Question about Microwave Ovens
Asda microwave seb177djh-p how to fix the light
How to replace light
How do I fix a blown microwave fuse?
How to Fix a Microwave Oven - Simple Fuse Replacement ...
? 18:04
https://www.youtube.com/watch?v=IN0BqiVX5ds
May 21, 2013 - Uploaded by GuruBrew
How to Fix a Microwave Oven - Simple Fuse Replacement. GuruBrew .... I'm hoping it's just a blown fuse ...
Whirlpool Microwave Keeps Blowing Fuses - YouTube
? 2:35
https://www.youtube.com/watch?v=KGQgendKTR0
May 7, 2013 - Uploaded by AdamDIY
Whirlpool Microwave Keeps Blowing Fuses ... MicrowaveThermal Fuse Replacement - GE Microwave ...
Microwave Oven Repair 101 ' DoItYourself.com
Dec 06, 2015 | In Microwave Ovens
How do I set the clock on a Zip 931 17L microwave?
The procedure is rather non-intuitive, as you have to press CANCEL to set the clock.
From the ZIP931 manual:
Setting the Clock
1. Touch CLOCK
2. Touch CANCEL
3. Enter the time
4. Touch CLOCK again
Note that this microwave oven is also sold under Asda, Russell Hobbs, and Oriental Pacific brands
http://www.fixya.com/support/t5816263-set_clock
http://mda.russellhobbs.com/IBS/RHM2016.pdf
Mar 12, 2015 | Microwave Ovens
I have a Heller Microwave Oven Model No: HMW28CS and the light doesn't work any more, was wondering if this can be fixed because there is nothing in the manual about this.
test this steps and fix it. God bless you
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
Oct 25, 2013 | Microwave Ovens
Light bulb
follow this steps and fix it. God bless you
  • Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction
  • Jul 29, 2013 | GE JES1384SF Microwave Oven
    Bought daewoo microwave KOR-6L15/ aug 2009 9 mnths use paint pealed exposing bare metal , asda (4944) replaced it like for like , new micro has the same problem paint peeling worse than the old one .my...
    Go and talk to them, it's obviously not fit for purpose and in the circumstances they should replace it.
    They offer a years guarantee and that's what you have had but you also have rights under the sale of goods act. for the item to be merchantable quality which it is not.
    Ask to see the manager, be polite and firm.
    good luck
    Mar 02, 2011 | Daewoo Microwave Ovens
    I have the asda microwave p80d20al-t5 and i need to reset the clock
    If you were to log on to asda's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, and a list of Dealers as required.
    Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
    I hope this helps.
    Nov 15, 2010 | Microwave Ovens
    How to set clock on asda microwave, p80d20al t5
    1. Touch CLOCK pad.
    2. Touch CANCEL pad.
    3. Use number pads to enter the correct time. You need at least three numbers to set time. (Note that the clock is a 12hr format clock)
    4. Touch CLOCK pad again.
    Aug 31, 2010 | Microwave Ovens
    Onn microwave/ oven. Need instruction manual
    call adsa electrical on 0845 3007775 and they'll email you the instructions
    Sep 17, 2009 | Microwave Ovens
    Microwave Ovens Logo
    83 people viewed this question
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
