Question about HP Pavilion ZD8110US Notebook
Hp 630 touchpad not working -pointer moves but doesn't click
    Sergeant:
  • HP Expert
  • 427 Answers
Double click on pad surface. Buttons could be faulty. Check mousepad settings. Install drivers
Posted on Apr 17, 2013
5 Suggested Answers
  • 9 Answers
SOURCE: I am having HP laptop. For last 2 days my touchpad
try reinstalling the driver for the mouse pad
that should go fine
Posted on Jan 05, 2010
  • 64 Answers
SOURCE: HP Pavilion DV2817CA ALPS touchpad Problem.
First call the person(s)who refurbished your computer.Second find out where a new mother board might be available.Third put your complaint to hp in writting.Fourth,see how much a new touch pad panel might cost you,then before you toss it find a geek squad(s) and have them,tkae a look at it.Or sell it once fixed.(Get something out of it)for all your trouble.
Posted on Feb 15, 2010
kachi
  • 425 Answers
SOURCE: hp lap top pentium 4
It's bad and needs to be changed, ie if you must keep enjoying the old functions.
Posted on Jun 23, 2011
rockmeister
  • 2047 Answers
SOURCE: Since I upgraded my OS
Hello there, This is a common problem when you upgrade the OS of a PC to a higher OS. The driver for that feature has not been installed on your PC. Often times the previous driver does not support the new OS so the scroll function will not work.
What you need to do is locate the driver for that particular feature which in most PC's are refered to as the synaptics pointing device. Download this from HP driver support.
When you open the site click on drivers and software then input your model number select from the list the PC which most appropriately describes your unit next select your OS to be windows XP and from the list select "Driver-Keyboard, mouse and input devices" then select "touchpad pointing device driver" and download the software.
After downloading the software right click on it and select properties in the window that pops up select compatibility and when you select that tick on run this program in compatibility mode for from the drop down list select Microsoft windows XP and click apply at the bottom of the page. then click on OK. after doing this install the driver which was downloaded and restart the PC. At this point the problem should be solved and the scroll on the pad should function properly.
Hope this solution has been helpful?
Thank you for visiting FixYa.
Posted on Aug 06, 2011
Gateway the touch pad not function why?
Adjusting the touchpad sensitivity on a Gateway laptop lets you fix and prevent annoying touchpad problems.
Often the touchpad is accidentally brushed while typing, which causes the cursor to move out of place.
Or you may find yourself having to tap too hard or too often on the touchpad to open windows and programs.
These problems can be fixed by simply adjusting the touchpad's sensitivity settings.
Click the "Start" button and double-click "Control Panel."
Double-click "Hardware & Sound" and choose "Mouse" to open the mouse properties box.
Choose the "Device Settings" tab. Highlight "Synaptic Touchpad" in the Devices box by clicking on it. Click the "Settings" button underneath the Devices box.
Choose "Sensitivity" in the properties settings box.
Click "PalmCheck" to adjust the sensitivity of the touchpad to accidental brushes against the pad while typing, which causes the cursor to move.
Click and hold the pointer to adjust the setting on the sensitivity scale.
Click "Touch Sensitivity" to adjust the sensitivity of the touchpad to tapping.
A higher rating on the scale means less tapping pressure will be needed.
Click "OK" to save your touchpad settings.
May 15, 2013 | Acer Aspire Computers & Internet
HP 2530p EliteBook - touchpad stopped working. Scrolling works except touch scrolling on right side of pad) and right button, but that's all. Wireless mouse works fine.
To access Mouse Properties, select Start - Control Panel - Hardware and Sound -Mouse.
Use Mouse Properties in Windows to customize settings for pointing devices, such as button configuration, click speed, and pointer options.
Jan 18, 2013 | HP EliteBook 2530p Notebook
Samsung laptop cursor tweeking
Step 1
1. Open Mouse by clicking the Start button, clicking Control Panel, clicking Hardware, and then clicking Mouse.
2. Click the Pointer Options tab, and then do any of the following:
To change the speed at which the mouse pointer moves, move the Select a pointer speed slider towards Slow or Fast.
• To make the pointer work more accurately when you're moving the mouse slowly, select the Enhance pointer precision check box.
