Question about Maytag MAH9700AWM Neptune Front Load Washer
No lights on control board, door locked, MAH9700
Had an E2 code, unplugged unite..code went out..seemed to work fine. Now no lights on board and door locked with cloths in machine.
    Top Expert:
  • Maytag Master
  • 9,472 Answers
Unfortunately the control board is dead and will need to be replaced. Here is the board to order if you decide to order it.
The E2 error code was for a stuck button and it would require the control board to be replaced also.
Posted on Dec 08, 2012
  • 116 Answers
SOURCE: MAH4000AWW Maytag Washer
It is best to contact Maytag at the 1-800 number listed in your owner's manual (or on your machine's serial tag) to see of there is anything that they will do for you. It is best to call rather than use the on-line contact information as they may set up an appointment with an authorized servicer in your area for you.
If not there are a number of options from a Maytag authorized repair to a do it yourself kit which is available from. http://www.neptunewaxmotor.com/
I am not affiliated with the makers of this kit and it will not help most people that are not technically adept. There are pictures on the website showing the disassembly and repair procedure.
Posted on Aug 05, 2008
Master_Tech
  • 770 Answers
SOURCE: control board
have you the touch onsole first to se if it was ok there have been more problems with tha then the cpu board? do you get any beeps while touching it??
Posted on Aug 23, 2008
SOURCE: Maytag Neptune - door locked, clothes inside, lights are on
The manual says that you should push the on/off button to turn off the machin. Wait for 2 minutes for the door to unlock. Then open the washer door.
Audioguy4
Posted on Oct 04, 2008
SearsTechToo
  • 261 Answers
SOURCE: CANNOT RESET E2 ERROR CODE TRYED UNPLUGGING DID NOT WORK
I have only worked on USA machines but I believe you have a control panel error.
Posted on Oct 15, 2008
SOURCE: My Neptune washer MAH9700
I have a Maytag Neptune MAH 9700. It died one day and the door remained locked. I am guessing the circuit board is fried so it's a good thing I purchased a five year extended warranty. The problem though, is that my 2 year olds BLANKY was in there and she won't go to bed without it. Can't wait 2 weeks for the repair guy. I was able to remove the top and (after I unplugged it of course) get my hand to the bottom of the switch housing. Seems there is a small opening at the bottom. I pressed up with my finger and was able to get the door opened. Whew!!! Hope this helps. ; )
Posted on Jun 19, 2009
I have an akira washing machine. problem is that when it comes to spin...E2 will appear. what is the problem n how to fix it? thank you.
E2 is a faulty button on your control board. Rub your hands over the buttons to make sure none of them are stuck and if you find nothing, try to unplug the unit for 60 seconds. If you continue to have issues, the control board will just need to be ordered and replaced to fix the issue. Here is also a link for the manual. Akira Service manual Home Appliance Washing Machine Always get a quote for motherboards as they vary alot in price and can sometimes be more then what the machine is worth.
Mar 16, 2014 | Washing Machines
Door won't unlock
try the cancel button it will drain the water and release the lock
May 30, 2009 | Maytag Neptune MAH9700 Front Load Washer
Whirlpool Duet will not work
Hi, you could have a control fault here or a door lock mechanism failure as well. the best way to find out if its ether the control or the door lock that may be faulty, is to unplug the unit for 5 minutes. this will drain all power from the control board, in return, resetting the program.
After the five minutes are up, simply switch your circuit breaker to the on position or plug the unit back in. If the control is working correctly, you should see a error code that says FdL(Failed door lock). If the control simply continues to malfunction like it was previously, this will confirm a major fault within the control board(microcomputer).
In this case, you will have to replace the control board in this unit. Remember, after the reset, power up the unit and watch the led and control panel carefully for any error codes. if the error code display is not functional, it will confirm control failure.
If you get an error code(FdL), check the wiring harness that connect the door lock mechanism to the control board. make sure they are in good condition and not lose. if the wires are ok, replace the door lock mech.
Please rate and god bless:)
May 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Front load washer won't turn on
did you try unplugging the unit for at least 10 minutes?
Mar 23, 2009 | Maytag Neptune MAH9700 Front Load Washer
E2 -F 1- MESSAGE APPEARS ON MY DISPLAY
F1 = analog to digital failure. unplug the unit for 30 seconds if the clock does not reset replace the control board.
E2 = Check Door / Switch. Replace door switch if defective.
Repairclinic.com has the parts that you will need.
Feb 20, 2009 | Whirlpool GR465LXLS Electric Kitchen Range
Whirlpool Electric Oven RBS305 overheats while baking, locks door
The technical manual for your range doesn't show an error code of E2 F2 but all of the F2 codes pertain to the touchpad of the range.
Can you clear the E2 F3 by pressing the cancel button? If not, shut off the power to the range for a few minutes and see if the error code goes away. If the error code remains You should unplug the range from the wall and remove the back panel for the control area. Disconnect the ribbon between the touchpad and the electronic control, clean the end of it and reconnect it.
If this doesn't repair the problem you will need to replace the touchpad on the range. The parts diagram lists two touchpads, they are part numbers 8273575- bisque, and 8272702- white.
Good luck
Dec 18, 2008 | Kitchen Ranges
Random electrical problems, sometimes it works beautifully, sometimes not!
F11 = Communication between the Central Control Unit (CCU) and the
Motor Control Unit (MCU) cannot be sent correctly.
1. Unplug washer or disconnect power.
2. Check wire harness connections to the MCU, the motor, and
Central Control Unit (CCU).
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic test or any
cycle.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
8. Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing the
MCU connectors.
FDL=
A Door Lock Error occurs if the door cannot be locked. It will try to lock
it six times before displaying the error code.
Le code d’erreur “Verrouillage porte” apparaît s’il n’est pas possible de verrouiller la
porte. Le système effectue six tentatives de verrouillage avant d’afficher le code d’erreur.
■ Door lock mechanism is broken or removed from door.
■ Door switch/lock unit failure.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door
switch/lock unit and Central Control Unit (CCU).
Feb 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire GLTF2940ES0
remove the bottom panel will find a tech sheet there with more specific instructions and the speed control bd is under the tub on the left hand side unplugged the unit before checking and the door lock is part of the com system turn the washer and see if the door lock light comes on try to open the door with the light on if you can that's where the problem is
Jan 16, 2008 | Frigidaire GLTF2940ES Front Load Washer
Jan 10, 2008 | Maytag Neptune MAH9700 Front Load Washer
Washing Machines Logo
175 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
