Question about managemylife.com
Kenwood CD/DVD player moder DV-605 tray is jammed, how can I manually resease it
I was loading discs and a disc jammed in unit. I cannot get tray to open, I can hear it trying to load but does not play
  • 51 Answers
You have to play the disc in another player or you can change the type of the disc.. the player is just not compatible with your disc.
Posted on Dec 09, 2012
Panasonic BTT268 tray wont open
Dear Scott,
If there is a CD stuck inside a CD/DVD reader, you could try using a medium sized paper clip straightened up. Insert it in the small hole in the front of the DVD player bezel and push it till it opens the mechanism. Please, have a look at: http://www.youtube.com/watch?v=fa_4CsS7MKw
The problem can also be caused if one of the rubber band that moves the DVD drive "door" has dried out, or even if the power supply in not properly connected to the drive.
Hope you may find this info hopeful!
Best regards,
Miguel Luiz Martins
Nov 19, 2013 | Kenwood DV-605 Multi-disc DVD Player
Tray won't open
by just resetting the software will not work this is a mechanical problem this usually happens on players that is not use for a long time or improper closing of tray..fixing this kind of problem requires opening the cover of the unit..you need to lubricate all moving gears and parts by putting enough amount of lubricating oil..you have also need to assist the motor manually by helping it to push the tray out just gently pull the tray with your hands during a eject command on the unit clean also the limit switches of the tray make that contact are properly working..good luck!
Apr 06, 2012 | Kenwood DV-605 Multi-disc DVD Player
Disc tray does not come out, display say hello
There is a flex cable that attaches the tray assy to the main pcb ,make sure that has not pulled out, also see if tray tries to move at all as it may need the mechism realigned and the open/close switches cleaned.Also the is a gear that turns the tray that has broken teeth on,check that gear ,as tray must turn before unit will intalize
Apr 16, 2010 | Kenwood DV-605 Multi-disc DVD Player
DVD tray makes noise when it rotates
This noise can be casued by two things:
1) The tray is not completely in the loaded position and the "clamper" is rubbing. Replace the loading belt and the loading sequence will complete and the noise should stop.
2) The "CD table" that is part of the spindle motor assembly has slipped a bit. This will make the CD/DVD ride too low and strike the lower tray support. This will require that the table be "re-aligned" to the proper height which may not be possible on your model without special measurement equipment. The height is critical to proper operation of the unit.
Try replacing the load belt first and report your results.
Thanks,
Dan
May 30, 2009 | Kenwood DV-605 Multi-disc DVD Player
Re: Kenwood DV 605 CD Player... Power On: Reads "Loading." All 5 CD lights are lit up but the CD changer does not turn. CD #1 appears on screen with two green lights appearing.
ace71cf.jpg We repaired this problem by taking the advice of another member of FixYa! The component had recently been packed to be shipped. After unpacking the unit when we powered up the read out only displayed "LOADING" and the CD changer door would not open. We removed the exterior cover and gently moved the CD changer one position. When it locked back into position we powered up and the unit works fine now. FixYa sure help me save perhaps a $100. or more by not sending it to the manufacturer or another shop. And it was working within minutes so we could enjoy using it right away. Thanks guys I very much will recommend this sevice to others... this was the 2nd problem we fixed that day by logging onto FixYa!!!
Z-Dawg
Dec 06, 2008 | Kenwood DV-605 Multi-disc DVD Player
Tray will not open on my dv-605
Solution: Unplug power from wall. (Don't just turn off!) Next: Remove exterior case. Now gently turn the CD changer clockwise one position. Power up and try again.
I had this same problem after unit appeared to have froze up when unpacked from a shipping box. The CD changer had got off track and by gently moving the CD changer 1 position it fixed the problem. Works fine now.
Best of luck,
Z-Dawg
Apr 30, 2008 | Kenwood DV-605 Multi-disc DVD Player
Disk error with Kenwood DV-605 multi-disc DVD player
Try the following
when the error is on the screen, press the number 1 key on the remote, this should take you to the fist chapter of your DVD no matter which region it is
Miguel
Jan 03, 2008 | Kenwood DV-605 Multi-disc DVD Player
Dv-605 kenwood
I have a similar issue with my DV-605 as well. When the unit power on, I can hear the motor trying to start, but the DVD does not spin. Being the adventurous type, I opened the case and turned the DVD drive motor a few revolutions by hand and then the dvd played. I think I need a new DVD drive motor. You may as well....
Dec 09, 2007 | Kenwood DV-605 Multi-disc DVD Player
DVD
I just fixed mine. Same scenario, with the loading and #1 displayed. The tray changer was jammed.
Take the cover off the unit and gently convince the changer to spin. It will go *crack* and then exhibit free-play. Turn the machine back on and voila it works.
I'm now watching Braveheart on 480p on 55"widescreen!!!!!
Wally
Oct 27, 2007 | Kenwood DV-605 Multi-disc DVD Player
managemylife.com Logo
53 people viewed this question
Top managemylife.com Computers & Internet Experts
thinksewfast
Are you a managemylife.com Computer and Internet Expert? Answer questions, earn points and help others
