Question about Philips 60P8341 60" Rear Projection Television
52" plixyglass is cracked can i fix it easily and how much does
It cost. could i just eliminate the plexiglass and watch tv normally.
  • carcinagenic Jan 12, 2009
    there is a screen behind plexyglass
    thank you thank you
    Genius:
  • 2,920 Answers
Yes i believe you can.is there a screen behind the plexiglass?
Posted on Jan 12, 2009
  • 1 more comment
  • Ronnie Houston Jan 12, 2009
    then you should be able to watch it without the plexi if the screen behind it is solid enough
    ur welcome
    you can have a sheet of plexiglass cut for about 80 to 100 at a hardware stor or some place like lowes or home depot.youd have to have exact measurements for it though
Broken front plexiglass rca 52 inch tv
Hello
Contact the nearest authorised service center for RCA at your town.
Mar 06, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
How do i replace the plexiglass on the 65in hitachi, it was cracked while moving. Also where can i buy the plexiglass to replace the cracked one
According to Sears Parts Distribution, the panel (which unfortunately is not a piece of plexiglass) can be purchased at this website:
http://www.searspartsdirect.com/partsdirect/part-model/Hitachi-Parts/Television-Parts/Model-65S500/0505/0333200/50022581/00001?blt=06&prst=&shdMod=
at a price of $468.15
It may be worth investing perhaps in a new Mitsubishi DLP, which can cost as little as $999 at places like Costco. Though I did read that your particular TV has an excellent picture.
Jan 21, 2011 | Hitachi 65S500 65" HDTV-Ready Rear...
I have a 52" Toshiba
in general cracked lcd panels cost more than the tv is worth.. depending on model panel replacment run 1500 to 2000.. and physical damage is not a warrenty item. do you have a toshiba or a rca the decription says you have rca r52wm24 which is not a lcd. that is a tube tv. and if it is cracked that definatly can be fix or replaced cost effective.
Oct 27, 2010 | RCA R52WM24 52" HDTV Projection Television
Broken plexiglass screen
If your TV is anything like mine (which I expect it is, since they’re the same brand), all you have to do is use a T-20 screwdriver bit to remove all the screws from the back of the frame around the plexiglass. Once the screws are out, the frame just pops up and the plexiglass is easily removable.
Mar 20, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Cracked Screen Protector
what is the model number for you set. is it a hd52w56 or something like that. on that model it is called the super sheild. is the inner screens damaged.. if just the outer screen that runs 200 or more. i have seen people just replace the plexiglass on it. the inner screens run about 250
Nov 09, 2008 | Televison & Video
Cracked cover D52W19
i have used plexiglass for customers in the past. it has work just fine. rca call this thing supersheild and charges about 200 dollars.
Jan 12, 2008 | RCA D52W19 52" Rear Projection Television
Replacement of outer screen for a Toshiba TP50H60 projection tv
A frosted sheet of plexiglas works well. I put a plexiglass screen on my own 62 inch projection TV. It must be frosted to received the image being projected.
Jan 03, 2008 | RCA R52WM24 52" HDTV Projection Television
52" LCD HDTV w/ Cracked screen
No way. The lcd panel is more then the price of the tv. Sorry.
Sep 04, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Philips 60P8341 60" Rear Projection Television Logo
118 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
