Question about Zeikos 55mm Filter Kit W/cirpolarizer For Sony Alpha
Will 55mm zeikos filters fit canon t3i lens?
Received the filter pack from a friend, do I need an adaptor to have these filters fit my canon t3i lens?
  • 685 Answers
That will depend upon which lens you have. Look on the inside of the lens cap there will be a number written like 52mm or 58mm. Once you have that you can get a stepping ring from your lens to the filters. Call us for help 864-583-6835
Posted on Dec 15, 2012
Lens filter choice for photographing solar eclipse 20.03.15 south UK
A bit late but try here for solar filters www.wexphotographic.com
Mar 12, 2015 | Canon EOS 600D Rebel T3i Digital Camera
What happens when I get Error code 20 on a canon rebel eos rebel t3i 600d?
From the Canon owner's manual:
"Error codes 10, 20, 30, 40, 50, 60, 70 and 80: Shooting is not possible due to an error. Turn the camera off and on again or re-install the battery. Operate the power switch, remove and install the battery pack again, or use a Canon lens (p.32, 28)."
Jun 17, 2014 | Canon EOS 30D Digital Camera with 18-55mm...
How to install a 52mm filter to a nikon 18-55mm lens
If you have 52mm screw in filters, look at the filter and you will notice that the metal ring has threads. Look at the inside of the rim surrounding you lens front element and you will also see screw threads. Carefully align the filter with the lens threads and screw them together. Do not over tighten or you will have difficulty removing your filter.
Although less common today, unthreaded filters are or were in the past available. If you have unthreaded filters, you will need to buy a 52mm filter adaptor. The adaptor is made in two screw together pieces. Unscrew the two pieces, drop the filter in between them and screw them back together. Then, screw the adaptor onto your lens.
Mar 11, 2014 | Nikon Cameras
Every picture I take has a line going through every picture
Have you checked you lens, there could be a hair line dust scratch on it. Or you have it set on a setting that helps with leveling...yes camra's do have them.
Aug 27, 2013 | Polaroid Studio Series .43X HD Wide Angle...
How to mount q-ray 70-210mm lens on canon t3i body
Quantaray makes lenses with a variety of lens mounts. Assuming the lens has a Canon EF mount, it will fit onto the T3i just like any Canon lens. If it has a different mount, you'll need an appropriate lens mount adapter.
Feb 28, 2013 | Canon EOS 600D Rebel T3i Digital Camera...
How to mount 67mm thread lens to t4i body only canon
One side of the reverse adapter has a 67mm thread, the other side has a lens mount. Mount it to the camera body as if it were a lens. Bear in mind that it's intended to screw onto the front of a lens and then mounted onto a camera to put the lens onto the camera in a "backward" position.
Dec 16, 2012 | Fotodiox 67mm Filter Thread Macro Reverse...
SIGMA CAMERA LENS 50-500MM 1:4-6:3 APO HSM EX FOR CANON
Any digital single lens reflex camera body , rebel t3i, go to Canon's USA website and look at dslr cameras
Oct 20, 2012 | Sigma APO 50-500mm F4-6.3 EX DG/HSM Lens
I have a Canon Power shot S3 . Can I use a Sigma AF-Mf zoom lens 100-300mm to it. If Yes, what type adapter to use.? I also have a 35-80mm canon lens. can this be used ? Thanks.
Your camera is a fixed lens compact model. You cannot fit other lenses to it unless they are specifically designed as supplementary lenses which screw onto the existing lens filter thread.
There are no adaptors you can safely use either, the only ones would be lens reversing rings which are used to mount lenses backwards for ultra close-up macrophotography, but the weight of the lenses you propose on the end of your existing lens would break your camera.
If you wish to use interchangeable lenses then you need to obtain an SLR or an interchangeable lens rangefinder camera.
Oct 03, 2010 | Canon Cameras
Just bought a 52mm hood, but it doesn't fit... Why??! Do I need another adapter?
The hood you buy needs to be the same as the inner ring on your lens. If you look at the inside of the lens ring or on the outside of the lens it will tell you what size filters will fit your lens. If the 52mm is too small or too big you should be able to find a adapter for it so it will fit. Try going to B&H photo website. They have tons of photography items. Hope this helps.
Oct 27, 2009 | Kodak EasyShare Z710 Digital Camera
What are the best filters for my canon t70
Any Canon FD lens will work. Also any 3rd party lens for the Canon FD mount.
Filters? depends on what you're shooting, but keep a UV or Skylight filter on the lens at all times. If you drop it, the damage will happen to the filter...not the lens.
Oct 08, 2009 | Canon T70 35mm SLR Camera
Zeikos 55mm Filter Kit W/cirpolarizer For Sony Alpha Logo
87 people viewed this question
Top Zeikos Cameras Experts
Are you a Zeikos Camera Expert? Answer questions, earn points and help others
