Question about Vizio Televison & Video
How to turn off hdmi-cec setting on a vizio m3d650sl tv
Harmony remote will not change input setting when going from watch tv to watch movie. logitech says to turn off hdmi-cec
2 Suggested Answers
phil_frye
  • 295 Answers
SOURCE: My Logitech Harmony does not move my Toshiba TV between inputs
It all depends on the Logitech remote's Harmony features. Can it you place your original Toshiba remote IR sensor up to the IR sensor on your Logitech and learn from the Toshiba remote?
Posted on Nov 19, 2009
Why does it turn on, then off?
"HDMI-CEC", short for HDMI Consumer Electronics Control, is an HDMI feature many TVs and peripherals have.
If the TV is connected to an HDMI or a programmed remote is being used on the cable box the TV may be getting a second command via the HDMI cable.(CEC) Suggest disconnecting the HDMI cable and manually turning on the TV and see if it will remain on with just a blue screen, Try changing the input to antenna-DVD etc and see if the TV remains on.
You may need to check the settings in the cable box or DVD to change the auto control(CEC) feature. Or if you prefer controlling the TV via the cable box remote then you would not use the TV remote for turning on and off.
This can get very confusing because the TV and the DVD or the TV and the cable box will interact between each other. The problem can be more confusing if the components are not exactly compatible with the CEC. Also many remotes have the additional feature of controlling other components in your AV setup. Many times the operation is alternate action. So each cycle of the remote the TV changes state from on to off. If the two components are out of sync than one is on and the other is off. In that case not using the master on off of the remote but using the individual component setting allows for the two to be sync again. (both off or both on)
Nov 15, 2015 | Sanyo Televison & Video
Why wont the tv pick up any HDMI input?
Hello. CEC stands for Consumer Electronics Control. This allows you to use one remote control to operate multiple devices that are connected with the HDMI cables. Since all of the equipment worked before the power surge, it is very likely it will work again. We just need to "reset" everything.
Start by unplugging all devices from AC power and disconnecting the HDMI cables. Assuming you are using the TV remote to control everything, pug the TV back into AC Power and turn it on. Go thru all standard setup on the TV as needed (set date and time, scan for channels, etc). Turn the TV off.
Connect the first HDMI device to AC Power, connect the HDMI cable and then turn on the TV and the HDMI device. Check to see if the remote controls both devices. If it does not, go thru the Setup options on the HDMI device (you may need to use the original remote control) and see if there are any settings that apply to the HDMI CEC settings (enbable or turn them on).
Repeat this for additional HDMI devices.
By unplugging both the controlling device (TV) and the controlled device (such as a Bluray/DVD player) and then reconnecting them in the correct order, you should be able to get all devices working on the same remote again.
Sep 03, 2014 | Insignia IS-LCDTV32 32 in. Television
I have problems having the Logitech One to choose right input on my SonyKDL-32EX501. It changes between HDMI 1, Analog and AV1, and ignores other active ports. Have to use Help every time in order to...
If HELP fixes the problem, then this is a delay issue. Try increasing your TV's input and inter-device delays.
1. Click 'Settings' next to the icong for your TV in the software.
2. Select 'Adjust the delays (speed settings)'
Apr 26, 2010 | Logitech Harmony One Advanced Universal...
When powering on using the harmony 670 remote, it changes the input type from HDMI to cable
You probably have the input selected to cable for the Activity that you are using.
In the software, click 'Settings' beside your activity then click 'Review the settings for this Activity'. Then, go through the setup wizard and make sure the input for the Activity is selected as 'HDMI'.
Apr 01, 2010 | Logitech Harmony 550 Remote Control
When I switch from watching movie to watch TV on my Harmony 700 I get a picture on the TV that looks like the menu for the AV receiver and can't get back to a TV picture although I do have sound. I...
Hi, I would like you to try changing the input selection method for your TV. I suspect that some of the commands are incorrect.
1. In the software, click 'Settings' next to the icon for your TV.
2. Click 'Adjust Inputs'.
Make sure you select the method that best describes how the original remote changes inputs. Dont pay attention to the brand names. Also, make sure that the input list is EXACTLY the same in the software as on the TV itself.
Once you have done all of the input setup, update the remote and try it out again.
Let me know if that helps :)
Feb 01, 2010 | Logitech Harmony 700 LCD Remote Control
Samsung PN58b530 tv and harmony 550. When setup have all devices set except when the tv turns on it stays on one hdmi setup then jumps to another that was not programmed.
Samsung TV's have Anynet automatic input switching. This severely conflicts with the Harmony Remote as they both do the same jobs; Switch inputs automatically. We would like for you to disable this feature on your Samsung TV using your original remote, so the Harmony Remote will work properly.
Disable Samsung Anynet+
1. Press your Tools Button.
2. Scroll down to Anynet and press your Select Button.
3. Once on the Anynet screen, please press your Left/Right Button(s) to select the Off Setting on the Anynet+ (HDMI-CEC)
4. Scroll down to the Auto Turn Off and select No.
Once this is completed, please turn off your TV and all device and power them back on using the Harmony Remote.
Feb 01, 2010 | Logitech Harmony 550 Remote Control
Nov 19, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Television input doesn't always match activity
Depending on the type of tv you may need to count the TV tuner as an input. My bro-in-law had the same problem. The TV has 5 inputs (S-video, HDMI, etc) but when you set up the remote you need to tell the remote you have 6 inputs, one for the TV tuner.
I hope that helps.
Mar 09, 2009 | Logitech Harmony 880 LCD Remote Control
Abilities of Universal Remotes
Yes!
When you define different activities (such as Watch TV, Watch DVD, etc.) the remote will ask which of the TV inputs your device is plugged into.  After programming, when you select the appropriate activity, the remote will automatically select the correct input.
Jan 02, 2009 | Logitech Harmony 890 LCD Remote Control
Televison & Video Logo
83 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
