacuum sound as the door when closed drops the temp inside the unit and that creates a vacuum making the door temporarily hard to open
May 15, 2017 | Kenmore Elite Side By Side Refrigerator -...
Why does it get very hot around the door's perimeter?
The door is heated so it doesn't stick shut with ice. It may be that the condenser is clogged or the fan isn't running, causing excessive heat in the strip. Clean the condenser thoroughly and check the fan.
Jul 01, 2012 | Kenmore Elite Side By Side Refrigerator -...
Kenmore side by side, freezer section is not freezing. Ice is melting. Refrigerator side seems to be working. I do not hear any noise from refrige/freezer.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 21, 2011 | Kenmore Freezers
Mdle 21571 upright Kenmore Freezer seems to run all the time and seems warm to the touch. It is keeping cold but the running all the time doesn't seem right.
heatman101
Sep 02, 2011 | Kenmore Freezers
The red light is on my freezer also the green one the door has not been left open can you help
This means the sensor has determined that the temperature is rising. This can happen if the door was left open (which doesn't appear to be the case with your green light) or an unusual amount of warm food was put into it. If this is not the case you may have a cooling problem. If you can put a thermometer in there and check the temperature, working properly the freezer should be around 0 F. If you have trouble please send the model number from the tag on the freezer. That will help with trouble shooting.
Jun 07, 2011 | Whirlpool 10 cu. ft. / 283 liter Chest...
Not cool enough to freeze the food
Let's start by diagnosing the freezer;
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food.
I hope this helps.
Regards.
May 02, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Wont freeze
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food........
Take care.
Apr 30, 2011 | Turbo Air Freezers
Freezer not freezing .. It's cold..
I hope this helps........
Take care.
Apr 12, 2011 | Northland Panel Ready Upright Built In...
Imperial commercial upright. Top shelf is icing and frezzing bottom is not freezing.
Good luck.
Apr 12, 2011 | Freezers
My whirlpool chest freezer runs but does not freeze?
Best regards.
Apr 07, 2011 | Whirlpool Freezers
Kenmore Elite Side By Side Refrigerator - White Logo
166 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
