Question about Samsung HL-S5088W 50" HDTV
My samsung hl-s5088w wont turn on
Been in controlled temp storage for 6 months. just recently moved but tried flipping the blue switch downwards but nothing. its not making any noise or lighting up at all
    Top Expert:
  • Samsung Master
  • 14,553 Answers
Find and test the main fuse in this set first.
Posted on Dec 22, 2012
  • 231 Answers
SOURCE: HELP HL-R5067W LOUD GRINDING/VIBRATING NOISE
noise you are hearing can be the fans inside with bad bearings and or what im assuming given the info you gave.More likely the motor inside the optics engine (color wheel) is making noise..This will also cause picture problems..very expensive to repair..
Posted on Dec 14, 2007
tvservice306
  • 458 Answers
SOURCE: samsung hl-r6178w 3 blinking lights
check you lamp door switch.check lamp drvier board has 310 v ? if no may be power board bad if 310 v ok may be main board bad .
Posted on Aug 13, 2009
Slinteriors
  • 8617 Answers
SOURCE: samsung tv picture out
Replace the color wheel
Posted on Aug 28, 2009
Slinteriors
  • 8617 Answers
SOURCE: Samsung HL-P4663W/HL is making a buzzing noise
Color wheel needs replacement is the most likeliest cause.
Posted on Jan 02, 2010
ladywinn
  • 5138 Answers
SOURCE: I have a Samsung HL-S4266w TV When I plug in tv I
You need to replace the Color Wheel.
Encompass Parts Distribution 1-800-638-3328
Samsung Parts.com 1-800-844-7871
Posted on Oct 25, 2010
Where the the LAMP located on the Samsung HL-P5063W?
Just in case you still have no answer for this.
It is located in the back behind the cover.
1- UNPLUG TV
2-Take out the 14 or so screws holding the lower back cover on.
3- When the back is off take note of the little blue toggle switch on the bottom of center board. This is a safety switch, it must be depressed downward when re-attaching the back panel or TV will NOT power up/ I used tape to permately hold it in the downward position.
4- The lamp is right there on the right side and is held in by 1 brass colored screw. Undo the screw and pull gently towards the back of the TV to remove.
Feb 19, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
We replaced the lamp on our Samsung 50" dlp model HL-S5086W tv about 3 weeks ago. Just recently, the tv started turning off by itself and the red standby/temp light and the green lamp light flash for a few...
    1. Ensure that the TV is off. It may be advisable to unplug the TV as well.
    2. 2 Using a Phillips screwdriver, remove the single screw affixing the lamp cover (the small, grill panel on the back of the set) to the chasis. There is also a grill that is held in place by tension. Just "pinch" the thumb clamp on the bottom of the grill and slide it out. This is the same procedure you would perform to change the lamp, except in this case you will not need to remove the lamp itself.
    3. 3 Inspect the spring-loaded blue safety switch to ensure it is making good contact when the panel is secured. The switch should deflect downward when the panel is replaced. If the contact with the panel is suspect, very gently bend the metal bracket on which the switch is mounted.
    4. 4 Replace the grill cover and the lamp door, and continue to enjoy your TV.
    jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
  • 5.Check some basics first. Make sure the sleep timer on your TV hasn't been turned on, telling your set to turn off at a certain time. If your DLP TV is acting erratically, Samsung recommends turning the set off and unplugging it for 30 minutes. After 30 minutes plug it back in and turn it back on. Unplugging the set resets it, and that may fix the problem.
  • 6 Check your power supply. Make sure your Samsung DLP is securely plugged into a working outlet. Plug the TV into a different outlet to see if the problem still exists. Make sure that a fuse hasn't blown in your house or a circuit breaker hasn't flipped.
  • 7 Replace the lamp. If your Samsung DLP is shutting off or won't turn on, a bad lamp is the most likely cause. To replace the lamp, remove the lamp cover from the back of the TV by removing the screws with a Phillips screwdriver and slide it out and away from the TV. Remove the screws on the lamp assembly and slide it out of the TV. Disconnect the old lamp and insert a new lamp into the assembly. Slide the assembly back into place and replace the screws. Do the same for the lamp cover.
  • 8 Check for signs of overheating. Samsung DLP TVs generate a sizable amount of heat. If the components inside the TV get to hot, the TV will shut itself off as a protective measure. Make sure your DLP is out 12 inches or so from the wall. Make sure that all of the vents on the set are clear of any obstructions. Allow the TV to cool down for 30 minutes before turning it back on.
  • 9 Contact Samsung. If none of the above tips help, it's time to contact Samsung, as the problem is likely something that should only be fixed by a qualified service technician. More serious problems may include a bad power supply or a bad ballast. Attempting to repair those yourself will void your warranty and may cause more serious damage to your set.
  • The safety switch exists so the user does not accidentally remove the lamp door while the TV is on. Doing so could, theoretically, result in burn or electrocution. This spring loaded switch causes the TV to shut down when the door is opened.
  • Since the TV's chasis is plastic, expansion and contraction can cause the switch to lose firm contact with the lamp door. The TV's behavior could then be such that after being on for a while (getting warm) the plastic expands and the switch loses enough contact to cause the TV to shut down. The frequency with which this phenomenon occurs is not only dependent on the internal temperature of the TV, but also the ambient temperature of the room as well as the relative tension on the switch itself. The user's perception is that the TV starts up fine, but then "randomly" turns itself off after being on for a while.
  • If you have recently moved your TV, it is very common for random shut-downs to occur. This is because the move has shifted the flimsy plastic chasis of the TV, thereby loosening the contact between the lamp door and the switch.
  • Make sure your TV is off and cool when performing this procedure.
  • Jul 31, 2010 | Samsung HL-S5086W 50" HDTV
    Samsung HLP5063W looses picture, turns off wont turn on and more
    Jan 23, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
    Can a bad lamp cause my tv to turn off and make humming
    i would try cleaning the dust out of the area around the bulb and fan, and ensure that the fan has access to proper ventilation.
    Oct 09, 2009 | Televison & Video
    My 56 inch hi-def projection samsung tv turns off automatically
  • Mar 06, 2009 | Samsung DLP HL-P5663W 56" TV
    Samsung 50" fades when I turn on Vent in bathroom
    I would DEFFINITELY call the electricians back!!!!! I am a electrician and I would be very interested on what the electricians did, but something is definitly wrong, are you sure it is a different circuit you tried, try an extension cord to a kitchen or bath room outlet and double check, hope this helps.
    Jan 26, 2009 | Samsung DLP HL-P5663W 56" TV
    Samsung HL S5088W picture issue
    I would replace the lamp. A lamp can come and go as one of its problems of being bad.
    May 03, 2008 | Samsung HL-S5088W 50" HDTV
    TV turns off by itselft
    Feb 27, 2008 | Samsung HL-S6186W 61" HDTV
    Hlp4663w color wheel
    Check
    http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
    Jan 29, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
    Samsung HL-S5088W 50" HDTV Logo
    51 people viewed this question
    Henry  Thomas
    Henry Thomas
    Jerry Greenberg
    Jerry Greenberg
