Question about Mtd Snowthrower Snowblower 5 24" Parts Manual Tmo-35275b 315-555-088
How to adjust a carburetor for a MTD 1997 snowblower?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,069 Answers
2 stroke?? read down to the adjustment part.
http://www.aerocorsair.com/id150.htm
Posted on Dec 11, 2012
Mtd 31c won't stay running?
You probably have to take the carburetor apart and clean it using a spray type carburetor cleaner spraying the jets and small holes in it.
Mar 16, 2014 | MTD Genuine Factory Parts Auger Belt for...
How to take a carburetor off an MTD Snow Thrower
Get user manuals for craftsman snowblowers to train yourself in clearing the pathways that are fully covered with snow.
Dec 15, 2013 | Mtd Yard-Man 26" 208cc Two Stage Gas...
When I have the choke fully on, the engine in my snowblower runs. When I take it off choke, it sputters and stops. The fuel line is clear and there is no fuel filter that I can find.
The mixture settings on the carburetor may be off. Cleaning the carburetor and having the mixture settings adjusted may help. The fuel delivery is not an issue since choking increases the fuel/air ratio, i.e. adds more fuel for the same amount of air. Also worth checking the seals on the intake components, since excess air could be leaking in after the carburetor.
Oct 19, 2012 | Tecumseh Engine 5.5hp Horizontal OHV MTD...
Hose hook up for carburetor mtd 3/21 snowblower
one goes into the side of the carb. next to the engine, one goes into the air cleaner
Oct 16, 2012 | Mtd 22" Yard Machine Push Mower
1997 MTD Yardman 20hp 46in, hard starting,needs jump even with new batt; brothers mtd had similar problem, shop adjusted valves; prosedure for valve adj?
Time to clean the carburetor as the alcohol laced fuel sold today causes gunk to build up in the orifices of the carburetor and degrades fuel flow. You may want to add a little fuel cleaner such as Sea Foam (sold at Walmart) or any other type of cleaner to try and mitigate the starting problem. You may also want to drain the fuel when storing the machine for any length of time or add Stabil to the fuel which works fairly well.
Apr 10, 2011 | Garden
For mtd 3hp 2cycle motor only stays running when pushing prime repeatedly on full chock 5 sec
This is usually a symptom of blocked or partially obstructed metering passages in the carburetor. Carburetor should be removed and metering passages cleaned to restore fuel flow through the carburetor.
Feb 12, 2011 | Tecumseh Snowblower Snow Blower Starter...
Looking for a carburetor for a yard machines mtd
You may have better luck in identifying the engine type and manufacture (Briggs & Stratton, Tecumseh, etc) and get the number of the engine vs the machine itself, if possible. If you are able to do this, you can search ebay or the net for a wider range of possibilities for a purchase.
Feb 19, 2010 | Measuring Tools & Sensors
MTD Snowblower starts good but runs very rough
Carb adjustment. There is usually a HIGH and LOW fuel mixture adjustment on the carb. Sounds like the LOW needs to be adjusted. Do a search on the Internet for a service manual for your particular model/make. Simple job IF you have the manual there for guidance.
Good Luck
Jan 26, 2010 | Mtd Products Yard Machines 158CC Tiller
Auger stopprd working on an MTD snowblower.
The manual has a step by step procedure for adjusting the cables for the auger, speed selector and drivewheels. One socket wrench and about 10 min should do it.
My Yardworks is an MTD product and it's manual should be similar to yours. If you lost it, you can download it from MTD's site.
Dec 23, 2008 | Craftsman Garden
Mtd Snowthrower Snowblower 5 24" Parts Manual Tmo-35275b 315-555-088 Logo
442 people viewed this question
Top Mtd Tools & Hardware - Others Experts
Ted Maxwell
ray gallant
joseph m fucci
joseph m fucci
Level 1 Expert
Are you a Mtd Tool and Hardware - Other Expert? Answer questions, earn points and help others
