Question about AEG Lavamat 16810 Front Load Washer/Dryer
AEG LAVAMAT 16810 Don't DRY Error E57
Hi, I have the problem with dry. It stop after 2 minutes. With the correct procedure it display E57. Who can help me? Thanks a lot David
3 Suggested Answers
SOURCE: My aeg lavamat 16810 washer dryer won't dry. The
I had the same problem and fixed it by replacing the triple valve. One of the inlets passes water to the condenser and this had failed. You can tell this by opening up the top and when the drier starts you here the drain working and then should hear a gentle hiss as the water is let through. If you don't hear anything then after 10 mins you get the E10 error. It cost me £27 which is cheaper than getting a new machine or a call out charge. If you feel competent then all you need is a philips screwdriver, pliers to get the clips off and a flat head driver to remove the rubber hoses.
Posted on Nov 11, 2009
  • 174 Answers
SOURCE: aeg Lavamat 64840 programme stops at 1 minute.
The main PCB, before sending the door aperture signals, checks for the following conditions:
• The drum must be stationary (no signal from the tachymetric generator)
• The water level must not be higher than the lower edge of the door
• The temperature of the water must not be higher than 40º C.
Automatic release device
In the event of a power failure, or if the appliance is switched off using the ON/OFF switch, or if there is a
fault in the solenoid valve, the bi-metal PTC cools within a period of between 55 seconds and about 4
minutes (at a temperature of 65°C), thus releasing the door.
if after swiching off for longer than 5mins and the door lock does not unlock the lock must be faulty.
Posted on Jul 16, 2010
How do I fix my AEG Lavamat T57800 dryer
E51 - Motor power triac short-circuited
Motor faulty ; Wiring faulty ; Electronic board faulty ; Motor capacitor ; also check tension of belt
Dado
Jul 15, 2014 | AEG T57800 Electric Dryer
AEG Lavamat 64809 error code E30
Lavamat?! Where in the *&%^ is this machine from? Yugoslavia! I'm guessing it will not allow water IN Because only the Spin (Centrifuge) cycle works?! So if that is so you need your water inlet valves replaced, there are Two. Even in machines named after a Bar of Soap!
Jan 04, 2014 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG Lavamat 76810 E70 7Beeps Does seem to still work but display shows E70 and 7beeps over and over. Many thanks gary
I Have AEG Lavamat 76810 E70 7 Beeps and Beeps never stops
The water was not hot
I took all the multi-plugs out and put them back in the whole machine ALL CONNECTORS
Now it works fine E70 is gone
Jul 14, 2011 | AEG Lavamat 16810 Front Load Washer/Dryer
Not drying clothes still getting warm and turning but despite leaving it for hours the clothes never become dry just warm and damp
sounds like your clothes are not spun dry enough try spinning on maximum speed alternatively check your water pump is not partially blocked maybe you need to clean filter let me know how you went
Nov 12, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
My aeg lavamat 16810 washer dryer won't dry. The error message is E10, meaning the water isn't going in. Water is running until the dryer kicks in, then the valve closes and it stops. The heater etc are...
Oct 28, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
16820 dryer not working
I suggest checking the moister sensor and or cycling thermostat. the hi limit thermostat as well, with a meter for continuity. other wise you may have a bad timer
Mar 20, 2017 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG Lavamat Turbo 12830 - error code E20
Hi
E20 means there is a bolckage in there
remove filter and clear any debris in there and check impeller is turning ok.
regards
Mar 21, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG Lavamat 16820: Strange noise coming the machine
Ok, the motor windings are bad. the A.C. hum is a warning that the motor will sound when the windings are separated or shorting. its unable to hold a balanced current.the motor will actually stop soon if it isn't repaired.
Feb 15, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG 16810 UPGRADE WASHER DRYER E10 ERROR
This is worth posting in case anyone else has the problem. The mechanic was stumped and then around 3 days later a Zanussi gave the same problem - steam emitting from the drum. He changed the valve - the entire unit. Problem solved. Zanussi and AEG have identical internals. He changed our valve - problem solved.
Jul 22, 2008 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG Lavamat 16810 Front Load Washer/Dryer Logo
104 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
