Question about Garden
My stihl.Ms 441 smokes from the little ports on the front of the muffler why is this I mixed my 5 gallon stihl 2 cycle oil mix with exactly 5 gallons
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,095 Answers
It's a 2 cycle engine..it should smoke.
Posted on Dec 11, 2012
5 Suggested Answers
dontbother10
  • 2220 Answers
SOURCE: port in front for oil and the back is for gas and mixture
Hello Andre;
I think you are saying you put oil/fuel mix in the oil tank and bar oil in the fuel tank; discovered your mistake drained both tanks and refilled with the correct fluids. Now the saw runs but smokes excessively. I think it will do no lasting harm. After you have run a few tanks of the correct mix (50:1) through the saw. Remove and clean the muffler and spark arrestor, reinstall them. Inspect your plug if any evidence of fouling replace it. I think you will be cutting with this saw for years.
Yes the additional smoke is caused by a very oil rich mixture and should abate with each fresh tank of fuel. If the chain is not moving ensure the chain brake is not engaged.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Posted on Apr 23, 2010
Testimonial: "Thanks a million Andre"
  • 178 Answers
SOURCE: what is the correct mixture
50:1 is the correct mixture. Every company has an oil they would perfer you use. Namely, the one they make. I would imagine that if it ran perfect before you put that premix in there, the premix is your problem, assuming no one "borrowed" it and straight gassed it. It also sounds like once it gets warmed up, it begins to fail. I would do a compression test once it gets warmed up. Also, you could pull the spark plug, grab a flashlight, and see if you notice any scoring on the cylinder.
Here is a link for the manual, in case you lost yours.
http://weborder.husqvarna.com/order_static/doc/ZOUS/ZOUS2000/ZOUS2000-EB7000-0005.pdf
Posted on Nov 24, 2010
barterjoe
  • 344 Answers
SOURCE: keep burning up piston on
It sounds like you are running lean. Not a lean oil/gas mix but a lean Air/fuel ratio. This engine runs hot as a high performance engine. any air leaks such as crank seals, manifold gaskets or muffler gaskets can give you too much air for the fuel coming in.
Secondly from the fuel side:
Ethanol (curse it) combines with oils that have no nondispersants making a white chalky poweder in the fuel system causing less fuel to mix with air. any blockage or pin hole leak can cause less fuel to be brought into the engine thus less cooling and lubricating.
Your carburetor and fuel filter need to be serviced and adjusted correctly or they will affect the mix.
When done the engine should run no faster than 13,000 rpm top no load speed.
This engine should idle smoothly at 2,500 with no more than 150 rpm change
if the speed is not as listed above when the rebuild is done you need to go back into the machine.
Call up a shop like www.arcolawn.comto get a EDT8 tach. it is well worth the money.
good luck
Joe
Posted on Feb 12, 2011
al_kupchella
  • 843 Answers
SOURCE: what is 40-1 mix never
40:1 is exactly the same thing as 100 ml to the gallon. It;s just expressed differently. Put another way, 40:1 is 40 gallons of gas to 1 gallon of oil. Or 1 gallon of gas to 1/40 gallon of oil. 100 ml is very nearly 1/40 gallon. Good luck. Vote if you found this helpful. Al K
Posted on May 22, 2011
What is the oil to fuel ratio for a cub cadet trimer/brush cutter?
The exact mix ratio for Cub Cadet trimmers varies, depending upon the exact model. Cub Cadet's ST 228 2-cycle trimmer model uses a mix of 2.6 fluid ounces of 2-cycle oil blended with 1 gallon of unleaded gasoline or a 50-to-1 ratio. This equates to 20 milliliters of 2-cycle oil to 1 liter of gas. The Cub Cadet BC 210, on the other hand, requires a mix ratio of 40 to 1, or 3.2 fluid ounces of 2-cycle engine oil to 1 gallon of unleaded gasoline
Jun 22, 2018 | Cub Cadet Garden
Gas oil mix for 1990 evinrude 6hp
Mix 8 ounces of two cycle oil to one gallon of gas.
