Question about Water Heaters
Water won't stay hot long
The burner comes on when it's supposed to and heats the water but must not heat it completely because the hot water runs out too soon. Any suggestions?
  • Water Heaters Master
  • 5,245 Answers
1) Thermostat may be bad, or out of calibration. Set temperature higher, and/or troubleshoot by type of gas control.
Copy following link to troubleshoot by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html
2) Dip tube broken
http://waterheatertimer.org/Water-heater-dip-tube.html
3) Water leak running hot water out of tank.
Turn off all taps and put ear against pipe listening for water leak.
Posted on Dec 09, 2012
ftw1952
  • 10319 Answers
SOURCE: gas hot water tank. burner lights,water doesn't
gas regulator gone bad
Posted on Jan 16, 2010
  • 107 Answers
SOURCE: burner didn't ignite on my AO Smith model FXGT/PGXT
Unless your AO is a high recover it will take a while for it to fill up with the water that you have used then reheat the water in the tank.
Posted on Dec 18, 2008
canddplumb
  • 35 Answers
SOURCE: Not enough hot water to complete shower. Noticed
If it is a new water heater it might be that the water supplies are crossed. The cold water should be installed on the right hand side of the tank or on the bottom if your tank hooks up on the side. If its an older water heater the dip tube may have broken off. This is a tube that runs from the top of your water heater on the cold side to the lower portion of the tank.It puts the cold water in the bottom of the heater which pushes the hot water to the top.To change the dip tube out you must disconnect the cold water supply from the 3/4 inch nipple at the top of the tank. Then with a pipe wrench unscrew the nipple from the tank it will have the remainder of the tube on it.You can get a replacement dip tube at a plumming supply. Installation is opposite of removal. If this is your problem I suggest you get a new water heater .Usually its caused from minnerals in the water or buy two dissimiler metals being connected together in the water piping system causing corrosion Your water heater will probably fail in the near future.
Posted on Dec 16, 2009
  • 120 Answers
SOURCE: Hi there, I have a rinnai 20 ,the water heats up
Usually this type of fault is down to poor water flow. Basically you are asking the unit to work at a level below it's minimum output. Easy thing to try is to check any filters or water flow limiters in your tapware. Usually these are in the nozzle of the tap. I often take these out. The inifinty reduces water flow anyway and there is no reason to have water limiters. Try turning on two taps at once. If this stops the fault then you definately need to increase your water flow. Make sure the mains water is turned on full. Aslo you can check the cold water filter on the infinity. It's just above the cold water isolation tap (middle pipe as you look at it), turn that off first, the filter is a round plastic nut, unscreww it and clean the filter. Reconnect, turn you mains water back on.
There are other faults but this is by far the most common.
Posted on Aug 15, 2010
  • 10865 Answers
SOURCE: Whirlpool gas water heater model FG1H5040T3NV. The
Hello. I see this all the time with these Whirlpool units. Do this:
Make sure that the end of the thermocouple is over the pilot light. The therocouple needed to be pushed farther thru the hole in the bracket.
That may solve your problem, I hope it does.
That said, if this is a new unit, seriously consider returning it. IF it is not new and the suggestion above does not solve the problem replace the thermocouple. IF that does not solve it, replace the gas valve. Joe
Thanks for choosing Fixya!
Posted on Nov 29, 2010
New heat exchanger fitted still not heating
The heat exchanger is everything above the fire and makes the heat available for ducting. The combustion chamber supply\'s heat to it from either a burner or heating elements. Does your burner light or elements get hot? Check for power turned off.?
Nov 11, 2013 | Bosch & Power Vent Water Heater
Heater fires up but won't keep heating water
Sounds like the sensor is not working shutting down too early
Jan 06, 2018 | RTO Atwood Water Heater - 6 Gal LP
Reliance 606 Hot water Heating element (Pilot light) won't stay lit
Gas water heaters don't have elements, so I am confused about what type water heater you have..
Look on the side of tank for the label.
Find the brand, and type. Does it show BTUs? Or does it show wattage?
Then re-post question with this information, for best possible answer.
Also post question on Tank forum.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Aug 12, 2012 | Water Heaters
After hot water demand, burner stays lit, blew up Pex supply line
Thermocouple has 2 ends. One end attaches to gas control valve, other end sits inside the pilot flame.
