Question about GE Advantium 120 Convection/Microwave Oven
WB15X10082 REPLACEMENT how do i access the bottom screw on the inside of the door? there is a plate blocking the screw.
  • GE Master
  • 9,047 Answers
The service manual is here. That will help you in disassembly and reassembly.
Posted on Dec 12, 2012
3 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: GE profile mirowave JVM1350WW002. Handle broken
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can find handy exploded views and order parts by model number here.
Posted on Oct 11, 2009
Whispis2
  • 192 Answers
SOURCE: ughes.netI have a GE Spacesaver
Mike,
Found the diagram HERE and HERE and also has a parts listing you can order.
Hope this helps with you project.
Posted on Mar 26, 2011
Turntable is not turnig
Check to see if your control panel has an on/off button for turntable and make sure its not off. If it still doesn't turn then the little drive motor may be bad. It can be accessed through the bottom of the microwave, usually through a small access door on counter top micros and by removing all screws around the bottom plate of over the range microwaves and allowing the bottom plate to hinge down. Unplug power before attempting this repair.
Mar 31, 2015 | Microwave Ovens
Cannot access screw for lower part of handle blocked by interior assembly
The inside of the door must come apart. Be careful that screen inside the door is actually a choke to keep the microwave radiation in. Make sure that you replace each and every screw and everything else just as you took it apart.
Good luck
Dec 13, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
The door handle on my microwave broke off at bottom of the door. The screws holding the handle on are not visible from the back of the door. How do I access the screws to replace the handle. GE Profile...
The back of the door will have a moulded surround that will be fixed with allen heads or small screws. Remove the inside cover of the door and you will see the holes for the handle.
Jul 03, 2010 | KitchenAid KBMS1454RSS Microwave Oven
Light replacement
Hi, Remove the 2 screws in the grille, the grille pulls straight out (with the door open is a little easier). Then above the light is a cover plate which is removed by the two screws on the plastic frame. You will see a little tab that allows you to lift that cover plate out gaining access to that bulb. As always you should be safe and turn off the power before you repair any electrical device. Good Luck!
Feb 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microvent is coming loose on the bottom of mounting.
Generally, these units are held to a backing plate with a pair of screws that are accessed by removing the vent plate above the door. There are a couple of Philips screws. Inside...at each end, there is a slot head screw head on a rod. Support the unit and back these screws out. The unit will then pivot from the bottom away from the wall. Detach it and then repair the issues with the hold bracket. Warning: these units are heavy!
Dec 31, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave door tension spring
See answer here http://www.fixya.com/support/t265705-microwave_door
in different thread.. Basically have to pry plastic trim ring off inside of door with putty knife (careful, it cracks easily) to get to screws on bottom of door. See second pic. Top screws are easily accessible from inside of door. Spring can easily be replaced by hand once you get adequate access. You'll need a fairly stubby right angle screwdriver (I used a cut-down #2 Phillips bit and small Vice-Grips as a make-do) to get to the screws. Also need Torx (T10, I think) to detach the shock absorber doodads from the door where they attach above the hinges. If you're just starting to take the door apart, be careful when you take out the top 2 screws on the inside-- they hold the inside plastic piece on , but they also hold the whole outer stainless/ glass/ handle piece on. It just slips in at the bottom, so be ready to slide it out when you take these screws out.fea33aa.pngc391898.jpg
Dec 16, 2008 | KitchenAid KEMC377K Convection / Microwave...
Microwave Oven Door Handle Replacement
You shoul take off the hole door, use something like a flat screw driver and wedge the plate off.
some of the mics got tamper holes where it hooks in.
Hope it works...
Sep 09, 2008 | Whirlpool MH7155XM Microwave Oven
Microwave handle replacement
How to replace handle on GE Advantium SCA1001DSS.
Remove two screws on top at front in order to remove plastic front vent grill. Then the door lifts off pin hinges. Lay door flat on surface. Plastic trim snaps off with gentle prying (start at bottom middle and bottom hinge side). Then remove six screws holding notched metal section with door latch. This piece will also snap out (several visible clips holding it around edges). Then remove door handle screws, Replace handle and reverse process to put back together.
Jul 29, 2008 | Microwave Ovens
Fixing Microwave door handle
pop the plastic off inside door you will see 2 screws that hold handle on or if your trying to get the door hinges off unscrew bottom panel to access bottom hinge screw and vent at top to access screws for top hinge
Aug 30, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Advantium 120 Convection/Microwave Oven Logo
129 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
