Question about ASUS A8R-MX/SI Motherboard
Ram upgrade i have pc2300 can i mix pc3200 with it
  • Jason Edinger May 11, 2010
    That depends on the motherboard. You should go to the manufacturers site and verify the highest speed that the motherboard can support. What brand motherboard?
  • Roberta Smith
    Roberta Smith May 11, 2010
    should work... but both ram will run at the lowest speed of the two
    Robert
    Problem Solver:
  • 18 Answers
Yes, but you cant maximize your PC3200 with that combination,
Posted on Jan 16, 2009
Which ram do i need?
You need DDR SDRAM like this,
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231039
Best value for the money
Have a nice day!
Aug 31, 2011 | ASUS P4G800-V Motherboard
I am going to upgrade ram to 1 gb. can i use ddr2 1 gb ram to upgrade .motherboard is microstar model ms-6526 ver: 2 . present ram is ddr1 400 MHz, 512 MB
If your computer has two RAM slots on the motherboard, i would recommend trying it. The computer will run on the 512MB stick alone and just not recognise the other stick. And if it works it works.
I have searced for support documentation and came up with none for the original MS-6526
I run my original version MS-6526 on a 512MB PC2300 (DDR1) and a 512MB PC3200 (DDR1) and it runs just fine for games and videos.
Personally I would recommend trying the DDR2 first and if that fails, return the card and get a DDR1 card. They are expensive, but at least they work.
Oct 08, 2010 | Intel Microstar MS-6526 Pentium 4 ATX...
I got intel 845 gl motherboard having ddr 256mb pc3200 ram. there are two slots availble. i want to upgrade
If you want to upgrade your ram, buy the same memory frequency like your current ddr 256 mb pc3200 memory. You can upgrade your memory up to 4GB and be sure they have all the same frequency to avoid system complications.
Dec 19, 2009 | Intel Motherboard
Pc5300 on pc3200 slot to upgrade msi 845gvm-v
PC5300 or more correctly "PC2-5300" and can work in a system that has "PC2-3200" RAM, and if mixed, they will operate at the speed of the slowest module. "PC-3200" RAM, however, is not compatible. PC-3200 is DDR SDRAM, having 184 pins. PC2-3200, and PC2-5300 are DDR2 SDRAM, having 240 pins. DDR and DDR2 modules are the same length,
but the pins on DDR2 are smaller and the keying notch is in a slightly different position.
You need to get the replacement ram all the same type ie - DDR or DDR2
And yes your motherboard should accept 2GB max
Jun 15, 2009 | MSI 845GVM-V (MS-7057-010) Motherboard
Tried to add RAM but now computer won't turn on
Didn't we speak online about this a couple of days ago? You can't mix and match RAM. What you added is probably not the right config for that machine. You need to go to this link, plug in your machine information and then REPLACE, NOT ADD TO what you have.
May 26, 2009 | E-Machines eMachines Desktop PC
Dimension 2400 is at 1.5MG - will not go to 2.0MG per manual!
yeah thats a normal issue with the dimension 2400 as the older bios only supports a max of 1gb of memory you will need to go to the dell website which ive linked below and get the bios update which will give you support up to 2gb-pc3200 ddr memory
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_PNT_P4_CEL_2400&os=WW1&osl=en&catid=&impid=
Dec 07, 2008 | Dell Dimension 2400 PC Desktop
Microstar motherboard p4m 266
Hi Andy. Sorry I disappeared, it was way past my bedtime.
Your board will support 2gb of DDR266/PC3200 memory, although there are other considerations if you're using very high performance modules.
The board is still fully supported by MSI and you can find further information at the following address:
http://www.msicomputer.com/product/p_spec.asp?model=P4MAM-L
If you click on the download centre link on the left of that page you'll find drivers and updated BIOS if you need them.
Hope this helps,
erch.
Mar 18, 2008 | Computers & Internet
Its about the memory card
The board supports upto 4 GB RAM. PC3200 RAM is supported.
1. Reset CMOS settings by CMOS jumper.
2. Try updating BIOS of your motherboard from :
http://support.asus.com/download/download_item.aspx?product=1&model=P5GL-MX
Best of Luck,
rajesh_im
Feb 13, 2008 | ASUS P5GL-MX Motherboard
ASUS A8R-MX/SI Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
