Question about Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint WMA56 - Puts holes in washing
We ahve a problem with our Hotpoint WMA56. When my wife puts does a wash, she says that on a regular basis, holes are being put into the clothes in the wash. She is convinced that there is something sharp behind the drum, that occasionally pokes through the holes, and causes damage. She thinks it may be wire from a bra strap, or something similar. I have taken off the top off the washing machine, in an effort to see whether I could examine the drum internally, but there is a two piece plastic casing around it, which look like a big job to take off. Has anyone got any ideas, about the problem, or some tips about stripping down. Look forward to your input, and many thanks.
    President:
  • 1,462 Answers
Could well be a bra wire. the easiest way to check is: remove small cover on rear bottom of machine. you will see the heater on rhs. loosen centre nut and prise heater out. shine a torch down the hole and turn the drum slowly and any foreign object should be apparant
Posted on Jun 11, 2007
Hotpoint aquarius 1300 wma56 not draining. I've taken out the filter and cleaned. Put all back together, did spin cycle - all good. ran a full wash. Now stuck with water in not draining or spinning.
The motor is not reversing direction when it is supposed to pump out the water from the machine. The timer may be the problem or the motor itself.
Apr 26, 2016 | Hotpoint Washing Machines
Froth coming up my washing machine
I would imagine that either you have accidentally put to make washing power in or there has been a back log of washing power which has added to the load. Put the washing machine through a cycle with nothing in it and clear out the pipes with may be some calgon. It should work. Good luck
SH
Apr 10, 2013 | Hotpoint Washing Machines
Hi, my Hotpoint Aquarius wma56 washes, but drum wont spin in rinse and wont spin...any advice?
you need to check/clear filter, its located within sump hose @ bottom of drum quite trickey clip to remove slide it to the side to assist then withdraw nylon filter and clear.
Jun 10, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
Can you help? we have a hotpoint aquirius 1100 waher, the drum seal seems to keep getting dirty, wife keeps machine spotless and allways cleans seal, but constantly gets brown scum going onto washing and...
hi my trick is .................... WHITE VINAGER ...YES VINAGER ... right get 5 ltrs of white not brown or your cloths will STINK :))) now wip some around seal .... tip 2 ltrs into drum ...and rest into powder capartment .... leave for 5 min ...then put on boil wash ...DONT PUT ANY THING ELS IN ..IE CLOTHS OR POWDER.. it normally gose .. wash through x2 times with powder ect b4 any cloths go in . bsc appliances bristol 07779933829 postal service too.
Feb 26, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
Is there a filter on a wma56 washing machine, if so where is it
The filter is located at the rear of the washer, to gain access to it, remove the lower rear panel of washer.
Remove large black hose from bottom of drum, and remove and clean plastic filter inside the hose.
Refit filter and hose, and test .
May 04, 2010 | Hotpoint Aquarius WMA56 Front Load Washer
Leaking water from door during spin
Most likely door seal, check all around the seal, as often very small holes are missed, then they open up during spin
Mar 09, 2010 | Hotpoint Aquarius WMA56 Front Load Washer
Finding an instruction manual for a Hotpoint WMA56
Click on the link below to download instructions manual for your appliance:
INSTRUCTIONS FOR INSTALLATION & USE for the AQUARIUS RANGE WMA56
Do not forget to rate the solution.
Thanks.
Mar 02, 2009 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint Aquarius WMA56 wont drain properly water leaking onto floor
pump is working water is only a trickle coming out so wont final spin
Nov 07, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint Aquarius WMA56 Front Load Washer Logo
158 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
