Question about Ricoh Copier Toner for Aficio 2035, 2045 Type 3110D, Black
H have problem in ricoh aficio 2045 . when the copier need toner . the massage add toner .when open the door to load the machine didnt move to load
2 Suggested Answers
joel_baleta
  • 155 Answers
SOURCE: add toner ricoh aficio 2045
Toner supply is controlled with readings from TD sensor on the developing unit and the I.D sensor above the drum by default.
These are low cost parts and easy to change.
(The TD sensor on this model have been known to fluctuate back and forth by a fair margin so is a good place to start).
You could also try stripping down and cleaning out the toner hopper.
Check the four mylars are present and the grabber is opening wide enough to grab the toner bottle nozzle successfully.
Check the toner hopper exit slider is opening fully when the PCU is inserted.
I had one of these 'add toner' faults today and it was the toner hopper all clogged up inside.
The side bit where the toner drops down had hardened clumps of toner stuck around the side entrance mylar and the exit hole.
Check also the toner motor. I have seen these fail. Run simulation output check for toner motor. I would remove the toner supply unit and hold the motor when you run this simulation. Sometimes the motor turns but does not have enough torgue to turn the toner supply unit.
Posted on Mar 06, 2010
Add toner aficio mp 1900
open the front door of the machine.
remove the toner unit gently .
replace toner bottle.
refix the toner unit ans close the door .
wait for toner to load.
good luck..
Feb 20, 2014 | Gestetner DSm620d All-In-One Laser Printer
Sc 690 ricoh 2045
Try to reset : enter in SP mode ,open the front door and turn OFF the copier.Unplugged and Wait 2 minutes ,plugged and close the front door and turn ON the copier.If is do not work your problem is in the BICU board.
Apr 17, 2013 | Ricoh Aficio 450 Copier
I have an sc 326 error code in my ricoh aficio 2045 copier
kindly change the developer unit and clear the error.
the machine will respond
thank you and all the best
May 20, 2012 | Ricoh Aficio 2045e 2035e Copier...
Hello, I have a problem with RICOH Aficio 2015.
look check that motor bottle is rolling and toner home place is sending toner to drum
Mar 23, 2011 | Ricoh Aficio 2015 Copier
Sc 322 for RICOH AFICIO 2045
That is a LASER error code.
It can be just toner dust because that error is a bad communication between the laser synchronization detector board and the LD unit.
Sometimes the dust of toner goes to the laser and causes this error.
Try to clean the laser unit. Maybe that work
Feb 24, 2011 | Ricoh Aficio 450 Copier
My Ricoh CL7000 is saying add toner magenta. But there is plenty of magenta in the cartridge. I've added toner and cleaned out everywhere I can get to. Any suggestions?
It could be a clog in the toner tube, but the most likely (and easiest to fix) problem is the magenta DV unit. Replace the magenta DV unit, turn the machine off and back on, and if it still says add magenta toner open and close the toner cover so that it can load toner, then your problem should be gone.
Nov 08, 2010 | Ricoh Aficio CL7000 Laser Printer
I need to know the part number for the toner replacement bottle for the Ricoh Aficio 2045 PCL 6
Ricoh Aficio 2045 copier/printers take the Ricoh Type 3110D Toner Cartridge. Go with OEM toner on these machines. The generic version tends to make them run dirty.
Sep 09, 2010 | Office Equipment & Supplies
Add toner ricoh aficio 2045
Mar 05, 2010 | Ricoh Aficio 2035 Copier
On lcd massage
some times the nipple (cover) of the toner stays in the toner holder this wont allow the new one to be opened
Sep 22, 2008 | Ricoh Aficio 1022 All-In-One Laser Printer
Ricoh Copier Toner for Aficio 2035, 2045 Type 3110D, Black Logo
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