Jun 09, 2016 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
Does it work with pure (car) petrol. Do I have to mix with oil. What type of oil? How do I mix.
most 2 cycle machines will work with a 50 to 1 ratio, you mix 2 stroke oil with gas, that would be 2.56 ounces of the oil to each gallon of gas, put a gallon of fuel in a gas can, and add the required amount of 2 stroke oil, and shake it up, and use it as necessary!! Good Luck If you find that the machine smokes a little, you can cut back just a hair on the oil added
Aug 01, 2011 | Garden
I have a techumseh snow blower 5.5 engine. I need to know what type of fuel it needs. It says on the outside something about a 50:1 oil gas mix and lists some types of oils. Where can I get these oils,...
go to your hardware store and ask for some 2 cycle 50:1 oil, mix that with a gallon of gas and you're good to go. Before you mix, make sure that you read the oil container for it's recommendations! You can purchase a small container of oil that is all measured for 1 gallon of gas
Feb 10, 2010 | Garden
Wht is the gas to oil ratio for a homelite vac
Yours is not a current model and I did not find a manual. The following is an excerpt from a 26cc MightyLite Blower/Vac UT08550/UT08951 "Operator's Manual":
This product is powered by a 2-cycle engine and requires pre-mixing gasoline and 2-cycle lubricant. Pre-mix unleaded gasoline and 2-cycle engine lubricant in a clean 1 gallon container approved for gasoline.
Recommended fuel: This engine is certified to operate on unleaded gasoline intended for automotive use.
Mix Homelite Premium Exact Mix lubricant with gasoline according to the instructions on the package. If Premium Exact Mix lubricant is not available, use a high quality synthetic 2-cycle engine lubricant, mixed at 2.6 oz. per gallon (US).
Do not use automotive lubricant or 2-cycle outboard lubricant.
NOTE: Premium Exact Mix fuel mix will stay fresh up to 30 days. DO NOT mix quantities larger than usable in a 30 day period.
PREMIUM EXACT MIX (50:1)
GasolineLubricant
1 gallon (US) 2.6 oz.
1 Liter 20 cc (20 ml)
1 quart fuel:3/4 ounces of oil = 1 Gallon fuel:3 ounces of oil or slightly less than 43:1. Not what a current manual recommends.
If properly adjusted your blower will operate fine on 50:1 regardless of what the manual reads. HTH
Lou
Jan 31, 2010 | Homelite Leaf Vac Attack
Need to know gas mixture
GasolineLubricant
If properly adjusted your blower will operate fine on 50:1 regardles of what the manual reads. HTH
Lou
Jan 29, 2010 | Homelite Consumer Products Backpack...
What is the gas mix parts oil to gas
Your manual says 40:1.
I gallon of premium fuel to 3.2 ounces of quality 2-cycle oil.
I gallon of premium fuel to 3 ounces of quality 2-cycle oil (.Oz/quart) is about 43:1.
Purchase the pre-measured 2.6 ounce 2-cycle containers sold at most chainsaw outlets.
I gallon of premium fuel to 2.6 ounces of quality 2-cycle oil is 50:1.
Once adjusted with this mix your saw will start easier, plugs, pistons, and mufflers will take considerably longer to carbon foul. HTH
Lou
Jan 25, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
What is the gas and oil spec for Homelite Edge/Treamer and were can I find the online manual - UT20930
50:1 mixture. Trimlite, Trim 'n Edge, and EasyReach models.
Pre-mix unleaded gasoline and 2-cycle engine oil in a clean 1 gallon container approved for gasoline.
Unleaded gasoline. Mix Homelite Premium Exact Mix oil with gasoline according to the instructions on the package. If Premium Exact Mix oil is not available, use a high quality 2-cycle engine oil, mixed at 2.6 oz. per gallon (US). Do not use automotive oil or 2-cycle outboard oil.
Homelite manuals are quite hard to find. I'm sorry that I can't help you with that.
Oct 11, 2009 | Homelite Garden
What is the fuel oil mixture for a homelite gas trimmer model ut20779
Hi a safe fuel mix is 25:1 but most homelites run a mix of 32:1 either one should be ok
Jul 03, 2009 | Garden
Garden Logo
83 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
