Connect Samsung 40" Led HD to cisco explorer 4642HD
Connect to Cisco Explorer 4642 HD boxc
SOURCE: Receiving faxes with a Cisco ATA 186
More investigation implies that faxing over VoIP, as I am doing, requires setting the fax BAUD rate to 9600 bps or slower. So does anyone know if it is possible to set the BAUD rate on the Dell MFP 1600n multifunction printers?
Posted on Feb 23, 2008
  • 5 Answers
SOURCE: configure cisco aironet wifi
if ur using IOS autonomous AP, then u'll need to configure the bvi interface to get an ip address and then enable the interface. once it has an ip, u'll need to configure the ssid, vlan, etc - choices include doing so with the CLI or web page GUI. U'll need to enable the built-in web server then u can access it via the web interface to setup the ssid, any vlans, radius, etc. good luck.
Posted on Jun 19, 2008
techjuli
  • 157 Answers
SOURCE: cisco 857 router
You might need to reset the password. In order to do this, follow these directions:
  1. Console into the router, then power cycle it. As its rebooting hit the "break | pause" button on your keyboard, and you get to the rommon1> prompt.
  2. Then type rommon1>confreg 2142 rommon2>reset
  3. The router comes back on as if it were new---answer no to the first question, and sometimes it asks a second question (do you want to terminate autoinstall, or something...)---answer yes to the secondquestion if it asks. Then hit enter and you get router> in a few seconds.
  4. Then router>en router#copy start run
create a new account:
  1. router#conf t
  2. router(config)#username bob priv 15 password bob
set register back:
  1. router(config)#confreg 0x2102
  2. router(config)#exit
  3. router#wr
  4. router#reboot
and that should let you login with bob/bob
Posted on Nov 30, 2008
SOURCE: installation of cisco asa 5510 firewall
The problem is your version of java, you need to uninstall java 6 update 11 or 12 and install java 6 update 6. you can download this from the archive section at the java web site. I had the same problem but this solved it.
Good luck
pls send me a line if your problem is solve
asowe@lastingsolutions.gm
Posted on Mar 10, 2009
  • 8 Answers
SOURCE: Restart Cisco Asa 5510
Yes. The firewall will restart. Just be sure to save your running config to memory before turning off. For that you must issue the command: write memory.
Best Regards,
T
Posted on Apr 23, 2009
Horizontally overlapping picture when connected to a CISCO Explorer 4642HD. Proper picture when connected to DVD, computer, and WD Live.
press the auto august button we occasionally have this and that fixes it OR you can adjust the screen positioning with the projector so move the picture across till its straight
Jan 10, 2014 | Optoma DX603 DLP Projector
Need to find my wlan code Using Linksys cisco
Dear Friend!
Please write 192.168.0.10 in explorer and enter
User name and password : admin
Please vote after working.....
Best regards,
Pramod Bhikam Singh
Apr 22, 2011 | Cisco Linksys E1000 WirelessN Broadband...
No wireless connection for laptop. Linksys router - model #wrt160n v2
you can run a direct line to that router and go to the cisco web site and get the information you need to run that router. its a pdf format and is 2.56 Meg. Try this
SecureEasySetup (Orange/White) The Cisco logo is the Router's SecureEasySetup button. It
lights up and will stay orange when the Router is powered on. The color orange indicates that
the Router is not using the SecureEasySetup feature, while the color white indicates that the
Router is using the SecureEasySetup feature. When the Router enters SecureEasySetup
mode, the Cisco logo will turn white and start flashing. After the Router has generated
the SSID and WPA Personal key, the Cisco logo will stop flashing and stay white.
To clear the SSID and WPA Personal key, press and hold down the Cisco logo for five seconds.
The Cisco logo will flash slowly as the Router resets itself. The Cisco logo will turn orange to
indicate a successful reset.NOTE: SecureEasySetup is a feature that makes
it easy to set up your wireless network. If you have SecureEasySetup devices, run the Router's
Setup Wizard CD-ROM and follow the onscreen instructions to use SecureEasySetup.
Power (Green) The Power LED lights up and will stay on while the Router is powered
on. When the Router goes through its selfdiagnostic mode during every boot-up, this
LED will flash. When the diagnostic is complete, the LED will be solidly lit.
DMZ (Green) The DMZ LED indicates when the DMZ function is being used. This LED will
remain lit as long as DMZ is enabled. WLAN (Green) The WLAN LED lights up when
the wireless feature is enabled. If the LED is flashing, the Router is actively sending or
receiving data over the network. 1, 2, 3, 4 (Green) These numbered LEDs, corresponding with the numbered ports on the Router's back panel, serve two purposes. If the LED is continuously lit, the Router is successfully connected to a device through that port. A flashing LED indicates network activity over that port.
Internet (Green) The Internet LED lights up when there is a connection made through the
Internet port. A flashing LED indicates network activity over the Internet port.
Good luck
Nov 26, 2010 | Computers & Internet
When i boot up my router the output is all mixed up characters
I recently had a similar issue with a wrt54g Linksys (by Cisco) router. It happened when I used Internet Explorer 7 or 8. When I used Firefox, there was no issue. So, I suggest using a different web browser.
Oct 28, 2010 | Cisco 1721 Router
Hi, Can't connect my cisco 857w to my pc
make sure in your pc you set the obtain ip address automatically to your lan card and reset the router also and access the ipconfig command and check the ip address and access the login page thru internet explorer and do the setting for wireless access.
Jan 14, 2010 | Cisco 857W (882658019555) Router
Can not login on con 0 port (not text), lost
default username and password for all router are
admin and admin
or
admin and password
try these two combinations
else try link
http://www.cisco.com/en/US/products/ps6187/index.html
Oct 03, 2009 | Cisco 1811 Router
Cisco button
You will need to go into the router configuration which is done by going to "192.168.1.1" in Internet Explorer; From here you will need to set the correct settings for your wireless connection.
Jul 19, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
Password
try these combination's:
User password
cisco cisco
admin password
admin admin
admin 1234
Feb 12, 2009 | Zonet Computers & Internet
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
Electro Med Services...
