Question about UltraFire Camping, Backpacking & Hiking
UltraFire UF-H1b headlamp quit working, caan it be repaired?
UF-H1b uses CR123A battery
How to disassemble a zoom focus flashlight
Ultrafire/CREE XML XM-L T6 LED 1600LM Flashlight Torch ...
? 27:39
https://www.youtube.com/watch?v=lsPdC-xgxTU
Oct 15, 2013 - Uploaded by Richard Lloyd
Here is a link to this CREE XML XM-L T6 LED 1600LM flashlightat ... 1600LM Flashlight Torch Lumen Zoomable Review/Disassembly/Mod.
CREE Flashlight - How to Fix Frequent Problems - YouTube
? 8:04
https://www.youtube.com/watch?v=zJpQAvum0bM
Dec 21, 2010 - Uploaded by motorbiking
How to repair your flashlight if the LED stops working, if it changes mo... ... Mini Cree Led Q5 Ultrafire Flashlight Torch Adjustable Focus Zoom ...
Disassemble HausBell CREE Flashlight (replace battery ...
Jan 19, 2016 | Cameras
How do I use the ten-tap programmable switch
Hi, I have included a link to the instructions for the ten-tap programming.
Dec 25, 2013 | Streamlight Protac HL Flashlight, 600...
I have a new ultrafire WF-502 b torch which only works on low mode, cannot get high, medium, strobe or sos modes to come on
Sounds like the battery needs to be charged. The same thing happens to mine when the battery gets close to being depleted.
Apr 09, 2013 | UltraFire WF502B
I purchased a lantern model # jasco 17300 and the light quit working after 6mos use
You may get it repaired but the cost will be the same as buy a new one or much more than get a new lambp. So I suggest you purchase one from online store:
http://www.aurabuy.com/outdoors-76-led-ultra-bright-waterproof-headlamp-with-adjustable-band-black-silver-4-aa.html
Mar 26, 2013 | Camping, Backpacking & Hiking
Led flashlight and headlamp from home depot #326 914 a light does not go out or give 3 modes
I think this one is suitable for you.and it is only 9.99$
UltraFire HD2011 CREE T6 LED 1000 Lumens 5-mode mini handy flashlight(1X18650)
Dec 31, 2012 | Camping, Backpacking & Hiking
Fullcharged new battery, light is green on charger, brandnew never used WF502B and nothing, no light clicked it severl times.
Try unscrewing the flashlight head from the flashlight body and removing the LED lamp assembly. It is integrated with the reflector which can also be unscrewed from the lamp assembly if necessary. The lamp assembly makes contact through two springs that make contact with the flashlight body and it is possible it was not assembled correctly causing one of the springs to be distorted and not make contact. Failing that, the LED emitter assembly might be defective.
Dec 15, 2011 | UltraFire WF502B
I have a cyclops 2 cell witch uses the cr123a batteries.the bulb burned out . where can i get an replacement at
The bulb may be purchased at most electronic stores such as Fry's or Radio Shack for under $2.
Feb 02, 2010 | Cyclops ® XRF Xenon Rechargeable...
LCD IS NOT WORKING WHEN CHARGEABLE BATTERIES IS PUT IN THE BP300 GRIP
ni-cad or ni-mh rechargeable batteries all have charging cycle life and will fall in effeciency. in saying that, batteries used for some time will be not be as powerful as the new ones, and over or under charged batteries also wouldn't give you expected power.
i guess the CR123A you replaced is a new one, so it has the desirable voltage and current.
LCD itself and the driver actually do not require a lot of power, but the camera does, which draws away from the battery.
pc-cook
Jan 25, 2008 | Canon EOS Elan 7 35mm SLR Camera
Camping, Backpacking & Hiking Logo
50 people viewed this question
Top UltraFire Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you an UltraFire Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
