Question about Whirlpool Duet WFW94HEX 27" Front-Load Washer with 4.3 cu. ft. Capacity, 10 Cycles, High Efficiency Model, NSF Certified Sanitize Option, Allergen Cycle, Precision Dispense and CEE Tier III Energy Star Qualified
Whirlpool WFW94HEXW1 front load washer makers awful noise during final spin. If you manually spin tub when empty, it sounds like coin sliding around under tub. How do I remove it? There is no front
Front of washer is all one piece with no lower kick panel.
    Sergeant:
    Champion:
  • 282 Answers
Sounds like you have a bad tub baring. This is not a small job I suggest thsy uoi get a trained service technician.
Good luck,
Marty
Posted on May 13, 2014
2 Suggested Answers
  • 16 Answers
SOURCE: my whirlpool duet front load washer has loose fins in the tub. how do i tighten them??
You're not gonna like this:
Pull the washer tub (see elsewhere on FixYa for step-by-steps), split the tub by removing the screws holding the two halves together, and remove the inner tub. Bend any tabs tighter that hold the fins on, and tighten any screws. While you have it apart, check for grease stains or other leakage on either side of the outer tub, and ensure the inner tub bearing is tight so that the inner tub shaft rotates smoothly and without oscillation. If there are stains or if the bearing is showing wear, replace that (back) half of the outer tub to replace the bearing (unless this is one of the few machines that allow you to replace only the bearing). You don't want to put all this back together, only to have to take it all apart again when the inner tub starts hammering on the inner tub because the bearing went south.
Posted on Jul 24, 2012
Why does my top load whirpool washer restart on its own after it finishes the last rinse and spin cycle. It does this on all settings, delicate, normal or heavy.
  1. Turn the washer off.
  2. Set the mode selector dial to NORMAL.
  3. Turn the dial counter clockwise ONE click (LEFT), clockwise THREE clicks (RIGHT), counter clockwise ONE click (LEFT) then clockwise ONE click (RIGHT).
  4. Now press the start button.
  5. All the cycle indicating lights should be illuminated.
  6. Press the Start Stop button once.
  7. Rotate the dial until Rinse, Wash, and Stop light illuminate.
  8. Turn the washer off and unplug it for 10 seconds.
  9. Finally, turn on the washer and it should now be reset.
  10. Run a test load empty to be sure the reset worked. If not perform the reset procedure one more time.
Oct 07, 2016 | Whirlpool Whirpool 3.5cu ft Top Load...
The tub continues to go off balance in spin cycle. Starts out smooth then starts to wobble terribly til the UL shows and shuts down. Support rods are good
There is a little device inside the washer that allows the agitator to spin independent of the drum. If this gets stuck, the washer will try to spin the whole drum instead of just the agitator. This will cause the washer to think the load is too large or out of balance, causing the error code. On some Whirlpools this device is just a washer.
Jan 07, 2015 | Whirlpool WTW8800YC 4.6 cu. ft. Cabrio...
Whirlpool trouble shooting
All Spin cycles regardless of load or even when unloaded and spinning?
If so suspension is broken.........Technician repair only, even the balance weights in the tub are too heavy for DIY to remove and replace springs
Sep 07, 2014 | Whirlpool WFW9550WW Duet 27" 4.4 cu. ft....
What does error code f 51mean?
F51 error code is a motor rotor position sensor failure or a lower harness problem. You need to check the motor in manual test mode, not automatic test mode. This will check the hall sensors and do a spin test: Be sure the washer is in standby mode (plugged in with all indicators off; or with only the Clothes Clean or Done indicator on). Select any one button (except POWER, START, STOP, and PAUSE/CANCEL) and follow the steps below, using the same button: Press/hold 3 seconds. Release for 3 seconds. Press/hold 3 seconds. Release for 3 seconds. Press/hold 3 seconds.