To speed the process of selecting a choice when a dialog box appears, select the automatically move pointer to the default button in a dialog box check box.
To make the pointer easier to find when you move it, select the Display pointer trails check box, and then move the slider towards Short or Long to decrease or increase the length of the pointer trail.
To ensure that the pointer doesn't block your view of the text you're typing, select the Hide pointer while typing check box.
To find a misplaced pointer by pressing the CTRL key, select the Show location of pointer when I press the CTRL key check box.
Change mouse settings
http://windows.microsoft.com/en-US/windows7/Change-mouse-settings
Step 2
If you are using touchpad, try reducing the Touchpad sensitivity and check
1. Click on the "Start" icon in the lower left corner of the screen. Select "Control Panel." Next select "Mouse" under "Hardware and Sound." You can also left-click the touchpad while the cursor is anywhere on the desktop. From that screen, choose "Mouse Pointers."
2. Select the "
Buttons" tab at the top of the dialog box that opens. This shows the type of touchpad device installed on your laptop.
3. Set the touchpad for right or left-handed use from this dialog box. You can adjust the double click speed of your computer as well. When you finish making any changes, click "
Apply."
4. Pick the "
Device Settings" tab from the dialog box now. You can see the touchpad for your Vista machine highlighted on this screen. Select "Settings."
5. Read the information provided in the next dialog box. It gives you options for tapping your
touchpad, using the buttons, scrolling, pointer motion and sensitivity.
6. Make any changes you want from the various topics. When you make a change, click "
Apply." Click "OK" when you finish making all your changes.
7. Do some work on your computer for a while, If the touchpad is still too sensitive, return to the "Mouse" menu and continue to adjust the settings until you get them just the way you want them.
Step 3
If the issue persists try to perform a clean boot and check whether the issue is still persists.
Follow the steps mentioned in the article given below.
How to configure Windows Vista to start in a "clean boot":
http://support.microsoft.com/kb/929135
Note:Once the troubleshooting is over, reset the computer to start as usual.
Also I would suggest you to keep in touch with mouse manufacturer
Oct 10, 2012 | Samsung SENS R460 LAPTOP LCD SCREEN 14.1"...
The cursor jumps around on my ASUS K501J notebook.
Step 1
Step 2
2. Select the "
Apply."
4. Pick the "
Step 3
Oct 08, 2012 | ASUS K50IJ Notebook
I have a HP 630,how can I disable the trackpad. There are no options avi in control panal
The touchpad provides full mouse functionality to your laptop but there are instances when you may actually feel more productive without the touchpad. For instance, if you have attached an external mouse to your laptop, you may not need an alternate input mechanism which is the built-in touchpad.
Sometimes your thumbs or palm may accidentally touch the touchpad while you're typing and this may inadvertently move your mouse cursor to a different location in the document. If you were not looking at your screen when the pointer jumped, you may end up typing at the wrong place.
Jul 26, 2012 | HP Computers & Internet
Touchpad stopped working cannot move pointer arrow around screen
Just check for the key combination on your key board (ex. Fn + F4 or F5..depends on the what key was designed for the touchpad), the touchpad might be locked.
If it is not locked, reinstall the touchpad driver, but it this still doesn't work, boot to Safe Mode to check if it does. Touch pad still not responding in Safe Mode would mean hardware failure.
Hope this helps.
Jun 26, 2011 | Computers & Internet
I have a HP pavillion DV6-1250us Windows vista home premium and i cannot get my mouse to scroll up or down? how do i fix this?
To move the pointer, slide your finger across the TouchPad surface in the direction you want the pointer to go. Use the TouchPad buttons like the corresponding buttons on an external mouse. To scroll up and down using the TouchPad vertical scroll zone (right edge of the touchpad), slide your finger up or down over the lines.
NOTE: If you are using the TouchPad to move the pointer, you must lift your finger off the TouchPad
before moving it to the scroll zone.
Mar 03, 2011 | Computers & Internet
Tap function in my laptop not working
You need to download and re-install touchpad drivers to get the tapping function working.
You can download the touchpad drivers from the link below:
Select software and drivers
Mar 27, 2009 | Computers & Internet
Computers & Internet Logo
229 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
