Question about Frigidaire FEF366 Electric Kitchen Range
Display, oven not working
I was using the oven (Frigidaire FEF366) at 350 degrees. I happened to be standing in front of the oven when something popped. There was a small, blue spark that looked like it came from inside of right above the display (the part that has the clock and all that). Now the display is not working and neither is the oven which apparently is controlled by the computer in there. The stove top and the lights on the unit are working fine. I am wondering if it is likely to just be a fuse or a more serious problem.
CW
  • nthomp3 Mar 01, 2009
    I have the same problem. My burners work fine but my display and oven will not work. I've only had the range for 2 yrs.
  • sinettex2 Apr 17, 2009
    I have a FEF364DWA and my display and oven does not work. Are there any fuses or something that might be simple to replace
    without calling a repairman?
Same exact thing happened to me.. the Control Module is defective - may be a power surge problem. was quoted $300 for the part plus labor.. is there a cheap way to fix it myself I wonder?
Posted on Dec 02, 2009
Re: how to recalibrate oven so the temperature in the oven matches oven display.
This is controlled by the thermostat. You will need to look into a replacement.
Apr 08, 2014 | Frigidaire Ovens
We have a free standing Frigidaire flat top stove oven that is electric I decided to use the self cleaning feature on it and the bottom element burnt into My husband removed the bottom element before...
I THINK THE HEATING ELEMENT YOU GOT COULD BE WRONG SIZE. I KNOW MINE WENT OUT WHEN COOKING SOMETHING HOTTER THAN I USUALLY USE LIKE 450 DEGREES, IT BURNT OUT. BY CLEANING OUT YOU'RE OVEN, WHICH REQUIRES REAL HOT TEMPERATURES, IT SOUNDS LIKE YOU ON THE RIGHT TRACK. IT BEING OLDER STOVE, A LOWER RATED ELEMENT I WOULD TRY..
Mar 24, 2017 | Kitchen Ranges
My Kenmore 911-4298814 oven won't hold broil or bake temp setting. The oven powers on with no error. When I press the "Bake" and dial up a temperature to (say) 350 degrees, the LCD displays...
just had similar problem with frigidaire, temp display would go blank, not even show clock, i took off back of stove, the circuit board would wiggle. when i pushed in on the circuit board it worked correctly.
Oct 30, 2011 | Ovens
Frigidaire compact 30 elec. stove. I need a wiring diagram for the front connections for oven, burners, oven lights. My oven isnt working and when I removed the front cover, noticed a wire not connected. ...
Does yours have the timer/clock thing that stands at the rear left of the stove? If so, make sure the far right dial is set at Manual. I had a repair person come out once (luckily it was someone I knew who didn't charge me) because my oven quit working. He turned the dial to manual and presto! :)
Sep 19, 2008 | Kitchen Ranges
Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work
my frigidaire oven will not light. The broiler works and the oven ingiter lights up, but the oven will not ingite. The electronic display does work.
Aug 25, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire Electric Range ES200/300
there is sometimes a thermal fuse inside the caseing might have to take the top off if not then you will need a new timer be safe and unplug
Jun 15, 2008 | Frigidaire PLEB27T9DC Electric Double Oven
Frigidaire Electric Slide-in Range - Oven Flash
Richard, sounds like you did all the pretests. You'll need a new display panel. When you work on it, be sure to cut the power.
Dec 13, 2007 | Frigidaire FES367 Electric Kitchen Range
Frigidaire FEF366 Electric Kitchen Range Logo
398 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
