Question about Frigidaire Washing Machines
Start capacitor FEX831FS2 - Frigidaire Washing Machines
Frigidaire fex831fs2 stackable dryer takes too long to dry and leaves clothes damp
Good Afternoon Famties4,
I understand that the dryer portion of your laundry center, model#FEX831FS2, takes too long to dry, even after making sure the vents are clear. First, I suggest checking the exhaust duct, making sure it is at least 4 inches in diameter and made of rigid or flexible metal. Secondly, make sure the duct has no more than two 90 degree bends and must not exceed length listed in the INSTALLATION INSTRUCTIONS. Lastly, make sure your dryer is connected to a 240 volt circuit. Drying time will be 20% longer than drying on a 240 volt circuit. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully.
-Best Regards-
WP
May 17, 2014 | Frigidaire 7 Cu. Ft. Stackable Electric...
What's the resistance value in stackable dryer motor model fex831fs2?
There should be some for both the motor and the heater coil. Don't know how much don't have schematic. Hope this helps
May 18, 2014 | Frigidaire 7 Cu. Ft. Stackable Electric...
Washer will not start
The valve is the best place to start looking, you should get a meter to measure voltage and ohms. There is nol guarantee that the valve you used is the right wattage so it is of no help.
Mar 21, 2014 | Frigidaire FEX831F Top Load Stacked Washer...
Frigidaire FEX831FS2 LAUNDRY CENTER-Agitator does not work, all other functions work...tub fills, spins and drains,
Can you move the agitator freely by hand? If so, you will need to replace the agitator due to it being stripped out. Here is the part to order.
Aug 18, 2013 | Frigidaire Washing Machines
Frigidare fex831fs2 washer fills but does not run
1. sounds like the drum has had it it happened to one of ours can be fixed though
Jan 30, 2012 | Frigidaire FEX831F Top Load Stacked Washer...
Frigidaire FEX831FS2 stack washer/dryer; it washes, but when it goes into spin cycle it does not spin and you can smell something "funny" burning up like a motor or something. This is what the...
well, The transmission hears turns 2 ways. One way to wash (which causing the agitator turn) and the other to spin. The motor also turns 2 way. If you say it washes fine and in spin cycle is where you get burning smell, maybe of many things: Bad transmission locking up motor causing the burning smell. Possible bad motor trying to start (bad start winding or capacitor). Maybe something simple as something getting stuck in between outer tub and inner basket. Something you can do to check the motor mechanically is disconnect the belt from the transmission pulley and put the time on spin cycle. If the motor shaft/pulley spins on start up then the next thing to look into is the transmission or something catching it from spinning. Check the inside of the washer, if the basket is the type with small holes, make sure there is nothing stuck in any of the whole. Iv seen small screws getting lodged in there and preventing the basket from spinning. You can start by doing simple checks like this to start narrowing down things. Open the front panel form the washer and see if you have access to the belt, if not then you have to tilt the unit to get under it. if you have money and dont want to bother dealing with the unit then replace it. But i like investigating things first. go with whirl pool if you replace it. let me know if what you find if you do make these checks.
Sep 10, 2011 | Washing Machines
Washing Machines Logo
20 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
