Question about GE JVM1631 Microwave Oven
How to replace the outer glass on a ge microwave
2 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: Glass Tray replacement needed
Those model numbers are not correct. That's likely why you're having trouble.
For model number JVM1790SK01, the part number is WB49X10114.
That's available here.
Posted on Mar 06, 2009
Help need replace glass panel in pvc
This door is radius and would be difficult to replace. Repair clinic claims the part is due in at the end of this month, I wish you luck on your search. I have not seen someone make this correctly as the metal supports at the bottom are attached to the glass and the stainless steel outer panel is just a panel stuck to glass.
Good luck
Feb 05, 2014 | Jenn-Air Microwave Ovens
The glass turntable broke. Where can I find a replacement?
Go to www.ebay.com Type: make and model of microwave, and refine search to glass plate.
Apr 02, 2012 | GE Spacemaker JVM1540 Microwave Oven
There are condensation, water drips between the glass on the door of my over the counter microwave/convection oven. Is this a problem? How can I clean this? Microwave is only 6 months old.
HELLO.
Yes.Water can only drip between the glass on the door when the door do not seal properly due to dirt on the microwave door.follow these steps given below to clean the door.
1. Unplug the microwave from the electrical outlet to prevent electrocution. Place the microwave in a well-lit area to be able to locate the fuse.
2. Use a screwdriver to remove the outer cabinet of the microwave, and follow the power cord to the fuse. The fuse is located 2 to 3 inches within the microwave and is attached to the power board.
3. Observe the fuse to determine if it is blown. Blown glass fuses will produce burn marks on nearby surfaces, or the internal fuse wire will be black and melted, while ceramic fuses show no outward appearance of being blown.
4. Determine if a ceramic fuse is blown by testing it with an ohmmeter. If the ohmmeter reads zero ohms, your fuse is not blown. Other readings on the ohmmeter show that your fuse is blown.
5. Replace the blown fuse by popping it out of its holder, and snapping a new fuse in its place. Tighten the fuse clips by squeezing them together with your fingers.
6. Replace the outer cabinet of the microwave, and plug the microwave back into the electrical outlet. Test the microwave to see if it's working properly.
Thanks.
Sep 17, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Mmi have a ge advantiun x20 model SCA1001FSS01 THE HNDLE IS BROKEN OFF HOW DO i REPLACE THIS pafife@yahoo.com
HELLO.
THE SOLUTION ON HOW TO REPLACE THE BROKEN HANDLE
THINGS NEEDED.
Phillips screwdriver.
Thin, flat-head screwdriver.
Putty knife.
Replacement microwave door handle.
1 Examine the inside of the door. The handles of some early GE Spacemaker microwave models were attached after the two inner door panels were assembled to the outer door. If you see two recessed screws opposite the handle attaching points, undo them with a Phillips screwdriver and remove the handle. If not, go to the next step.
2 Insert the blade of a thin, flat-head screwdriver into the top, outer corner of the door, between the plastic inner frame and the outer door. Gently pry the inner frame out and slip a putty knife into the exposed opening on top of the door. Slide the putty knife toward the hinges to free the top of the inner frame; repeat on the front and bottom edges of the door and lift the inner frame out to expose a second metal inner frame.
3 Insert a thin, flat-head screwdriver into each of the small square openings on the top and bottom of the inner metal frame, starting at the handle end of the door. Undo the attaching clips by gently levering the inner door away, using the rim of the outer door as a fulcrum. Move the inner door away from the outer door on its hinges.
4 Remove the glass from the outer door. Undo the two screws holding the handle to the outer door with a Phillips screwdriver. Screw the replacement handle onto the door and tighten securely.
5 Replace the glass panel and reassemble the door by snapping the two inner frames back in place.
Thanks.
Aug 30, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Trying to replace handle on GE microwave oven #JVM1631WB. Have already removed plastic cover that trims the glass on the inside of the door. This exposes two screws on the handle of which I have removed....
You order parts and find helpful exploded view diagrams here.
I'd recommend that your bookmark this link to your favorites.
Jan 29, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker II microwave: JEM25GY that died. It seems less expensive to replace rather than fix. Power works; it doesn't heat. New models all apparently have turntables; mine didn't and I...
YOU CAN TRY REMOVING THE GLASS TRAY AND TURNTABLE AND REPLACING IT WITH YOUR OLD GLASS TRAY (IF YOU HAD ONE) OR JUST ANY GLASS MICROWAVE TRAY. WITHOUT THE TURNTABLE, I CAN'T SEE HOW IT CAN ROTATE.
Nov 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Is there a fuse or circut breaker in the spacemaker?
yes a ceramic 15 or 20 amp fuse replace only with ceramic fuse sold at most hardware stores,its under outer cover its a 1" long by 1/8" dia white glass tube
Sep 23, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Can a novice do this...how do I do it, step by step?
Disconnect from electricity. Remove screws holding outer casing and you will see the inline fuse. Make sure there is nothing that will cause the fuse to blow again. Always replace the outer cover before testing.
May 20, 2009 | GE JVM1630 Microwave Oven
GE JVM1650BB005
You can search under Repair Parts and enter your full model number JVM1650BB005 and get an exploded view diagram here: http://www.geappliances.com/shop/prts/ That diagram can be a great help. Also, I've attached below a door panel diagram from a Sharp model. Your GE disassembly may work the same way. If you haven't already taken the door off the microwave, I would recommend you don't unless you leave the hinge assembly attached to the door and remove the door from the hinges. It's critical to be sure you get (or keep) the door and hinged aligned exactly as they were to prevent leakage.
Dec 05, 2006 | GE JVM1650 1000 Watts Microwave Oven
GE JVM1631 Microwave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
