I removed the back to see what battery to replace and can't get back on.
Some of the watch casebacks need a special tool (little press) to fit it back as human finger strength is not enough to close it back.
You need to find your nearest watch repair shop and ask for help. It is quick and easy operation, but without this tool allmost impossible.
Do not try to use any inappropriate tools (such as a hammer or similar) to force caseback back on as you can easily damage watch case, caseback or even movement.
Do not forget to rate, please.
Posted on Jan 13, 2009
Oct 02, 2016 | Watches
Sep 09, 2016 | Fossil Watches
Aug 30, 2016 | Michael Kors Watches
Dec 21, 2015 | DG Watches
Mar 09, 2013 | Watches
Nov 12, 2010 | Fossil VT2654 Pocketwatch
Choose a quiet, well-lit room where you can replace the battery in your Casio Pathfinder watch. Prepare a table, desk or other clean, flat surface where you can perform your watch repair. Put down a soft cloth or piece of craft felt to protect the face of your Casio Pathfinder watch from being scratched during the battery installation process.
Set your Casio Pathfinder watch face-down on the soft cloth or craft felt. Use an optical-sized Philips screwdriver to remove the four screws that secure the watch back to the body of the watch. Set the screws aside, but don't lift the watch back.
Slide the watch back off of the body of the watch very slowly. There are three important springs held underneath the watch back; it is essential to remove the watch back slowly to avoid losing them.
Lift the three springs out of your Casio Pathfinder watch using a small pair of metal tweezers. Take note of the length and placement of the springs as you remove them. Set the springs aside with the other disassembled watch components.
Take the black rubber protective disk out of your Casio Pathfinder to reveal an identically-shaped white plastic disk. Remove the white plastic disk and set it and the black rubber disk aside. Use your metal tweezers, if necessary, to lift out the rubber and plastic disks.
Release the battery strap that holds the battery in place in your Casio Pathfinder watch by pushing the battery strap latch to the left. Remove the old battery from your Casio Pathfinder using a pair of small plastic tweezers.
Pick up your replacement watch battery with the small plastic tweezers and insert it into the battery compartment of your Casio Pathfinder watch. Replace the battery strap and push it gently with the tip of your plastic tweezers to snap the latch in place.
Touch the "-" and "AC" terminals on your Casio Pathfinder watch with the tips of your metal tweezers for at least two seconds. This helps ensure that your watch will work properly once reassembled.
Put your Casio Pathfinder back together to complete the new battery installation. Start by replacing the white plastic disk, followed by the protective black rubber disk. Use your small metal tweezers to replace the small watch springs in their correct locations. Replace the back cover of your Casio Pathfinder, insert the four screws and tighten them with your optical-sized Philips screwdriver.
Sep 19, 2010 | Casio Pathfinder PAG40B-2V wristwatch
Sep 01, 2010 | Casio MTP3036A-2AV Wrist Watch
Aug 17, 2010 | Kenneth Cole KC3434 Wrist Watch
Aug 14, 2010 | Swatch Skin SFK254 Watch
Feb 14, 2013 | JCPenney Armitron Sport Link Bracelet...
229 people viewed this question