If this test mode has been entered successfully, all indicators on the console are illuminated for 5 seconds with 88 showing in the Estimated Time Remaining two-digit display. During the 5 second wait time with 88 showing in the display, press the same button once. You should be in manual test mode. If the button is not pressed within 5 seconds, the automatic test mode begins. The Rotor Position Sensor uses Wash, Rinse, and Spin indicators to detect the three hall sensors. Console can have up to two of these indicators on at the same time when the tub is not moving. Open the lid and rotate the basket by hand. The Wash, Rinse, and Spin indicators should toggle on and off according to the direction the tub is being turned.
SPIN TEST: Make sure lid is down. Press and release: 2nd RINSE or EXTRA RINSE. The lid locks and the lid lock indicator turns on. Press and release; SPIN SPEED, WATER LEVEL, or LOAD SIZE. The motor/basket spins at 23 rpm. Press again, motor /basket spins at 530 rpm. Press again, motor/basket spins at 950 rpm. Press again and motor turns off.
http://www.applianceblog.com/mainforums/threads/32879-Whirlpool-Cabrio-UL-F51-Error-Codes
Jul 27, 2014 | Whirlpool WTW8200YW 4.6 cu. ft. Cabrio...
Whirlpool front load wfw9151yw, I've had it less than a year and the bearings are bad!! Where can I buy bearings? How long is the manufacturers warranty. And what does it cover?
I also had the very same problem with my Whirlpool front loader. This is a common problem and if you have this less then one year they should replace the parts for free. The reason I said parts is because they also had to replace the entire tub and some other parts as well. It took then almost three hours. Thank goodness I have an extended warrentee which I think you shouls also consider.
Whirlpool is a very reliable company and after reading what Ashley sent to you I don't think your going to have any problems.
I just want to mention something to you. If the washer makes noise it could be something else like a clogger drain pump which is easily serviced. The way to tell is to have the washer off and try spinning the tub with your hand if it makes noise then your up for the whole monti.
Good luck,
Marty
Nov 01, 2013 | Whirlpool Duet WFW9151YW 27" Front-Load...
Cabrio Washer Problems
That error means that it is sensing an OVERLOAD. If it does this when it is empty, then there is something causing the error. IT could be something stuck in the drum around the seal or the bearing or it could be the bearings itself
May 02, 2013 | Whirlpool WTW8200YW 4.6 cu. ft. Cabrio...
Washer does not drain
1.), Pump may be bad. Check voltage to water pump in Spin Cycle. If you have voltage at the pump, but it does not run, replace the pump.
2.) If you have voltage to the water pump, and can hear or feel it running, cut power off, and remove the boot which is directly below the wash bin. The boot empties into the water pump. You will need long needle nose pliers or better, use water pump pliers to remove the straps holding the rubber piping to the pump and the boot. Remove debris from the boot, i.e., bobby pins, coins, socks, pens, keys, etc.
3.) If no voltage comes to the pump in spin cycle, you may need a new timer.
4.) Install a new belt on the motor pulley. You will regret not replacing the belt later.
Feb 02, 2013 | Whirlpool Whirpool 3.5cu ft Top Load...
My whirlpool duet front load washer has loose fins in the tub. how do i tighten them??
Jul 24, 2012 | Whirlpool WFW9550WW Duet Steam 4.4 cu. ft....
My whirlpool front load washing machine is making a loud knocking noise when in the spine cycle.
Bad tub baring or hopefully a cloged drain pump. If it is a tub baring it is going to cost a lot of money.
Good luck,
Marty
Whirlpool Duet WFW94HEX 27" Front-Load Washer with 4.3 cu. ft. Capacity, 10 Cycles, High Efficiency Model, NSF Certified Sanitize Option, Allergen Cycle, Precision Dispense and CEE Tier III Energy Star Qualified Logo
281 people viewed this question
Top Whirlpool Water Heaters Experts
Donni Steen
80stech
jdthefixer
Are you a Whirlpool Water Heater Expert? Answer questions, earn points and help others