Flame heats thermocouple, causing tiny electrical current that is detected inside the gas control valve and keeps the gas valve open so water heater can turn on when thermostat calls for heating.
If pilot goes out, then no electric current reaches gas control, and all gas to burner and pilot is shut off.
If pex line burst, that implies very high pressure, caused by closed system with check valve that stops expansion, or possible clog in the water line, or high local water pressure, or clogged factory-installed heat traps.
Put pressure gauge like BTG100 on the drain valve to check pressure, should not exceed 80psi, install pressure reducing valve on cold water line, install expansion tank on cold water line. Remove heat traps and install ordinary pex-lined di-electric nipples from hardware store.
If the water was super hot, then overheating could have caused the pipe explosion.
However the gas control thermostat is ECO protected, and if ECO (energy cut off) trips because of high heat detected inside the tank or combustion chamber, the gas control will trip off and no longer work, gas control needs to be replaced. Some newer electronic gas controls can be reset, but that type heater uses a thermopile instead of thermocouple.
Thermopile is basically a group of thermocouples, that product more electric current that is used to power electronics inside the gas control valve, which issues an error code on the gas control, and some day will send a text message each time out-of-range event occurs.
Copy following links for troubleshoot resources, including troubleshoot by type of gas control valve:
http://weaterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
http://waterheatertimer.org/Low-hot-water-pressure.html
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
Jul 12, 2012 | Bosch Aquastar 125B Gas Valve NG - Part...
I have an A.O. Smith Permaglas Water heat (Natural Gas) that will not stay lit.
There may be a draft blowing out the pilot. Place some fiberglass insulation inside the cover for the burner or pull down the insulation from inside the jacket just over the burner opening.
Mar 03, 2018 | Water Heaters
The pilot won't stay lit on gas hot water tank.
Make sure thermocouple tip is seated inside the burner flame.
Make sure thermocouple is not overtightened. Finger-tight + 1/4 turn.
If the pilot lights, then ECO energy cut off is not tripped, but gas control valve might be bad.
Check color of pilot flame: it should be strong and clear blue.
If pilot flame is weak, or color of flame is yellow-orange: Clean pilot orifice and burner and combustion parts on yearly basis.
Clean air intake screen if applicable.
Increase air supply to water heater. Open a window and see what happens.
Check for adequate draft going up chimney using match under vent hood to see if smoke drafts immediately upwards.
Bleed air out of gas line.
Check gas pressure.
Open following links for troubleshoot resources:
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/pdf/Pilot-outage-troubleshooting.pdf
http://waterheatertimer.org/pdf/Vent-spillage-test-atmospheric-gas-water-heater.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Sep 21, 2011 | Water Heaters
My gas water heater pilot light will not stay lit
Hi Mike,
1stly you have to understand what the pilot light does!
Yes, it lights the flame, but it protects you from gassing yourself!
that is thye main job!
hava a look inside!
In front of the pilot flame, (it might have a double flame... (one flame on the bottom & another on top.) is a curved piece of metal plate. The flame is supposed to heat that plate untill it it very hot! Thenm the plate bends down as it is a bimetyaalivc strip!
This opens the bsaety valve & you can let go.
The flame will noe stay on. If a gush of wind blows the flame out, the strip will cool & the safety valve close, preventing a dead family in the morning.
There is a newer system as well.
Right in front of the flame, is a pointed sensor with it's tip in the flame. . It has a electric cable running to a safety valve. This sensor have to heat up as well. It is a heat battery that activates the valve. See that it did not move!
If it heats up, & the valve does not keep the pilot flame going after a few seconds, the unit has to be replaced!
Safety first!
Andy
Sep 04, 2011 | Water Heaters
Parkray Cumbria efficiency problem
Some circulation pumps have a 3 phase mixing valve (cold,warm,hot) to regulate the water pressure in the building; no way to know unless you trace the plumbing. Basically, the hot water temperature could be lost because the circ-pump is cooling it with the cold water supplied to it. This is used to balance the pressure (aka Pressure Balancing Circ-Pump), so heater is really working overtime to heat the water. If the pump has two in and one out that's more than likely your problem; but you should consult a "old-school" plumber in your area.
Nov 25, 2008 | Water Heaters
Water Heaters Logo
192 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
