Question about Vizio Televison & Video
How to turn off hdmi-cec setting on a vizio m3d650sl tv
Need to find out how to turn off hdmi-cec setting
5 Suggested Answers
SOURCE: Philips TV HDMI CEC EasyLink tries to control Cable set top box
I finally found a fix to this! YAY. I thought I might have to return the TV. I have the Phillips 42PFL5603D, but should work for other models.
On the TV press menu picture settings---picture---dynamic contrast (turn off) AND active control, turn off
If you have Comcast Moto box: on the Cable box go menu--->setup--->cablebox set up---RF BYbass set to ON
If you have a non-Comcast Moto Box, I'm sure there is an RF bypass setting in the menu. You'll just have to look for it. Another fix was close saying to only turn of the active control, but it took all 3 of these for it to work consistently. The latter let it work for all of 30 seconds.
Posted on Mar 13, 2009
budmrtn
  • 11361 Answers
SOURCE: Tv comes on but turns itself off immediately. What
It may have gone into shutdown becuase it senses short circuits, or the power supply module may have failed. You need to do some reading and troubleshooting.
Right now the 5vdc standby and partial processor are working but nothing else.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Please post back what you find.
Posted on Jul 31, 2010
  • 56 Answers
SOURCE: vizio vf550m hdmi port problem
What did you do exactly?
Posted on Nov 18, 2011
gopakumarg43
  • 75581 Answers
SOURCE: magnavox LCD tv external speaker
Hello
The jack you describes here "Digital Ouput Device To" means, you can connect these jacks to the output of a digital device, such as DVD or so. It is meant for to get signal into the TV, not ot out.
HDMI [High Definition Multimedia Interface] is a type of connection, which the TV an be connected to any HDMI device from outside. Both the above said are, signal in to TV connections. Not out.
If you want to connect this TV to any amp or any other external audio devices; look for any audio out option is there.
Posted on Feb 05, 2012
How can I control a vizio blue ray player without the remote?
If you are connected to the tv with hdmi cable theres a good chance the tv has a setting called hdmi cec. if you click on that the tv will take over control of the blueray and the tv remote will operate it using the xtra keypad with usual play,ff,rew buttons.
Aug 16, 2017 | Vizio Televison & Video
Vizio LED TV E48-C2 keeps turning on by itself.
Turn it off and on using the power point. You will also save power as equipment still uses power in standby mode.
Aug 01, 2016 | Vizio Televison & Video
How do the hmi on tv withe control
How to Enable HDMI-CEC on Your TV, and Why You Should
www.howtogeek.com/.../how-to-enable-hdmi-cec-on-your-tv-and-why-...
Jan 16, 2015 - The devices can have some control over the TV, and the TV can have some control over ... AOC: E-link; Hitachi: HDMI-CEC (Thank you, Hitachi!) ...
How to find out if your device is HDMI CEC capable?
hdmicec.blogspot.com/.../how-to-find-out-if-your-device-is-hdmi.html
May 18, 2012 - Hitachi - HDMI-CEC ... You can control your computer with your TV'sremote control and you can set up that your laptop shuts down or goes to ...
[PDF]OG S606 U516 Eng - Hitachi Service
Dec 26, 2015 | Hitachi Gst Hitachi 46" Class LED-LCD...
Why does it turn on, then off?
"HDMI-CEC", short for HDMI Consumer Electronics Control, is an HDMI feature many TVs and peripherals have.
If the TV is connected to an HDMI or a programmed remote is being used on the cable box the TV may be getting a second command via the HDMI cable.(CEC) Suggest disconnecting the HDMI cable and manually turning on the TV and see if it will remain on with just a blue screen, Try changing the input to antenna-DVD etc and see if the TV remains on.
You may need to check the settings in the cable box or DVD to change the auto control(CEC) feature. Or if you prefer controlling the TV via the cable box remote then you would not use the TV remote for turning on and off.
This can get very confusing because the TV and the DVD or the TV and the cable box will interact between each other. The problem can be more confusing if the components are not exactly compatible with the CEC. Also many remotes have the additional feature of controlling other components in your AV setup. Many times the operation is alternate action. So each cycle of the remote the TV changes state from on to off. If the two components are out of sync than one is on and the other is off. In that case not using the master on off of the remote but using the individual component setting allows for the two to be sync again. (both off or both on)
Nov 15, 2015 | Sanyo Televison & Video
Is my Sony Grand Wega Consumer Electronics Control (CEC) compatible?
Consumer Electronics Control (CEC) What is Consumer Electronics Control (CEC)?
Consumer Electronics Control or CEC is a function that allows you to control multiple devices over HDMI using one remote control by having a secondary device receive commands from a primary device. Although CEC wiring is required for every HDMI port it does not mean that every HDMI port will have the function enabled.
