Philips 32 PFL3506/F7 wont turn on
Power flashed off and on now TV doesn't turn on.
    Top Expert:
  • Televison & ... Master
  • 36,467 Answers
Power supply failure
Posted on Dec 08, 2012
  • ryan Dec 08, 2012
    just held the power button as i plugged it in now it works....... i dont know
dsacco86
  • 1077 Answers
SOURCE: Philips 42" Model # is 42PF7320A TV Yr. 2005
Most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you red light flashing codes, circuit diagrams, test points, and part# lists. Usually, cost under $20. And most cases the new part cost less than $15.
I hope I shed some light on the subject for you.
Posted on Jul 05, 2009
abilenetech
  • 65 Answers
SOURCE: how do i watch movies on a philips 42pfl5603d/f7 from flash drive
the flash drive connection is usually for viewing pictures, but in most cases its used to upgrade the tv
Posted on Nov 18, 2009
  • 8457 Answers
SOURCE: Philips 42PF9631D 42 in. Plasma Television
Philip have alot power problems with their tv.Check power board for puff up parts like Capacitors,or rust in cracks or soldering.Changes parts or the whole power board.
Posted on Jan 08, 2010
welcomejee
  • 10594 Answers
SOURCE: i have a philips 32
It seems tv got problem in power supply board that is not providing proper output volts.
This model has two power supplies, main and inverter board. Both power supplies are available for $20 each (reasonable price?) at shopjimmy.com
Click HERE and HERE to view both required boards along with price info. Replacement of these boards is not so difficult for a handy person.
Let me know if you have additional question.
Thanks.
Posted on Dec 21, 2010
ronaldo_ross
  • 1056 Answers
SOURCE: TV wont turn on. No sound or backlight. The OPC
There is a problem with the standby section of the power supply. A flashing standby light indicate an overload which is caused by a shorted semiconductor in that circuit. It's fairly simple for a technician and should not cost much. You can't do that yourself it is electronic takes a long time to grasp.
Posted on Jun 04, 2011
Philips 42PFL3704D/F7. Why does it keep restarting?
Philips 42pfl3704d/f7 power reset when HDMI, USB, or cable ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Oct 9, 2012 - 5 posts - ‎2 authors
Philips 42pfl3704d/f7 power reset when HDMI, USB, or cable attached ... or Cable TV to unit the power resets, philips screen comes on and keeps on resetting. ... I tried a cable to the tv without the box and I do get picture.
Philips 42PFL3704D/F7 42-Inch 1080p LCD HDTV
www.amazon.com/Philips-42PFL3704D-F7.../B001LP...
Amazon.com, Inc.
Rating: 3.3 - ‎50 reviews
Amazon.com: Philips 42PFL3704D/F7 42-Inch 1080p LCD HDTV: Electronics. ... Will do all I can to prevent others from getting ripped off by Philips. ... came up every few weeks and would take an hour or so of reset before working properly.
Visit the support page for your Philips LCD TV 42PFL3704D ...
www.philips.ca > philips > Televisions > 3000 series
PhilipsFind support for your LCD TV 42PFL3704D/F7. ... How do I output sound from myPhilips TV to external audio devices such as Home Theaters, Soundbars, AV ...
42" Philips 42PFL3704D/F7 LCD TV WON'T COME ON - A
Dec 29, 2015 | Televison & Video
No power coming for Philips LCD tv
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and precious time.
Aug 24, 2014 | Philips Consumer Electronics Philips 32"...
How to fix 40pfl4908/f7 will not turn on
My philips tv no 40pfl4908/f7 has a white flashing light and the tv does not turn on
Mar 15, 2014 | Philips 40PFL4908/F7 - 40 LED 1080p HDTV...
Philips 32PFL3505D/F7 32-Inch LCD HDTV keeps turning off when I turn it on
very common failure on this tv is electrolytic capacitors failing on the power supply, the module that your power cord plugs into. The Caps can appear to have swollen tops, replace with same type or slightly higher working voltage. Observe capacitor polarity when installing new parts. Probably 1000 mfd @ 16V could be 1000mfd @ 25V.
you need soldering skills to repair the parts in question.
Mar 03, 2013 | Philips 32PFL3505D 32 in LCD TV
Philips 32" tv won't stay on
Quite possibly one of the heat sinks has come loose or a power supply cooling fan has failed.
Have you tried blowing it out using canned air?
Nov 01, 2017 | Philips 32PFL3504D 32 in. LCD TV
Where is My Philips 32pfl3505d f7 LCD TV fuses
I assume you are referring to the ac fuse, it is located on the power supply board. Just follow the ac power cord and it should lead you to it. If your set doesn't have a built in power cord, the fuse will be next to the power cord connector.
Sep 01, 2012 | Philips 32PFL3505D 32 in LCD TV
My Philips 32PFL3505D/F7 will not turn on after a power outage.
Had the the same issue. I was able to repair it by replacing a diode and updating the firmware.
Jan 10, 2012 | Philips 32PFL3505D 32 in LCD TV
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Televison & Video Logo
70 people viewed this question
Top Televison & Video Experts
Electro Med Services...
