Question about Tablets & eReaders
My tablet works only when the charger is connected if i disconnected the charger the tablet off,what can i do?what is the problem?
  • 2,072 Answers
The charger powers the tablet while it charges the battery. I would say the battery is defective or isn't connected properly. I'd recommend returning it. Opening them usually voids the warranty.
Posted on Dec 08, 2012
How can you fix tablet won't turn on or charge at all. It connects to laptop then quickly disconnects.
It may be the charger not connecting properly with the port on ur tablet what kind is it
Aug 29, 2015 | Tablets & eReaders
Visual Land 10in Tablet will not turn on after charging
If the tablet works while plugged-in to the charger, yet dies immediately when the charger is disconnected, it means that the rechargeable battery in the tablet is dead.
If the unit will not turn on at all, even with the charger attached, the charger itself may have failed, or the unit may be having other issues.
May 15, 2015 | Tablets & eReaders
I turn my tablet on then it switches it self off
Sounds like it does not have enough battery power to stay on. If you have not tried to charge it, you should try that first. If you have, it sounds like it is not getting charged or not holding a charge. Could be bad AC power source, bad charger, bad charger connection or bad battery. Take steps to confirm that each of these are good. If all of these are good, sometimes the tablet can become so discharged that it will not allow itself to charge. When they are in that state, sometimes you can trick them into charging again by repeatedly disconnecting and reconnecting the charger as follows: With charger plugged in to AC power source, connect the charger to the tablet. Pay attention to the screen or LED or whatever indicator your tablet has to let you know it is charging. You may see it momentarily indicate charging, or maybe not at all. Then unplug the charger from the tablet then immediately plug it back in and pay attention for the charge indication again. You may have to do this a bunch of times (like 20) until you see the indication that it is charging. When you do get the indication, stop unplugging and re-plugging and let the tablet charge for 24 hours (to a full charge). This trick doesn't always work. Sometimes the battery or charging circuit or an internal connection is bad and no amount of unplugging/re-plugging will fix a hardware problem.
Nov 17, 2014 | Tablets & eReaders
My tablet will not turn on and i dont know why? what do i do?
charge the battery.or connect the charger and after 5 minutes, turn it on without disconnecting the charger
Oct 16, 2014 | Tablets & eReaders
My Samsung Galaxy 3 Tablet wont charge
Have you tried a different charging cable?
Did you allow the battery to run down until it was completely drained?
- If so then try the following;
Watch this video (link below). You should only remove the back cover, disconnect and reconnect battery cable. Disregard the rest of the video as I could not find one doing ONLY what you would need to do. Follow the instructions to remove the back of the tablet then disconnect the battery cable(careful not to damage the circuit board), reconnect the battery cable, and replace the back cover. Connect the charger, within a minute the screen on the tablet will pulse/flicker which is good news, allow it to charge a while, turn on the device, turn off the wireless wifi, click the power button to turn the screen dark again, and allow to charge for another 6 hours or till fully charged (when not connected to wifi the background processes will affect the charge time, on a weak charger it may not even charge like from an usb port on a computer).
Again, you should only be concerned with the video up to about the 1 minute and 15 second mark. You only need to disconnect the cable then reattach it. ONLY DO SO if you are comfortable doing so. If you have never worked on electronics before or are uncomfortable find someone to do it for you.
Galaxy Tab 3 Battery Replacement and Screen Repair Disassemble and fix
Aug 01, 2014 | Samsung Galaxy Tab on 3 Mobile Tablet PC
Coby Kryos Android Tablet is not charging. It is connected to a charger but its not charging.
Leave the tablet connected to the charger for 5-10 minutes even if doesn\'t work. Then take out the battery and try with master charger and (switch on the tablet) after that, check whether the previous charger is working again or not again. If it doesn\'t show charging sign, then you have to take it to service center to change the charger connector.
May 21, 2013 | Tablets & eReaders
The tablet cannot work only it connected to the charger i buy allwinner tablet a13 many tablet and i will buy more to sell it in my country but one of my costumer have a problem he take the tablet before 3...
Some tablets have that problem,I bought a 7" tablet pc too,but it is working good when charging,RK3066 CPU,Mali-400 GPU,1G/8G,WIFI,HDMI,it performs good as samsung N9100,here's the link for you reference,http://www.aliexpress.com/store/product/7-inch-Teclast-P76A-Daul-Core-Tablet-PC-G-G-Screen-Android-4-1-RK3066-1/817920_761078901.html
Nov 14, 2012 | Tablets & eReaders
Tablets & eReaders Logo
272 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
