Question about Mitsubishi Televison & Video
Can i disable net command on mitsubishi wd52 52528...if so, how do i disable it...and if i disable it wil my inputs on the back of the tv be turned off?? i so confused...trying to get hd to work????
SOURCE: Net Command Does not work
Go to net command menu click on the AVR Learn icon.
Now you can program 4 different functions (inputs) from another remote. I programed 4 different source settings from my A/V receiver. And you label each input appropiately. Such as DVD, SAT, CAB, ANT.....
Now go back to net command and just to the right of previous Learn Icon you input the name of the source you just programmed for which ever device it is currently watching.
Net command is very confusing but works great once you figure it out. Hope this helps.
Posted on Feb 08, 2008
Slinteriors
  • 8617 Answers
SOURCE: TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Posted on Jun 15, 2008
SOURCE: Mitsubishi HDMI connection trouble
I have the same issue with my 73". Rather then going over all of my connections and equipment I'll just say htat I feel your frustration. I have been on the phone with Mitsubishi directly and it appears as though they have a free software upgrade that should address this problem. If you call 1-800-332-2119 and press 4 in the menu you will get someone to help you. Be patient. They will make you go through all of the fixes that you have already tried. They will mail you a flash drive that goes right into the front USB port of your TV. I hope this is of help. Good luck.
ret4good
Posted on Jan 05, 2009
  • 4 Answers
SOURCE: TV turns on with sound but blank black screen
This solution from troylove solved my problem. troylove11
Rank:wizard_s.gif Wiz
Rating: 85%, 1164 votes
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source.
Posted on Mar 14, 2009
SOURCE: TV Picture is green
I've corrected the green screen issue by plugging the blue, white, and yellow cable into the component 1 slot.
Posted on Jun 14, 2009
Inputs locked
Go into menu and select "net command", then review, then click on inputs to enable them. goodd luck
Dec 27, 2011 | Mitsubishi WD65737 65" DLP TV
I have a Mitsubishi DLP model # ws-65517, and the HDMI signal is scrambled purple, black an green lines. This is the case with my DVR and PS3, i tryed 2 different HD cables, reset button, unplugging it...
Don't you have more than one HDMI input on the back of your TV? If so, use another input and then select that input with your remote. If not, you may have to do the input replacement which you describe.
Jul 28, 2017 | Mitsubishi Televison & Video
I have a Mitsubishi Medallion HDTV Integrated 1080 WS-65615 and the speakers wont work. I've tried the the whole speaker/audio stuff but it wont let me select tv speakers.... help please!
hummm if i may suggest something... do you have net command enabled this would disable the speaker selection giving control of audio to other devices.
Oct 15, 2010 | Mitsubishi WS-65613 65" Rear Projection...
My Mitsubishi WD-62627 has no pic/sound w/ PS3
you just have to keep switching the back button off and when u turn it back on hold the front power button till you get 2 beeps
Apr 18, 2010 | Sony Playstation 3 (PS3) Console
Need help with Harmony One remote and Mits WD-65736
To ensure the remote controls your devices properly, you must disable Net Command.To disable Net Command you must delete all devices associated with it.
Open the Mitsubishi Television's setup menu.
Select Delete at the setup menu.
Select Entire Configuration and then select Next.
Follow the onscreen instructions to delete the entire configuration.
To finalize your selections and complete the NetCommand setup, select Finish from the finish screen.
#messageContent0_1 {font:10pt Tahoma,Verdana,sans-serif;}
Feb 01, 2010 | Mitsubishi WD-65736 Television
I have a Mitsubishi Model VS45603. We lost power
You will have to select the TV Menu (on the remote), go to NET COMMAND, and reassign all your devices and inputs again. You may even want to go to SETUP first to be sure the screen, video, audio, color, is what you want before assigning devices to inputs.
Aug 11, 2009 | Mitsubishi Televison & Video
I have a wd-52525 mitsubishi and it is supossed to be 720p but when I turn it on it says its 480i. What part of the tv makes it 720p or 1080p? Please help.......Thanks Paul
You will have to use component inputs for above 480i, and use the FORMAT key on your remote control unit (lower panel in center) to change to whatever you want for resolution. Be sure you have your signal input set to one of the Component inputs via Setup or Net Command (or use Devices on the remote)
Jul 19, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Power on tv and I get black screen with sound.
You have lost the input signal...you will have to go to Setup/Net Command and set your input to the one with signal (either a TV input or a Component input). If it is reset...the input likely switched to a non-usable input
Jul 12, 2009 | Mitsubishi WD-62525 62" Rear Projection...
I have a WD62825, it lost power while watching. There is power at the plug in.
Is the grreen light on?..or can be switched on via remote? Plug it out then back in. Green light flashing? If so...you have lost input signal or the tv has reset itself to another input (non functioning). Use Remote to set input (via Net Command) to functioning signal. If the Green light NEVER comes on...it may be major system failure. Be sure remote is set to "TV"
Jun 22, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Jan 28, 2008 | Mitsubishi WD-65833 65" HDTV
Televison & Video Logo
89 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
