Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Wayne Dalton garage door light stays on door is not working
I have Wayne Dalton Classic drive garage door opener. My remotes were not working. I replaced the board. Programmed the remotes. They are working, but something else broke. My LED interrupter came out. I put it back. When I try to open or close the door, first the light comes on and stays on. Door does not moves. I think this is a kind of code, but can not google it what it is. Then if I push the button or remote one more time it will go back and forth like a saftety issue. Please help if you have any idea. Thanks.
SOURCE: Garage Door issue
http://www.wayne-dalton.com/Files/ProductManuals/Residential_Garage_Door_Openers/DoorMaster/300640%20P4%207-9-2007.pdf
Posted on May 26, 2008
  • 4 Answers
SOURCE: remotes quit working for garage door
I had the same problem with my Craftsman opener but different model. However to fix this I simply followed the instructions that came with the opener and reprogramed the remote to the opener. The instructions are in your owners manual and are pretty straight forward.. John
Posted on Dec 11, 2008
SOURCE: My Wayne Dalton garage door will open with remote but not close
your infrared sensor is either misaligned, faulty, or you have a broken wire from your sensor to your door opener. (Flashing light indicates infrared light path is broken). both sensors should indicate green led. door wil not come down is safty feature to prevent door from closing when light path is broken.
Posted on Jan 16, 2009
glenmann62
  • 91 Answers
SOURCE: programing garage door opener remote
ok crystal,calm down this is an easy one! first locate the smart button on your openers , next you will press and hold down the smart button until you see an indicator light above it shut off, while your holding that button the light will be solid ,Now your ready to program your remotes ,first programm one side by taking each of your four remotes and pressing the smart button on machine then pressing the button on the remote you want to program,by doing that you will notice the lightbulbs on your machine shut off and go back on , This is an indicator that your machine has accepted the code , now do it with the other three remotes , after you,ve programmed all four ,go over to the other machine and repeat the process but this time you have to choose another button on your remotes since you,ve programmed all four remotes to the same button on each remote ,just choose the bottom button on your remotes this time to keep them seperated , hope this helps you and it is as easy as 1-2-3 your owners manual will describe exactly the same ,i know because i,ve installed over 27,000 machines working as an installer for sears, please leave a nice feedback rating if i was able to help you, good luck,Sincerely Glenn Mayer
Posted on Apr 01, 2009
SOURCE: Wayne Dalton DoorMaster Model BDOR-2000/BIRW-2000
Check the contact at the bottom of the socket and (with the unit unplugged) lift (or pull) it up to make contact with the bulb easier or tighten the bulb a bit more than normal.
Does the light ever come on?
Posted on Jul 28, 2009
Wayne Dalton garage door opener
well one answer might be the down force and up force need to be adjusted. it starts to move and then reverses because the force is set too low.
Mar 26, 2016 | Building Materials
How do i reporgram a wayne dalton keypad
I would look into buying a liftmaster jack shaft its a much better unit but to get u buy just press the little red button on the opener type in your code
Feb 04, 2015 | Wayne Dalton Remotes Wayne Dalton 327308...
Garage Door Remote
Did you happen to put a new light bulb in it? I put an LED bulb in mine and the interference caused the remotes to stop working. I had a bear figuring it out, because it seemed to be totally random. Sometimes they would work and sometimes they wouldn't. Once I switched back to an incandescent, it worked fine.
Jan 17, 2014 | Genie Wayne Dalton 36560U 1/2 Hp Dc Belt...
Batteries need changing in the garage door remote control. It requires the code to be reset but the previous owners of the house left no information. It is a Wayne Dalton, Magic Touch, Model Number...
Using a step stool reah up and remove the plastic light cover from the garage door opener and the the code setting instructions are written on its panel. Or seach on LiftMaster.com for help.
Jul 26, 2011 | liftmaster Remote Light Control Garage...
Need instruction manual for Wayne Dalton Chamberlin WD 220 grage door opener
The LiftMaster or Chamberlain web site has instruction manual downloads for all the models.
Jul 23, 2011 | Sears Craftsman LiftMaster Chamberlain...
How to have security with a lost wayne dalton garage door remote
Go to this site and follow the instructions.
http://www.1stdooropeners.com/299264coding.htm
May 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a wayne dalton garage door opener and the light stop working after and over ride or over use I let the motor rest and work again but the light stop working I replace the light bulb and nothing...
Try unplugging the unit for ten seconds.If that dont do anything youre have to call wayne dalton they should warranty the light socket replacement ,super easy to change out.
May 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Where to buy pre-1993 garage remote
Genie.com, overheaddoor.com or wayne-dalton.com are the places to go to get this third opener. Thanks BB
Jan 13, 2009 | One For All URC-5705 Remote Control
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
281 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