If your device has the CEC function, this information will be located under your setup or settings menu.
To enable the function you will need to turn the CEC function on and then search for any devices that are CEC enabled that are connected to the TV.
Was this article helpful? 2 out of 4 found this helpful Have more questions? Submit a request
Related articles
Jun 13, 2015 | Sony Grand WEGA KDF-50WE655 50" Rear...
Is there an option to turn off cec. So I can use ir control .
Go into the menu on your device. Look for HDMI settings. There is normally an option to turn off HDMI CEC. A lot of manufacturers have their own name for CEC, so you may have dig a little to find it.
Feb 14, 2015 | Televison & Video
Why wont the tv pick up any HDMI input?
Hello. CEC stands for Consumer Electronics Control. This allows you to use one remote control to operate multiple devices that are connected with the HDMI cables. Since all of the equipment worked before the power surge, it is very likely it will work again. We just need to "reset" everything.
Start by unplugging all devices from AC power and disconnecting the HDMI cables. Assuming you are using the TV remote to control everything, pug the TV back into AC Power and turn it on. Go thru all standard setup on the TV as needed (set date and time, scan for channels, etc). Turn the TV off.
Connect the first HDMI device to AC Power, connect the HDMI cable and then turn on the TV and the HDMI device. Check to see if the remote controls both devices. If it does not, go thru the Setup options on the HDMI device (you may need to use the original remote control) and see if there are any settings that apply to the HDMI CEC settings (enbable or turn them on).
Repeat this for additional HDMI devices.
By unplugging both the controlling device (TV) and the controlled device (such as a Bluray/DVD player) and then reconnecting them in the correct order, you should be able to get all devices working on the same remote again.
Sep 03, 2014 | Insignia IS-LCDTV32 32 in. Television
Is there a way to turn off the TV and hear music. I have tried but every time I turn off the TV the receiver goes off
What is the source of your music? And how it is connected to the receiver? If via HDMI, then it is not possible. Source HDMI device will not put any audio into the HDMI when the display device is not turned on (it must authentificate with the TV to be sure you are not doing any unauthorized copying).
If your only issue is that when you turn off TV it turns off the receiver, then turn on the receiver only after you have turned off the TV. If this causes the TV to turn on also, you have HDMI CEC enabled. HDMI CEC enabled devices to communicate with each other via HDMI - receiver can tell TV to turn on/off. You can disable the HDMI CEC support in receiver menu if you want. After that, your TV and receiver will turn on/off independently of each other.
Aug 30, 2014 | Yamaha RX-A810 Aventage Audio video AV...
Yamaha purple screen rx-v373
I had this same issue. I think I finally resolved the issue by turning off HDMI Control (HDMI-CEC) on my Blu-Ray player. I had the Blu-Ray player plugged into a Yamaha RX-V375 (almost an identical receiver). I think the source of the issue was that my TV does not not support HDMI-CEC. Turning off HDMI-CEC on the Blu-Ray player fixed the issue. The Yamaha receiver already had HDMI Control disabled, and all the other HDMI devices appeared to have HDMI-CEC disabled or not supported.
In my case, the symptoms of the issue were that I would see the correct picture for a second on power up, then the picture would go away. For the Blu-Ray HDMI input selected on the receiver, I would see a solid purple screen and a blank screen for the rest of the inputs. Sometimes switching inputs fixed the issue, sometimes power cycling would fix it, but it was getting very annoying.
Dec 03, 2012 | Yamaha Audio Players & Recorders
HD Video Recorder - CEC connection with HDTV
My first question would be, Is your Panasonic HD recorder CEC compliant? CEC means Consumer Electronics Control. That simply allows for the consumer to have better control over their Home Theater set up through the connection of you HDMI cable from their remote control without programing the remote control for every single device that is connected. If your recorder is CEC compliant the television should have automatically recognize the recorder and control you recorder via remote control (I am assuming that your recorder is an HD Camcorder, since your description was very vague). Once you connect your HD camcorder to your panasonic tv the tv should have turned on switching to the correct input and the same for any other CEC comliant devices. If your Panasonic HD recorder is not CEC compliant the you would have to start viewing your recorder the old fashion way, by using the recorder remote control or if your Toshiba remote is universal punch those codes in so that you can control your devices that way. If that don't work, try a different HDMI input and select the input and make sure your recorder is set to output on you tv. Hope this helps.....before I forget, check out this site to learn more about Consumer Electronics Control (CEC) http://www.videsignline.com/howto/207400325
Nov 23, 2008 | Televison & Video
Televison & Video Logo
225 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
