Question about Honeywell REM5000R1001 Personal Comfort Station
No connect button on display???
New thermostat, new batteries. Display says no signal, no way to connect to new thermostat
4 Suggested Answers
chillmaster
  • 104 Answers
SOURCE: I tried to replace my
Your "R" terminal is basically your "hot" and your "C" terminal is basically your "neutral" to simplify explanation. The Furnace supplies the "R" power to the thermostat and then depending on what wire the thermostat sends the power back on determines what the system does. The thermostat terminals are as follows "G" is fan, "W" or "aux" is elect heat, "Y" tells the outdoor unit to run, "O" or "B" tells the outdoor unit whether it is heating or cooling, and "E" is emergency heat. "G" should connect from the t-stat directly to the furnace and go no further. "W" or "aux" AND "E" should both connect to your "W" or "W1" terminal in the furnace, there should also be a "W" connection to the heat pump ( this allows the H/P to turn on the elect heat when the unit defrosts) "Y" and "O" or "B" may or may not connect to a terminal in the furnace, usually they just pass through the furnace from the t-stat to the H/P and get wire nutted in the furnace. Now, here is the key. As I mentioned previously "O" or "B", a system will only use one or the other. The entire industry (except for Rheem and Ruud) uses the "O" terminial which has 24v on it when you are cooling and no power when you are heating. Rheem and Ruud use the "B" terminal which is just backwards, 24v in heating and no power in cooling. This is all for a heat pump, If you do not have a heat pump, then disregard the references to "O", "B", "E", and "aux". You will have R-power on red wire, W-heat signal to furnace, G-fan signal to furnace, and "Y" cool signal to outdoor unit.
Posted on Jun 15, 2008
  • 27 Answers
SOURCE: new batteries ...display not working
remove the batteries and pull the metal tabs at each end stretching out a little the reinstall the batteries
Posted on Nov 26, 2008
  • 118 Answers
SOURCE: display not working after battery change
some have a small reset button on the back where you push it with a pencil tip. That may help!
Posted on Oct 28, 2009
Blank Screen
Remove and install new batteries, if displays reprogram. if no display replace thermostat
How To Install Programmable Thermostat The Home Depot
Jan 20, 2016 | Televison & Video
I have A LCD Honeywell thermostat that has a display that is blank. also it is not sending anything to my furnace. there for my main level in my house is very cold. I have the same one up stairs and it is...
Replace the batteries first. Some cheap thermostats require the batteries to function. I don't know of a honeywell model that does though. Its cheap, so do that first.
If still nothing comes on and you still have a blank display with new batteries, I'd say probably the thermostat is defective. Even if the furnace is broken, new batteries SHOULD bring up the display.
Feb 20, 2015 | Heating & Cooling
Thermostat is working, but display is blank
My thermostat used to go blank when heating. It was caused by the overheat protector inside the heater. That switch cuts the power to the heater and the thermostat. The heater could also be burned out. If it's a 24Volt system, the power supply could be bad.
Oct 13, 2014 | Heating & Cooling
How can I troubleshoot an Asus monitor that won't display an image?
check you surface pro display setting.
check if it is enable to give signal to 2 display image of surface pro
Aug 31, 2014 | Computers & Internet
Batt Lo Displayed. I replaced with new batteries. The display still reads Batt Lo and I cannot changed temperature, etc.
sometimes you can bend out the battery holders to allow more tention on the batteries but thats only a temporary repair. a new thermostat is needed
Oct 28, 2009 | Honeywell Programmable Thermostat Heater
Display not working after battery change
Honeywell Programmable Thermostat Display issues
there are currently 60 honeywell thermostats made i have no idea witch one you have , but a lot of the new ones run on batterys you might be seeing a low battery signal . look for a door where batterys might be and replace them
Jan 14, 2009 | Honeywell Programmable Thermostat Heater
New batteries ...display not working
Nov 26, 2008 | Honeywell Programmable Thermostat Heater
Battery Issue
This worked! Thank you! It was 49 degrees in the house, and now the heater is working again.
Thank you and warm wished for the new year!
Mary
Jun 05, 2007 | Honeywell CT3200 5-2 Day Electronic...
Honeywell REM5000R1001 Personal Comfort Station Logo
37 people viewed this question
Top Honeywell Televison & Video Experts
Ron Durham
Tom Chichester
Are you a Honeywell Televison and Video Expert? Answer questions, earn points and help others
