Question about Microwave Ovens
How to set clock on Neff microwave oven model5969
MicrowaveSvc
  • 9098 Answers
SOURCE: Setting clock on Westinghouse WST3501 microwave oven
Normally you would press Clock, enter the desired numbers, then hit Clock or Start. Try it with door open and with door closed.
Otherwise, contact Westinghouse Small Kitchen Appliances at 800-947-3745 or see http://www.saltoninc.com/contact/contact.html
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 13, 2007
SOURCE: Neff HTHB86K Microwave oven.
The microwave unit is faulty as you can read from the display or the controller isn't working correctly, you should take your MW oven to an authorized service center. It can be repaired by yourself but it's highly dangerous because it has high voltage inside and microwave energy.
Posted on Feb 15, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Oven Glass replacement HTHB84K
You can find their support and spares links via their Belgian site or British site.
Posted on May 24, 2008
  • 228 Answers
SOURCE: Noisy Fan in Neff Combi Microwave/Oven. B6774.0gb
yes you can fix it yourself it is a cooling fan in the top it is round metal fan quite small venting waste fumes from cavity when grilling etc need to remove top panel and 3 screws to remove it is a push in fit.
Posted on Oct 28, 2009
SOURCE: microwave starts as normal but cuts out after
This is happening due to either the magnetron, or the Power Diode, or both, is breaking down, under load, then the unit detects the fault condition, & then, for safety reasons, to avoid a fire or explosion, shuts down the system. You need to take it in to be looked at please obtain a "Quote" before proceeding with any work. This way you can decide to repair or replace.
Posted on Mar 24, 2010
Testimonial: "Excellent. Thanks so much for your very quick and valued help! Will do as you suggest and give further feed back on outcome. Again, Many Thanks. "
I need instruction manual for Neff microwave oven model 5969
Use link, enter full ENr from rating plate and you can download PDF of manual
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
Dec 08, 2012 | Neff Microwave Ovens
Micro wave stops working after 30 secs
Replace the door interlockswitches - or try re-positioning the existing set. They wear after time
Jun 08, 2012 | Neff H5470 Microwave Oven
Microwave popcorn in a packet does not pop in my Neff microwave oven why?
The magnetron is not working properly or the power level is not set high enough.
May 05, 2012 | Neff Microwave Ovens
Why does my microwave oven keep cutting out and clock needs resetting before it can be used again
Check the screws in the mains plug and the wall socket. If there is no problem there, check the fuse holder in the microwave itself for bad contacts.
Hope this helps.
Nov 04, 2010 | Neff H7881N2GB 800 Watts Convection /...
The microwave will not operate although the timer clock still works
is the door hook broken it sounds like microwave is reacting as if door is always open.
May 19, 2010 | Neff H5642 Convection / Microwave Oven
Microwave starts as normal but cuts out after
Mar 24, 2010 | Neff H5642 Convection / Microwave Oven
Switching off after 23 seconds without heating
Hi Paul, did you get any answer for that?? My neff is giving me same problem.. if you know what is the solution can you please e-mail me to alinaseer1@hotmail.com? Regards
Oct 31, 2009 | Neff H5470 Microwave Oven
Lost instruction manual as to how you reset time on clock
Go here to download to your manual:
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. – I would greatly appreciate a FixYa! rating if the solution I provided fixed or helped you resolve your problem.
Thank you for using FIXYA!
Cheers!
IrishDruid
Oct 30, 2008 | Neff H5470 Microwave Oven
I have a Neff Microwave/Oven/Grill combo. The grill and the oven parts still work, but the clock has gone off and the microwave part does not work. What can i do to fix this?? Thanks
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
Jun 25, 2008 | Neff Microwave Ovens
Microwave Ovens Logo
576 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
