Can not install it properly
Where do thwe three wires yellow red and white do
    Top Expert:
  • Televison & ... Master
  • 35,708 Answers
This is not a remote control problem; it is an equipment problem. The three "wires" you refer to are right audio (red), left audio (white), and video (yellow). If you can reply by telling me what you are trying to connect to what, maybe I can help
Posted on Dec 08, 2012
Midland 77-118. Three wires coming out of unit red,black,and orange. What is the orange for? Also need manual.
Its like the wiring in your house. That little three prong plug. There are three wires, one black,one white, and one green. The green is a ground wire , the black is neg flow and the white is positive flow. Well the red wire is hot ,the yellow wire is neg flow,and the black is ground. Some times the yellow wire isn't even connected. Look inside your radio and you will only see a red and black wire???you will have to google the radio model as such ( 77-118 owners manual)
Sep 01, 2015 | Midland Radio Communications
How do I install the 4 prong electrical cable to the dryer?
I would attach the black wire to the black & yellow, white to white, red to blue & brown. The green wire is your ground wire and needs to be attached to the cabinet. On the connection where your white wire is located see if there is a copper strap that goes from the terminal block to the cabinet. If there is, you will need to remove that strap and attach the green wire to where the strap was attached to the cabinet. Hope this helps!
Sep 16, 2014 | Dryers
How do I wire the plug to a Lotos plasma cutter for 220 volt ?
There are three wires on the machine, RED BLUE and YELLOW GREEN. In a standard US 220 VAC connection there is red, black and white. RED is connected to red, BLUE is connected to black and YELLOW GREEN is connected to white.
Sep 12, 2014 | Lotos LT5000D 50-Amp Plasma Cutter
I have three wires, yellow, blue and red which operated a fan which I am replacing. The new fan has a small cable junction with three marking, L, N and T. Which wire to which letter is my problem. I
I'd be willing to bet the yellow wire is really white just discolored and if so the that would be N for neutral the white wire, blue has been for the fan light ( L ) on the ones I've done so that would leave the red and T.
Mar 02, 2014 | Hand Tools
Dubbing from vhs to dvd but when trying to playback dvd it comes up blank
Install all three 3 RCA plugs to output of vcr,, other end of wires 3 RCA wires plug into right front of recorder then push record. Be sure red to red, white to white, yellow to yellow or you might have a bad RCA cord. Remote set source to E2.
Apr 12, 2011 | Philips DVDR3505/37 DVD Recorder
Honda cb250w 1998 problem with regulator - not sure of the wiring details. Has three yellow wires , a green and a red/white. In Melbourne Australia
The three yellow wires are from the alternator and supply AC voltage. The green should go to earth. The red and white is the 12 volt DC that will go to the starter solenoid/battery connection.
Jan 30, 2010 | Honda CB 250 Motorcycles
How do i hook up my dvd player
Get the appropriate cord for connecting the DVD player to the TV.
The chord should be three joined together. Its called an AV wire. It has yellow, white and red color at the mouth of the pin.
The yellow is for Video (Visual) while the red and white are for audio (sound).
Since the DVD is to show on the TV, the wire has to be connected as follows:
  1. Insert the yellow wire in to the yellow part of the video out of the DVD.
  2. Insert the white and red wire in to the white and red part respectively to the audio out of the DVD.
  3. Connect the other part of the yellow wire to the input of the TV
  4. Connect the white and red wire to input like wise.
  5. Put on the TV and select to AV from the TV remote and you will see a display of your DVD at the background of the TV.
At this stage you can start watching.
Take care.
Jan 01, 2010 | GE 27GT271 TV
I'm trying to install a rotary phone, but it doesn't have a jack like modern phones do. It has three wires with little crescent shaped metal things on the ends. Please help!
if they are red-green-yellow then just isolate your yellow wire and spade and open up phone junction box and connect the red/green wires to the red/green wires on phone jack terminals you can hook either way this type of phone isn't polarity sensitive,then make sure all other phones on this line work properly after install
Sep 15, 2009 | Cortelco 1950's Classic American Standard...
Wiring issue with the Honeywell HE360A Humidifier
Maybe I can help. this is 24v so it doestn't matter which wire goes where so here goes. 2 wires from humidistat go to furnace, split one of the wires(not both) so they reach the yellow wires on the humidifier. with marettsconnect one of the split wires to one of the yellow wires. do the same to the other split wire and yellow wire. what you should get is one wire from humidistat to furnace then one wire from humidifier to humidistat and one from humidifier to furnace. hope this helps
Jan 31, 2009 | Honeywell HE360A1027 Whole House...
Hook up portable dvd to tv
Connect the phone jack sized end of the wire to the portable DVD player and then connect the 3 RCA's to your tv in the color coded spots. Yellow for Video, Red and White for Sound.
Dec 18, 2008 | Sharp Aquos LC-15B4U-s 15 in. EDTV-Ready...
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Electro Med Services...
